Home » Archived » Java WorkFlow Tooling (JWT) » platform is ready
platform is ready [message #7890] |
Mon, 09 January 2006 17:17 |
Originally posted by: fabrice.dewasmes.openwide.fr
Hi all,
the forge platform is ready. I can be reached at :
https://forge.openwide.fr/projects/jwt/
For Allen, and eventually Roman and Surrendra, could you please provide
me with a zip file containing your code contribution ? This will be
needed to examine and see what we can reuse. Please make sure you have
the copyright of you're sending or that the licence the code is under is
OK. If you're unsure don't hesitate to contact me.
I will package and publish Gwen's code as of tomorrow.
Fabrice
Re: platform is ready [message #7910 is a reply to message #7890] |
Mon, 09 January 2006 17:53 |
Originally posted by: rzulauf.objeng.ch
Dear Fabrice
> Hi all,
Great, thank you for your work.
Please give me time until Wednesday to package the code to contribute. I
will send it to you directly.
Roman
Re: platform is ready [message #7927 is a reply to message #7910] |
Mon, 09 January 2006 21:17 |
Roman Zulauf wrote:
> Dear Fabrice
>> Hi all,
>> provide me with a zip file containing your code contribution ? This
>> will be needed to examine and see what we can reuse. Please make sure
>> you have the copyright of you're sending or that the licence the code
>> is under is OK. If you're unsure don't hesitate to contact me.
> Roman
perfect. Timing seems excellent.
Fabrice
couldn't login upon registration [message #10508 is a reply to message #7927] |
Thu, 12 January 2006 01:08 |
Originally posted by: vgv8.yahoo.com.br
I tried to register and even successfully changed password (through Email)
but cannot login recieving
"Cookies must be enabled past this point. "
though I am sure my PC is full of them
My Login Name is first letter of first name dash last name
Guennadi Vanine
"Fabrice Dewasmes" <fabrice.dewasmes@openwide.fr> wrote in message
news:dpujvh$u8q$1@utils.eclipse.org...
> Roman Zulauf wrote:
>> Dear Fabrice
>>> Hi all,
>> Roman
> Fabrice
couldn't login upon registrations [message #10542 is a reply to message #10508] |
Thu, 12 January 2006 01:23 |
I really tried to register second time (since I had not received
confirmation by Email and upon returning the registration page, in order to
recall my name, was emptied) but my Login Name was already used:(((
I am on MS Windows XP SP2 (multimonitor 4 displays :)) ), .NET1.1, .NET2.0,
SQL Server 200, SQL Server 2005 Express, Visual Studio 2003/2005 .NET, 4
JRE, 6 Eclipses, Norton System Works, IE6, IIS, Together Workflow Editor CE
2.0 beta 1 from 30/12/2005 and a couple of hundreds of other apps.
Guennadi Vanine
Re: couldn't login upon registrations [message #10575 is a reply to message #10542] |
Thu, 12 January 2006 09:09 |
> Guennadi Vanine
Your status was pending and is now active on the platform. Please try to
log on again
Fabrice
could login but my post disappeared [message #10800 is a reply to message #10575] |
Thu, 12 January 2006 19:02 |
I logged in, thanks and posted as a third one, after someone on trip in HK,
but now I see again only Welcome posts from Fabrice
Guennadi Vanine
news:dq56gm$phk$1@utils.eclipse.org...
>> to recall my name, was emptied) but my Login Name was already used:(((
>> .NET2.0, SQL Server 200, SQL Server 2005 Express, Visual Studio 2003/2005
>> .NET, 4 JRE, 6 Eclipses, Norton System Works, IE6, IIS, Together Workflow
>> Editor CE 2.0 beta 1 from 30/12/2005 and a couple of hundreds of other
>> apps.
>> Guennadi Vanine
> log on again
> Fabrice
Re: could login but my post disappeared [message #13157 is a reply to message #10800] |
Fri, 13 January 2006 10:38 |
I don't understand this sentence sorry :(
You've been added to developper list and not simple observer. I hope
this will solve your problem.
Fabrice
> Guennadi Vanine
>>>apps.
>>>Guennadi Vanine
>>log on again
>>Fabrice
trying to understand post disappearance in forge [message #13349 is a reply to message #13157] |
Fri, 13 January 2006 14:44 |
I succeeded to log in with my Login Name and Password
I made a post in
Open Discussions
https://forge.openwide.fr/forum/forum.php?forum_id=173
that I observed to be a third one in that forum on 12 January.
On next visit, in a few hours, the same day I observed again the initial
state - only Welcome post.
In other words, the other 2 posts (which I already saw) disappeared.
Currently I see there only 1 Welcome post per each (of 3) forum. On the
moment of my posting they were 2.
If they were removed by moderator (I just posted mimicking the second post
from someone on biz trip in HK that I am also in Portugal and for already
quite a time), it should have been noted.
Because otherwise it appears to be a technical problem and therefore the
waste of time
Guennadi Vanine
news:dq8034$f93$1@utils.eclipse.org...
>> HK,
> You've been added to developper list and not simple observer. I hope this
> Fabrice
Current Time: Wed Feb 05 12:52:18 GMT 2025
Powered by FUDForum. Page generated in 0.03009 seconds
