Re: Question: Generating EObjekts using UML-Diagram (Rational SoftwareArchitekt) posible? [message #87389 is a reply to message #87374] |
Fri, 22 December 2006 15:01 |
Oliver,
Yes. The EMF importer wizards support reading *.uml or *.uml2 files.
Which version of RSA are you using? I believe that RSA 7.0 turns off
EMF's capabilities and that you must enable them to make them available
(but I'm not sure of all the details).
Oliver Smithy wrote:
> Hi everyone,
> I have read a lot about how to generate EObjekts using UML-Diagrams
> made with Rational Rose. My question, is it also possible to generate
> them via UML-Diagrams that where generated using IBM's Rational
> Software-Architect?
> thanks for any answers,
> cheers
> Oliver
Re: Question: Generating EObjekts using UML-Diagram (Rational SoftwareArchitekt) posible? [message #87434 is a reply to message #87389] |
Fri, 22 December 2006 15:22 |
Originally posted by: news.madlener.online.de
Hi Ed,
thanks a lot for answering so very fast. The model was not generated by
me. Therefor I will have to ask which version was used in the process, I
just received an *.emx and a *.project file, I don't think that I can
use that though, therefor I will ask for *.uml2 files
cheers
Oliver
Ed Merks wrote:
> Oliver,
>> Hi everyone,
>> Software-Architect?
>> cheers
>> Oliver
How to import the UML2 Files [message #87540 is a reply to message #87434] |
Sun, 24 December 2006 20:27 |
Hi Ed, and everybody else,
> Ed Merks wrote:
>> Oliver,
>> available (but I'm not sure of all the details).
I got an UML2 file, inside is XML generated by RSA7. I wanted to use it
to create an EMF Model, but the wizard will only check for other files,
do I have to change the extension? Or do I need other plugins?
Merry Christmas to everyone!
cheers
Oliver
Re: How to import the UML2 Files [message #87557 is a reply to message #87540] |
Sun, 24 December 2006 21:20 |
--------------060806010006050609040208
Oliver,
The importer should include all these choices (including UML model):
and the file dialog should support these (uml, uml2, xmi) file extensions:
Check in Eclipse's Window->Preferences...->General->Capabilities to be
sure the support for these capabilities haven't been disabled...
Merry Christmas to you and to all... ;-)
>> Ed Merks wrote:
>>> Oliver,
>>> files. Which version of RSA are you using? I believe that RSA 7.0
>>> turns off EMF's capabilities and that you must enable them to make
>>> them available (but I'm not sure of all the details).
> it to create an EMF Model, but the wizard will only check for other
> files, do I have to change the extension? Or do I need other plugins?
> cheers
> Oliver
Content-Type: multipart/related;
boundary="------------010705060301060807020209"
--------------010705060301060807020209
<html>
<head>
<title></title>
</head>
Oliver,<br>
<br>
The importer should include all these choices (including UML model):<br>
<blockquote><img src="cid:part1.08080701.08010707@ca.ibm.com" alt=""><br>
</blockquote>
extensions:<br>
<blockquote><img src="cid:part2.04070100.04050306@ca.ibm.com" alt=""><br>
</blockquote>
Check in Eclipse's
Window->Preferences...->General->Capabi lities to be sure the
support for these capabilities haven't been disabled...<br>
<br>
Merry Christmas to you and to all... ;-)<br>
<br>
<br>
<blockquote cite="midemmoqo$vmv$1@utils.eclipse.org" type="cite">Hi Ed,
and everybody else,
<br>
<br>
<blockquote type="cite"><br>
Ed Merks wrote:
<br>
<blockquote type="cite">Oliver,
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
cheers
<br>
<br>
Oliver
<br>
</blockquote>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="moz-screenshot.jpg"
Content-ID: <part1.08080701.08010707@ca.ibm.com>
Content-Disposition: inline;
filename="moz-screenshot.jpg"
/9j/4AAQSkZJRgABAQIAJAAkAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CADrAVsDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD0rxPrcWn6bJq1otvdxOyu jrsZZEKx7SGw
ePmyMda5CHx/e3Cs0OhLIq/eKIpA+uI6t67fXGp/C7T7+8k8y6urS2mmfaBu do4CxwOBkk9K
pxXMFr4WtrMPHEssKuWLRg7iOfvOp6100acZLVHFUdWVfkjPlSV9k+rGP8R7 iM4fSIlPoQg/
9p03/hZUv/QKg/8AHP8A4iuR1CO3MuU1AOw6IHtzn8pifyBPtXbeGoLK++G8 +nXh2yXuqmC1
k25CTmJShJwSASNpIGcMenJrapRpw6HFVqYqFXkVTpfZfcQf8LJl/wCgVB/4 5/8AEUf8LIl/
6BUH/jn/AMRWh4j0Sw1HxZ4o1DUblooLFbX5QxQMXRQCWCOQBjoFOSRyKisv AugzyXrzarPD
b2d4ElNwRbusDRAoSrrkNvYLk4BAOBWajStdoydXHczjGa3fbo2r/gyp/wAL Il/6BcH/AI5/
8RS/8LHl/wCgXB/45/8AEVh+LNCt/DupW1hFcedMLWN7n5wwSU5yBwCBjBAP OCPWt34j6hIP
EF/ZpqmoFS0W+zIxABsU5B38nODjaOSfTmvZ03ay3MXi8XGMnKdnFpbLrf8A yD/hY8v/AEC4
P/HP/iKP+FjS/wDQLg/JP/iK7/8AsfSv+E7/ALb8/wD0r/j08nY3+v8AK37t 2cf6njGMe+a4
G41CSw+H/h0xapf2UjLd7FtBxKRJwHO9cDnrhup/GIqnLaJ0VamLpXcqu1+i 6NL9Q/4WLL/0
C4PyT/4ij/hYsv8A0C4PyT/4iqngKTyrrW5POkh2aRO3mxDLpgryvI5HUcj6 irsUum+KIRDc
Pf3LaTptxcyXchWOa4IcMqEnf8oBIHJ69B3t06adrHPDF4qcFJVNX0sv689h P+FiS/8AQMg/
JP8A4ij/AIWJL/0DIPyT/wCIqH/hFLH7Bs825+2f2L/a3m7l8vr/AKvZjPTj du6847Vr6l4S
0yPUryfUtSv51+3Q2aNJIWlYmJXJyI3Lt82AuF6daXLS7FKvmDV+f8vPy8jP /wCFhy/9AyD8
k/8AiKP+FhS/9AyD8k/+IqvJ4Z0+0trISjU7ua9luo4/ssQDIIm2gmFhuYkj JG5cDjtVfxZb
2lvFoIt7ZYpJNKhklZAAHJzyQB97g5JJzx0xzSp0m7JGU8XjoRcpT2t0XX5e Zo/8LCl/6BkH
5J/8RR/wsGX/AKBsH5J/8RXFCnVp9Xp9jl/tXF/z/gv8jtP+FgS/9A2D8k/+ Io/4WBL/ANA2
D8k/+IrjKWj6vT7C/tbGfz/gv8js/wDhP5f+gbB+Sf8AxFH/AAn8v/QNg/JP /iK42lp/V6fY
X9rYz+f8F/kdl/wn0v8A0DoPyT/4ij/hPZf+gdB/3yn/AMRXHClo+r0+wf2t jP5/wX+R2P8A
wnsv/QOg/wC+U/8AiKP+E8l/6B0H/fKf/EVx9LT+r0uxP9r4z+f8F/kdh/wn cv8A0DoP++U/
+Ipf+E7l/wCgfB/3yn/xFcfSij6tS7B/a+N/n/Bf5HX/APCdS/8AQPg/75T/ AOIpf+E5l/6B
8H/fKf8AxFchSin9Wpdhf2xjf5/wX+R13/Ccy/8AQPg/75T/AOIpf+E4l/6B 8H/fKf8AxFcj
S0fVqXYX9sY3+f8ABf5HW/8ACby/8+EH/fKf/EUv/Cby/wDPhB/3yn/xFcmK Kf1al2J/tnG/
z/gv8jrP+E2l/wCfCD/vlP8A4il/4TaX/nwg/wC+U/8AiK5MUoo+rUu35i/t nHfz/gv8jq/+
E1l/58IP++U/+Ipf+E0l/wCfCD/vhP8A4iuUFOp/VaXb8xf2zjv5/wAF/kdT /wAJpL/z4wf9
8J/8RS/8JnL/AM+MH/fCf/EVyopwo+q0u35i/trHfz/gv8jqP+Ezl/58YP8A vhP/AIil/wCE
yl/58YP++E/+IrlxSin9VpdvzF/bWO/n/Bf5HT/8JjL/AM+MH/fCf/EUf8Jj L/z4wf8AfCf/
ABFczRR9Vo9vzD+28d/z8/Bf5HofjuwutT0y5s7OFpriSX5EXqcCIn9Aa89b wl4qksPsU2iS
SxDOwtjcn0IavY3/AOQ9D/11k/8ARSVsV5kKsoKyPtKuFVSp7Tmadraf8MfO Fv8ADTX7eYyr
o9y0n95mU4/WtH/hDvF32T7J/Z159m3+Z5PmDZvxjdtzjOOM179RVvEze5zz yunN80pSb9V/
keEp4d8cx3r3qQ6kt1Iu15xcYdhxwW3ZI4H5Coz4U8YlblTZXxW5YNODLxKQ cgtz8xyc8969
6ope3l2RP9k0v5pfev8AI8DuPCHi28uGnutOvJ5mxuklcMxwMDJJz0FW7jQ/ Hl5A0F0mqTwv
jdHLcllODkZBbHUV7jRR9Yl2Qv7Jpa+9LXzX+R4T/wAI140+3/b/ALLqH2z/ AJ+PO/edMfe3
Z6cfSo38I+LJYIoJNPu3hhz5UbOCqZOTtGcDJ64r3qij6xLsgeT0X9qX3r/I 8Gg8I+LLbzPI
0+7i81DHJ5bhd6HqpweQfSiDwj4stvM8jT7uLzEMcmxwu9D1U4PIPpXvNFP6 zLshf2NQ/ml9
6/yPDP8AhG/Gf2D7D9m1D7H/AM+/nfu+ufu5x15+tX72x8dXerXWox2d3ZzX OzzVtJDGp2rt
H8Xp6+pr2Sil9Yl2RSymklZTl96/y8zw6Dw34ytrWS1gttQit5M74kl2o+Rg 5AODkcVG/hPx
VLBFBJp928MOfLjZwVTJycDPGT1xXutFP6zLsiP7GotW5pfev8jwb/hC/Ef/ AECZ/wBP8aP+
EL8R/wDQJn/T/GveaKf1qfZE/wBh4f8Amf4f5Hg//CGeI/8AoEz/AKf40v8A whniL/oEz/p/
jXu9FH1qfZB/YeH/AJpfh/keE/8ACG+Iv+gVP+n+NH/CG+Iv+gVP+n+Ne7UU fWp9kL+wsP8A
zS+9f5HhQ8G+If8AoFT/AKf40v8Awh3iH/oFT/p/jXulFP63Psg/sLDfzS+9 f5Hhn/CHeIf+
gVP+n+NL/wAIf4h/6BU/6f417lRR9bn2Qv7Bw380vvX+R4b/AMIf4g/6BU/6 f40v/CIeIP8A
oFz/AKf417jRR9bn2Qf2Dhv5pfev8jw//hEPEH/QLn/T/Gl/4RHX/wDoFz/p /jXt9FH1yfZC
/sDDfzS+9f5HiP8AwiOv/wDQLn/T/Gj/AIRHX/8AoFz/AKf417dRT+uT7IP7 Aw380vvX+R4l
/wAIlr//AEC5/wAh/jS/8Ilr3/QLn/If417ZRR9cqdkL/V/DfzS+9f5Hin/C J69/0C5/yH+N
H/CJ69/0DJ/yFe10UfXKnZB/q9hf5pfev8jxX/hFNe/6Bk/5Cl/4RTXf+gZP +Qr2mij67U7I
X+r2F/ml96/yPF/+EU13/oGT/kKX/hFdd/6Bk/5CvZ6KPrtTsg/1dwv80vvX +R4x/wAIrrn/
AEDJ/wAhS/8ACLa5/wBAyf8AIV7NRT+u1OyF/q7hf5pfev8AI8a/4RbXP+gb P+Qo/wCEW1z/
AKBs/wCQr2Wij67U7IP9XML/ADS+9f5GO/8AyHof+usn/opK5/xPqOu2/jK1 tvtGq2Ph5tPe
T7XpWni7ke68wDY48qXaoTkfKuSTycYG4k8NzrcTwSxyoLiZCyMGAZUVWHHc MCCOxBFSahoJ
u9RN/aarfaZdPEsMz2ghbzUQsUBEsbgbS7/dxncc5wMcZ75xcfxQht5tN01L 3Rrx7mykvl1O
+1EWUEkPnNHEM+WczlVy67VCsrYHYc3/AMLZ/wCJ7/wlflX39mf8Ip9o/svz /k+0fbvIz/d+
9xvxnbzj+Gu8sPhppWinTpNEv9S0y4srJrETwvHI0sTSeaQ4lR1zvLNlQv3i OmADVfhlouuT
XE2p3WpXMlxpn9nSs84yy+d5/mfd4cSYIA+QABQgUYoAw7v4y2emrqy3NpY3 kljp630b6PqQ
u4ZN0oh8tnKJsYM6E8N8pJ6gA3PiH4l8V6D8PNV1KGztNOv7Z4CtxBdC4QI8 gU7Q8QJfOAVZ
QMOCGJBUbmo+CYNb0e+0zXNZ1XU7e7i8rEzxReV8wbcoijRSwZUILhsbcDhm DSX/AINttZ8P
6jo+talqWpRXyKjyzSIjRhTuTYsaKgIb5s7STwG3AAAA3LF7ySzja/gggujn fHBMZUXk4wxV
SeMfwj0561xel/Eu21DxZpmieXpso1NJmgew1RLp4TGofbOqqFQld33XcZUg Ej5q6w6Slxoc
2k6lcz6jDPE8M8k+1HlR8gg+WqAcHHygfnzXP6d8PbWw1PQb2TWtVvP7BieG whn8gJGjR+WQ
dkSs3ygdT2+uQDH8Z+KdZ8N+Mor9bz/imtPiszqdr5ScJcSXEfnb8F/kZI/k XO7Pbk1h3vxO
1PRPFGp6peSSXXh99CGqWGnokanDXKQQt5mN2HGJDnlRKRtJXn1C60CxvrjU 5bpZJU1KySxu
Yi2FMSmXgYwQT5zgnPpjHfH8R/DzRfFOpXl9qT3Ze60waa6RyBVVBKJVccZ3 hwDySOMEGgDH
134nTeFZtVtdd0SNbuz0xNRiWxvDMkqtMIQrM8aFDvZeitwSeoAOHr3jjWPC nxB1G/1u3xa2
nhoTpp1lfvNDJI12saudyIFbLYJ2khR36V1l/wDDTStaOoya3f6lqdxe2S2J nmeONoolk80B
BEiLneFbLBvugdMgx6j8LdH1m6vrrV9Q1W/uL3T/ALBNJNMg+USiRXVVQKrK yrgKApxkqSWJ
AOL8dfE6a78LeINLsbi0g1CCyt72G+0PVTcoFN1HG6GQIhR/mHAByG5I79x8 VtX1Pw/8PNQ1
jR7+SzvLR4mV1jjcMGkVCrB1YYw+eMHIHOMg2NX8CReINEvdK1nX9ZvYLpFT czQxmMB1f5RH
EqkkovLKxAyFxubOh4t8L23jHw/Lot7d3dvaTOrS/ZSgZwp3BSWVsDcAeMHg c4yCAcnq/wAS
rjw7ea/bS6X9tsfDf2JL28e7CzzCcL86xLEELAk5G5R6YzgF98U7jS9Tm0m6 8PebqcGq2enS
Q2l6HRhcxs6MjuiZYbSCrBR0+brjU1H4aaVqtv4givL/AFKR9eS0W8l3xq2b cDay4TALYy3G
OeAKx/Gvw8nvtbttY0V7s3l7run3d84kiAtordHTzIw4wSAwODuye2OKALF1 8TprC/vNHutE
jGtQanZackUV4Wt3a6QujGUxhgAFfP7s8gYzkkR33xTuNL1ObSbrw95upwar Z6dJDaXodGFz
GzoyO6JlhtIKsFHT5uuNSX4aaVcvdXV1f6lPqlxe218dSZ4xKksC7Yiqqgiw AWGChzuOc8YG
+GmlTX41G7v9SutQOp22pSXUjxq0j26FIkKqgQIAx6KCc9elAGPqfivxoniz wXZjSbTTn1NL
03Omz3yuHaNSVDSrE20BdrgrnJYqQMZMeqfGWz02XWJDaWJtdK1A2MsMmpBL 6bayq8kVvsIZ
QWbGXGQhzjt2mu+F7bXL/TNRN3d2WoaY8jWt1alCyCRNjqVkVkIIx1XIwMEc 5pweCYLK81GT
T9Z1WytdRu3vLqzgeII8jgCQhzGZU3Y/hcEZ+UrxgAp+H/G2p+IfEF5Y2/hm RdPsdTutPutR
N7HtQxAbSEwHYsTgjGFyDlucdpWPoHhuz8Of2p9jknf+0tQl1CbzmB2ySY3B cAYXgYByfeti
gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA OftRa/2rA1mk
aQvcTPhE2gsyKWOPUsSSe5JNdBXGeEtRi1a00y+gGI5ZZ8DzI5OigfejZlPT sT+fFdnQBn/2
7o/9sf2R/atj/af/AD5faE877u77md33eenTmtCuL0DVdFgt5dE1G5tDqR1i 7kXTnw8+WvZJ
In8rlsYKSBsYC4fIAzXLnxR4oXS9Bca1aRy3Gj218kl9IkJvrmXezRLGlu5m C4jHlxbHw4GW
LqQAeuUV5H4v8R6neXmsaPaXMcqX1vfWI0h7iNrpClrMQ626xCRQ7RAqxkcM sinaNw26n/CR
ay3i+C0ttbsZLNZbWO2jmuE8zULd442e4WJIC0n35MSJIkYMeSoVHyAekUVy /g7VrjU/7RFx
qX25oZQCRAEWNjklQQAUwNoMMg82NgwZnDIx4/SvFniWaxmuLrVLEs8ULXsU MqzSaUXmiWQs
ogUQeWjzErM0hBizyEkJAPWKK8/m19V+xRN418vRpPtB/t3Zbx75F8nZD5ro YHzvmOUUH91t
6xyZy28UeKJNFmvbi7j0+WS9tLe5FwUtYtOU2Ec7ne8UmwtM4T94H+8qjaTm gD1SiuTh1q+i
+Hh1K7njmuijIt1athApkKJOXeMLsClZGl8vZgM6qVwDzfhzX9e8RaxHpK+I oBBF9rEl7YND
dNMEWzdSsvlLHuBuHUnysbcrgsA4APTJp4bZA88scSF1QM7BQWZgqjnuWIAH ckCpK8jl8TT6
9YaVNqmsx2N3Pe6NLb6RH5SLdo72srShXBlYCR5RlWA/dYOSGzuePvEV1pH9 q48Qf2L9l0r7
Vp/+oH264/e7o/3qtv27IflTBHm853LgA9AoryfU/FniW3n8QypqljDJaxag VsPNV5oI4klM
M3kCDcm7ZE2+SVkYScDLoBsX17r0Xiqz8ONr86/aJYJZLuC2hV1EkN6zRoGR lEYa1jI3BnGW
BduMAHoFRzzw2tvLcXEscMESF5JJGCqigZJJPAAHOa8ztPFmrS2un/btY+x2 l/aWN/dagUiT
7AtxFcsUVmUosfmQRIpkDN+8ILFipGf4l8RXV54Q1qDVPEH9n2/9lXP2CT9x H/a/7y5jHLqQ
+6OO3b9zt/1+RwyYAPXJ54bW3luLiWOGCJC8kkjBVRQMkkngADnNR3l/Z6fE Jb27gtozuw80
gQHapduT6KrMfQKT0FeT+Itf127tfFVpc39iIfsmpwyab54aaKBIphHL5Kwh 49wWNt7ylCJO
AC6AdJ48ubvT9UXUbG6kt7iy8OavcRlVRgzL9n2hgwPAbDcY5UZ4yCAdxDPD coXgljlQOyFk
YMAysVYcdwwII7EEVJXj7a/runzTWthf2NjCt3fTW4u5xH9tnN/dBognkyPP gLH8kRR/3gGS
WXb3Gi6tcXXi3VrGXUvtCw5P2cQACAbgFB4DxtjcSJNwlBWSIhdyKAdJDPDc oXgljlQOyFkY
MAysVYcdwwII7EEVJXl+ia8dLup1s9Un1SQarqpvNEt1hlkt4lluZA6IqiQM zrEo3sVJmxjL
LivZ+MdSNnqsE3iaxmhtfssv2+0vLe4IEhmDR+f5EcETful2+YmCW2lwZFKA HrFRmeFbhLdp
YxO6M6RlhuZVIDEDqQCygntuHrXnf/CR+IJPF8FsdSsYY/NtUjs5t0El3E8c bSSratC83BeU
A+aqoY/nGI3LHhXVDq3jLR7i51v7ZqT6JdPe6fmEf2dK0lqWi2oodMNuXEhZ hs65ByAekUV5
frnizVrO11We11j/AImcX9orLpeyI/YYIYp2guNm3zBuMcB3OSjedwPmTHYa NcajF4h1LSb+
++2+VaW12JTEse1pXmVkUL0jHkgqGLMMnLtxgA6Cq/2+z8jz/tcHk+b5HmeY Nvmb/L2Z/vb/
AJcdd3HWuH8KeKr3VPGUllJfQTWtzaT3YtGuo5LmxKSRBYpY0iQwtiUhldpD lMbvlJav9vs/
7G/sH7XB/bP/AAkvn/2f5g+0eX/avnb/AC/vbfK/eZxjZ83TmgD0A39mtnNe G7gFrDv82YyD
ZHsJD7m6DaVYHPTBz0qSOeGZ5kiljd4X2SqrAlG2hsN6HaynB7EHvXjeq2us HwT4ss4bicaZ
eS6vfSTB33QeTPOHhVh8qq7C3Oz+JTdZI+Wu40jXdHsfFnibTrzVbG3vp9Vi 8m2muESSTdaW
yrtUnJyQQMdTQB2FFcP4j1PVoPElzFaarPbW8MWmRiGOKJlLXV1LA7kshbcq hWXnbuUZDDIO
Pc+LNWjtr3zdY+zXVlFcLpsRSIHWLiK5uYvKYMpLsRDBlYdhzMcY3IFAPTJJ 4YXhSWWNHmfZ
ErMAXbaWwvqdqscDsCe1Ek8MLwpLLGjzPsiVmALttLYX1O1WOB2BPavK9e16 9/tW1uItU+0a
7Z6hqBg8P7YztEVreCF/LVRMd6rGeWw3m5AAK4saPqmo6jrmhLd6vY6rbx6q DFcWl0tzhjZX
m5DLHBFHwAh2gFhuJY4ZKAPUKKKKACiiigAooooAKKKKAOU0C1nsjYW9zPPP Kks26SdVVzlF
PIVVHQ9gK6usd/8AkPQ/9dZP/RSVsUAFFFFABRRRQAUUUUAFFFFABRRRQAVl 6l4f0/VrhZr3
7XIAgRoFvZkgkXJOHiVwjg5IIZTkcHI4rUooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAx3/AOQ9D/11k/8A RSVsVzWtvsut
w3cSt912Q/cj7qQR+BrN+1N6z/8Agbcf/HKAO3oriPtTes//AIG3H/xyj7U3 rP8A+Btx/wDH
KAO3oriPtTes/wD4G3H/AMco+1N6z/8Agbcf/HKAO3oriPtTes//AIG3H/xy j7U3rP8A+Btx
/wDHKAO3oriPtTes/wD4G3H/AMco+1N6z/8Agbcf/HKAO3oriPtTes//AIG3 H/xyj7U3rP8A
+Btx/wDHKAO3oriPtTes/wD4G3H/AMco+1N6z/8Agbcf/HKAO3oriPtTes// AIG3H/xyj7U3
rP8A+Btx/wDHKAO3oriPtTes/wD4G3H/AMco+1N6z/8Agbcf/HKAO3oriPtT es//AIG3H/xy
j7U3rP8A+Btx/wDHKAO3oriPtTes/wD4G3H/AMco+1N6z/8Agbcf/HKAO3or iPtTes//AIG3
H/xyj7U3rP8A+Btx/wDHKAO3oriPtTes/wD4G3H/AMco+1N6z/8Agbcf/HKA O3oriPtTes//
AIG3H/xyj7U3rP8A+Btx/wDHKAO3oriPtTes/wD4G3H/AMco+1N6z/8Agbcf /HKAO3oriPtT
es//AIG3H/xyj7U3rP8A+Btx/wDHKAO3oriPtTes/wD4G3H/AMco+1N6z/8A gbcf/HKAO3or
iPtTes//AIG3H/xyj7U3rP8A+Btx/wDHKAO3oriPtTes/wD4G3H/AMco+1N6 z/8Agbcf/HKA
O3oriPtTes//AIG3H/xyj7U3rP8A+Btx/wDHKAO3oriPtTes/wD4G3H/AMco +1N6z/8Agbcf
/HKAO3oriPtTes//AIG3H/xyj7U3rP8A+Btx/wDHKANDXv8AXn/rq3/oEdY9 bGvf68/9dW/9
AjrHoAhN3bC2kuTcRCCLf5ku8bU2khsnoMEEH0wamrzHULfUj4W8Q20U0osb mTUrt5QzZi8q
WUNEp6KHIhO3uDPyOK6S91e6i16WAX/lzpeQQ2+m4T/SYH8vzJcEeYdu+X5l IUeVyOGyAdOZ
o1mWEyIJXUuqFhuKggEgeg3Ln6j1oM0azLCZEErqXVCw3FQQCQPQblz9R615 vJrV41xaX0Gq
pcaodNkN1bO0SrpzPNaiQHahaMIC5zIH2+Xkg4bOxoF5d3uv2L3V3b3m21vF ingk8xXXfan7
4jRXIYsMquBjBywagDsIpo50LxSJIoZkJRgQGUkMPqCCD6EU+uAl1G/sLCWS zu3hW3XWb5ow
iMszRXXyq24E7fnbO0qeeoqafWZ7fXTpd/4lewtoGnT7XJ9nR5mCWrqGLpsy POk+6o4A64JI
B3NFcTa6/qc0ts13c/ZdRaS0RdJ8tV86ORYjLJsYGT5C83IYAeVyDtbNC3v9 Vhshqv215Ly6
0WwcvMERG3TOZZMhMARLKDnBChgXDcUAei0VxOmatq09zAkmqxTRLb3kyy2y falm2CALuKxp
5m1pH4iC5wFyWDVseHL831tE0mq/aZP3gUZjIlAKbmDooEgUnAZAow4Vl3g4 AN6iiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigDY17/AF5/66t/6BHWPWxr3+vP/XVv/QI6x6ACisGTxr4ZikaOTW7NHQlW VpMEEdQRTf8A
hOfC3/Qesf8Av6KAOgorn/8AhOfC3/Qesf8Av6KP+E58Lf8AQesf+/ooA6Co WtYXvYrtkzPF
G8SPk8KxUsMdOSi/l9axf+E58Lf9B6x/7+ij/hOfC3/Qesf+/ooA6Ciuf/4T nwt/0HrH/v6K
P+E58Lf9B6x/7+igDoKK5/8A4Tnwt/0HrH/v6KP+E58Lf9B6x/7+igDoKK5/ /hOfC3/Qesf+
/oo/4Tnwt/0HrH/v6KAOgorn/wDhOfC3/Qesf+/oo/4Tnwt/0HrH/v6KAOgo rn/+E58Lf9B6
x/7+ij/hOfC3/Qesf+/ooA6Ciuf/AOE58Lf9B6x/7+ij/hOfC3/Qesf+/ooA 6Ciuf/4Tnwt/
0HrH/v6KP+E58Lf9B6x/7+igDoKK5/8A4Tnwt/0HrH/v6KP+E58Lf9B6x/7+ igDoKK5//hOf
C3/Qesf+/oo/4Tnwt/0HrH/v6KAOgorn/wDhOfC3/Qesf+/oo/4Tnwt/0HrH /v6KAOgorn/+
E58Lf9B6x/7+ij/hOfC3/Qesf+/ooA6Ciuf/AOE58Lf9B6x/7+ij/hOfC3/Q esf+/ooA6Ciu
f/4Tnwt/0HrH/v6KP+E58Lf9B6x/7+igDoKK5/8A4Tnwt/0HrH/v6KP+E58L f9B6x/7+igDo
KK5//hOfC3/Qesf+/oo/4Tnwt/0HrH/v6KAOgorn/wDhOfC3/Qesf+/oo/4T nwt/0HrH/v6K
AOgorn/+E58Lf9B6x/7+ij/hOfC3/Qesf+/ooA6Ciuf/AOE58Lf9B6x/7+ij /hOfC3/Qesf+
/ooA7DUZrife91a/ZpBdzIE8wPlF2hHyP7yhWx23YPIrPrY17/Xn/rq3/oEd Y9AF/wCGH/Ih
Wv8A193v/pVLWdY+LNOvdT+zyR6n+/kQxyC7ZR+9dtoKLJwANvTPfgY5vfDW GO4+HkMM0aSR
SXN8jo6gqym6mBBB6g1ytt4LS21MrdLJJbQyICo0eRjMI3YYJAK4YBTnnO48 DHOlONGV/a/I
1puNnzHpGkS3SPNY3brK8CI6ygkllYsAGz1I2Hnvkd+TU0bWdY1e6kk/suxi 0xLu5tvO+3u0
x8mV4t3l+SF5ZOm/gHv0qXR5WuNWvp/JuEjMEKBpoHjyQ0pIG4DOMj86yvDn h280TWrudtD0
Mfabu7lk1SGc/a3jlmeVVZfJGcZRSPMx8uecAVjBWVjNu7udBFrujzfbvK1W xk/s/P23bcIf
s2M58zn5MbW64+6fSi313R7v7H9m1Wxm+3b/ALJ5dwjfaNn39mD823vjOO9c vD4W1j+wbDSp
YtKH9jxW0dlcB3aS58iWGQbjsHkK/kKGUebywOT5eHjn8Falql1q11fT2lq+ rWV9bzJA7TC3
aaK1iQqSqbwFtixyF5YAZxuqhHYabq2m6zbtcaXqFpfQK5RpLWZZVDYBwSpI zgg49xVez8S6
DqLwJY63pt087ukKwXSOZGRQzhcHkqpBIHQEE1n+F9CuNLuL28u4I4Z7lIot o1O5v2KoXIzL
PggZkOFCjHJy27C49l4K1K206yt3ntC8FloluxDtgtZ3DSykfL0KnC+p6460 AdZFrujzfbvK
1Wxk/s/P23bcIfs2M58zn5MbW64+6fSsuy8caDcw6jdy6rpsGn2t6LOK9a9T yp2MMcvytkDP
zsuAT9wn2GGngvWHsdKtpXsU/sK0itrJlmdvtnlzW0oaQbB5OfsijA8zHmE8 7cNHP4P1y71a
41u4htBdy3ErCztdZubZQjw2qbjPHGrkg2v3NmDvBzlRkA7TTtT+332rW3k+ X/Z92ttu3Z8z
MMUu7GOP9bjHP3c98DQrn/Cnh5/DlvfWxaAwySwmAQhgFRLWCHGGJI5ibALN wRkk5roKACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooA
KKKKAOY17/Xn/rq3/oEdY9bGvf68/wDXVv8A0COsegC/8MP+RCtf+vu9/wDS qWlu9cmVGNrf
zTzSXDxxRqqxwvyxVElMLKzYAGN3Jzznik+GH/IhWv8A193v/pVLWC6x2l4s Ed3aPJZuYIZZ
ryOJUWORiokQjexVjnAIVtqk9KuEISfvv8bHLialWCXs1v5XO08OaydXsgzZ ZhGriTAG9WLA
EgdGBRgR0yMjg8VYfGEUsxL6RqUNgL1rH+0H8kxGUTGADashkwZRtB2dwTgZ IZ4V+ypc3Fva
XaXSQ2sCtMrhtzl5ixJHck5/GsqHwjcwWJukjuzqJ11rryXvneDyG1AyF/JZ zFnyTvHy7g2C
MOAazSS0T0OiLk4py3tr6neUV5+vhzUf7Yd00nbfC7vJrjVftKw/bbeRZhDb +dGTONvmQDlQ
F8nKk7Uzl3Xg6+uNL02KTR7tdPt3uM6dbJYs5ZvLEcrQTbraMgJLnyjyZNwC +ZIqso9UqnHq
UMus3Olqsnn29vDcOxA2lZGkVQOc5zE2eO469uf1bRbuTw5oVrcWcmrx2Txn ULKSZJmvFEDp
gtLsSUiRo5Mvtzs3AbgBWHe+G9SlW7WLQvK0y5tLSF7JHt7iVY0lupPLjWfM IZTJASrZRV3L
GTtU0AekUV5vonhzVrd9Ba70md3tZZlSS5uYt1rB9okZB+7OIWEflgCHcjru idVQIy9B4O0m
40v+0RPpv2JZJQQTOJGmbksxKnEnJwJmCyuoUSLlAzAHUUV5fo3ge90ux0sw aRBbXVraaOd0
RjVo51mP25gQfvNEFV2H+sUBctjFFv4T1ZbGCKPR/s80FpHFq774h/bkizQO 7ZVj5m9Irhcz
7CftGDgM+AD0Sy1KG+utRt4lkD2FwLeUsBgsYo5crz02yKOccg/UllqUN9da jbxLIHsLgW8p
YDBYxRy5XnptkUc45B+p8vn8FXVzLcSr4bu7LR3vZZU0i1j092DNBaospjlL wAAxTjIO8bxj
hmruPCGkX2kR6nHf+Yzy3ELJLJcec0oWzt4mYvgFjvjcZKqTjOBmgDpKKKKA CiiigAooooAK
KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDiP 7T/tvRNN1byf
J+3RJc+Vu3bN8MTbc4GcZxnAqvWpq0ENqsdvbxRwwROUjjjUKqKI4wAAOAAO MVl0AX/hh/yI
Vr/193v/AKVS1nzeO7s6lcW1vc6YQkrLGNjMWXcQpyHwSQM8etXvhqjSfD2B FkaJmub4CRAM
qftU3IyCMj3BFeWx6XqMWoGGRJ0aF0SRt6FVKMQ2OucEHA/PtW1KnGd+Y8/H V6lLl5Op6XqX
jC6l8DahfWubTVLTyg/yAqN0gXcu4EYI3cHkc+xPD/8ACa+NvtP2f+0P3vkf aNvkw/6vy/Nz
93+5zjr268Vp3jZ8I+J/+uVn/wCjmrBzF9s/tX7TbfZf7K+z/wCvTzPM+yeT jy87/v8AGcYx
z05rSlFJNNXODF1qkpxak1otn5u7LY8a+Nmv4LEah/pNx5flJ5MPzeYAU524 GQw69M81DL4+
8YwRwSSantSdDJGfIhO5QzLn7vHKsPwrQstfsotb0aZ5ovtNqllaxTb/AJUh aOPzc/w/J+9U
55/fHpsFc7eWj3mi6VPDPaFbezdZUa7iV1ImlbGwsGJwwIwOc8VolHqkcs6l VJ8tRvfq/L/g
l3/hY3iz/oK/+S8X/wATR/wsbxZ/0Ff/ACXi/wDiai0i4s4tIhjlWxMjPeSO Zoo2fKQI0PLD
IHmA4HRuQQckVoQ/2WZrd4/7N8mR4pNU8zysiJoYS3lhuQdxn4i+YHAwMKKb Uf5RRnXav7R/
e/8AMhi8feMZ455I9T3JAgkkPkQjapZVz93nllH40RePvGM8c8kep7kgQSSH yIRtUsq5+7zy
yj8asafLp8do63D6eujSW1qsgBjE7N5sBmBx++IyJT6YAxxtqLUrmy/s+/UQ 2ltcvZlcRXME
hkHnwFR+5RUzw57tgHOAFpWjf4SnKqo39o9u78/6Xcr/APCxvFn/AEFf/JeL /wCJo/4WN4s/
6Cv/AJLxf/E1y1FXyR7HL9ar/wA7+9nU/wDCxvFn/QV/8l4v/ia6/wCHXizW 9e8QXFrqV758
KWrSKvlIuGDoM5UA9Ca8nrvvhH/yNd1/14v/AOhx1FSEVB2R1YPEVpV4qU21 fuz2eiiiuE+o
CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigDhE
1WbWbA3dxbR2063tzbyRRymVQ0TiIkMVUkEpnoOtR1JHoq+H9Li05Z5JylxN K8rliWeTbI5y
xZsbnONzMcYyzHJMdAF/4Yf8iFa/9fd7/wClUtSXn9jo0t1eaRoESvPIglvJ URpGViCTmM8k
gnqaj+GH/IhWv/X3e/8ApVLWdrcTPbR3UAuxcwXF8kTw2wnT5pGyjpgnDYxk DA7kZFOMOeaj
exM2lG9rm3HpOieINBu9PhtI7AT7Bcpaokbgq25eduCMg4OPXoc458fDLwo1 nDeDVrs2s2zy
phcxbJN5ATa2zB3FlAx1yMda6fw87tcsJLdLeQafa7oEGFjOZcqB6Dp+FYVi YQmm6g8cn/CJ
zXEZ023LgiFpGQW8jJjPlFz+7jyfKLISAAotyEpwVrmVTDUar5pRKo+GXhRr OG8GrXZtZtnl
TC5i2SbyAm1tmDuLKBjrkY61JD8KvDVyheDUb+VA7IWSeNgGVirDhOoYEEdi CK5nSrXWB4J8
J2c1xOdMs5dIvo5i77p/OngCQsx+VlRjcHZ/CotcE/NXceDdd0fy7nSP7Vsf 7T/tXUv9C+0J
53/H3M33M7vu89OnNX7Wfcz+o4f+RGLJ8OfB0OqQ6XLrlwmoTJvitGu4RK68 8qm3JHytyB2P
pVif4VeGrW3luLjUb+GCJC8kkk8aqigZJJKYAA5zVrUbu30zxRPbQXdjdSX+ oWs0+j3NuTcu
+IYxPCxYZjjWNZCQj4MUnzKQdmP4i1mW78PeKobnXsX32TU4ZNE8lG8qBEmE cuFUSR7lWN97
sUPmYAG9MHtZ9w+o4f8AkRpf8Kj0D/n71L/v5H/8RR/wqPQP+fvUv+/kf/xF VfEGueItGvJt
MGrwMp+yzz6jcGO1S1WUXW4BzHIsce+3iVfMWRv3hUsSysteLXvEU5Dya5tE cWnxD7JHG8Uw
ub2a387e8ILMI1R1ZQsbMNwUocE9rPuH1HD/AMiNL/hUegf8/epf9/I//iKP +FR6B/z96l/3
8j/+IrF1/wAcatp2imdNTgtrrTvtp3XtxFbpqPkzyxIiqYWMsmIQXWMxY81c Ebht9Yo9rPuH
1HD/AMiOB/4VHoH/AD96l/38j/8AiK1/DngXTPDGoSXtlPdySPEYiJnUjBIP ZRz8orp6KTqS
as2VDCUISUoxVwoooqDpCiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAKKKKACiiigDmNe/15/wCurf8AoEdY9bGvf68/9dW/9AjrHoAv/DD/ AJEK1/6+73/0
qlrcbw9p7SSOBdKXdnYJeTKNzEknAbAySTxWH8MP+RCtf+vu9/8ASqWuwoAp 2Wl2mnySyW6y
75Qqu0kzyEhc4GWJx94/nVyiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA5DUb 631DfNayeZGt
3NCTtIw8e2Nxz6MrD3xxxWfRb2Nxp9jcQ3UflyNqt/MBuBykkxkQ8eqsp9s8 80UAX/hh/wAi
Fa/9fd7/AOlUtdhXH/DD/kQrX/r7vf8A0qlrsKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
oA5jXv8AXn/rq3/oEdY9bGvf68/9dW/9AjrHoAv/AAw/5EK1/wCvu9/9Kpa7 CuP+GH/IhWv/
AF93v/pVLXYUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB/9k=
name="moz-screenshot-1.jpg"
Content-ID: <part2.04070100.04050306@ca.ibm.com>
filename="moz-screenshot-1.jpg"
CAJZAXMDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDrZfFk8d3JbpYwuyuUGI0y cHHTZTJPGFxE
22TT4kb0aNAf/QKradMlrqeo3R27o5DgkqMAsc/eIHp3rm9cktrieSU6gkZY 5wJLfj85hXTR
oe0V2wk1FHV/8JnL/wA+MH/fCf8AxFL/AMJlL/z4wf8AfCf/ABFZ3w/OfEem nzPM4kw+VO75
G5+VmH5E10d/YWt34ftlsX2Wmo6ujxZXmIMhUgrwOGDDA4wBzXNL3ZOILVXM 3/hMpf8Anxg/
74T/AOIpf+Exl/58YP8AvhP/AIipx4b0d9Sht1u7hU+1vayHkjIUlfnMaqGy ANvzZyMGmap4
XsdO0We8F8sk0Qji2pKpHn5/eLjHYYIHXg5pXAj/AOEwl/58oP8AvhP/AIij /hMJf+fKD/vh
P/iKfp1x9m8Es/2y6tM6jjfbDLH92OD8y8fj2FXtBsYtb8KzWt1cMk8+oM0c rAufMCBiTzzl
Q3U/rRcDP/4S+X/nyg/74T/4il/4S6X/AJ8oP++E/wDiK6Cd7ePV5HtJHjtl 8PkxPHncqbuC
MkHIGOpFcJfXL3VyXa7uLoABVkuPvY9MZOOSe9CdxPQ2/wDhLpf+fKD/AL4T /wCJpf8AhLZf
+fOD/vhP/ia0fEeqxWuq6tbyzXVx5sAiS2dR5MbFVIcHceR1+71796pX2g6f ZXGrHNy8OnrC
NnmKGkaQjndtwAAemD9aLg7kf/CWy/8APnB/37T/AOJpf+Esl/584P8Av2n/ AMTWj/wisXm/
YPt1z5P9oeXtyNu3yfMzjpux8u79O1UE0LTplFxDPcNAtrNO6gH5ihAwsjIo OcjPynGD60XF
qN/4SuX/AJ84P+/af/E0v/CVy/8APnB/37T/AOJp0VnZJoWrzC0uAPJt3i+0 KA6FmIyrY5XP
cAZHHHWucFMTbR0X/CVS/wDPpB/37T/4mj/hKZf+fSD/AL9p/wDE1zwpaBcz Og/4SmX/AJ9I
P+/af/E0v/CUS/8APpB/37T/AOJrn6UUC5mb/wDwlEv/AD6Qf9+0/wDiaX/h J5f+fWD/AL9p
/wDE1gUtAczN/wD4SaX/AJ9YP+/af/E0f8JLL/z6wf8AftP/AImsIUtAudm7 /wAJLL/z6wf9
+0/+Jo/4SSX/AJ9YP+/af/E1hCnCgXPI3P8AhI5f+faD/v0n/wATR/wkcv8A z7Qf9+k/+JrE
oFAc8jc/4SKX/n2g/wC/Sf8AxNH/AAkUv/PtB/36T/4msUUtAueRtf8ACQy/ 8+0H/fpP/iaP
+Egl/wCfaD/v0n/xNY1LQHtJGz/wkEv/AD7wf9+k/wDiaP7fl/594P8Av0n/ AMTWPS0C9pI2
P7el/wCfeD/v0n/xNL/b0v8Az7wf9+k/+JrHpaBe0l3Nf+3Zf+feD/v0n/xN L/bsv/PCD/v0
n/xNZApaA9pLua39uS/88IP+/Sf/ABNL/bcv/PCD/vyn/wATWUKUUC9rLuan 9ty/88IP+/Kf
/E0v9tS/88IP+/Kf/E1lU4UB7Wfc0/7Zl/54wf8AflP/AIml/tmX/njB/wB+ U/8AiazKWgXt
Z9zS/tiX/njB/wB+U/8AiaX+15f+eMH/AH5T/wCJrNFLQHtZ9zR/teX/AJ4w f9+U/wDiaKz6
KBe1n3KMmga215PPBp0rxSsxHygq6k5rAuvhne3d0Z30q6VSc+UrfJ/j+te6 2H/IPtv+uS/y
FWKuNScPhdjteu541a+GfEFk8b2thdQNGMI0Z2lRjHBB9Kf/AMI74i+z/Z/s N15O/f5efl3Y
xnGcZx3r2KioA8jm0fxVcSRSTQ38jxHdGzyElD6gk8dB+VMfQfEksbRyWl46 NIZWVmyC56sR
nr716/RQB5JbaR4ps4zHbQ38CE7ischUE+uAaY+heJJY2jktLx0aQysrMSC5 6sRnr7169RQB
5J/Yvib/AJ973/VeT98/6v8Audfu+3Sof+EY1v8A6Bs/5V7DRQKx5FN4f8QX ErSz2V1LI3V3
O4nt1JqZdK8TpcvcrDfidxtaUOdzDjgnOew/KvV6KAseXfYPEn2D7L9gn/4+ ftXnc+Z5mMZz
n8fXNRtpXiZ7lblob8zoMLKXO5RzwDnPc/nXqtFAWPKDo/iRpZZWt70ySrsk cscuvoTnkcDi
oR4b1n/oHT/98167RQLlPI/+Ec1n/oHT/wDfNL/wjmsf9A6f/vmvW6KA5UeS /wDCOax/0Dp/
++aX/hHdY/6B8/8A3zXrNFAciPJv+Ed1j/oHz/8AfNL/AMI9q/8A0D5/++a9 YooFyI8o/wCE
e1f/AKB8/wD3zS/8I/q//QPn/wC+a9WooDkR5T/wj+rf9A+f/vml/sDVv+gf P/3zXqtFAezR
5X/YGrf8+E//AHzS/wBgat/z4T/9816nRQL2aPLf7B1X/nwn/wC+aX+wdV/5 8J/++a9RooD2
aPLv7C1X/nwn/wC+aX+wtV/58J/++a9QooD2SPMP7D1T/nwn/wC+KX+w9U/5 8J/++K9OooD2
SPMf7E1T/nxn/wC+KX+xNT/58Z/++K9NooF7KJ5n/Yup/wDPjP8A98Gl/sXU /wDnxn/74Nel
0UB7GJ5r/Y2pf8+M/wD3waX+xtS/58Z/++DXpNFAexiebf2NqX/PjP8A98Gl /sfUv+fKf/vg
16RRQL2MTzj+x9R/58p/++DS/wBkaj/z5T/98GvRqKA9hE85/sjUf+fKf/vg 0v8AZOo/8+U/
/fBr0WigPYRPO/7J1D/nyn/74NFeiUUB7CJw/wAQ9b1Hw58KLzVtJuPs99BF b+XLsV9u6SNT
wwIPBI5FY/jTxH4it/H76DpOrfYYZtKtJI3+zRy+VNLqEcBkww+b5HI2k4+h 5rtNU0Cx8U+D
30XUlkNpdW6K/lttZSMMrA+oYA85HHII4rPHgGym1dtW1DU9S1DUNlvGlxOY lKRwzrcBAsca
rguq5JBOBgEUGx53rfxK8RS/DieXT7v7D4h0HbHrj+XHLtmEwgEeCuw+YS8u 5MhfL2/xA16B
4A1vUdb/AOEo/tG4877D4gu7K3+RV2Qpt2rwBnGTycn3rQ8Q+DtL8R6Hq2k3 PnwQ6rLHNdSQ
Ph2dPLAI3AgcRIOnb1Oar6V4LXRNRvbnTte1WGG+1CTULi0xbtG8jkFhkxFw pAAwGBx3zzQB
n/EfU9W0v/hGf7K1Wex+363Bp9x5UUT7o5c5P7xGww28EccnIPGM8/FC8+2T KNBgNqPED+Ho
pDfne1wAdjMvlYWMnbkhiVySFbGD1HijwnB4q/s37RqN9Z/2ddrew/ZPK5mX 7jHejZ288dDk
5B4xn/8ACuNH/wCfm+/5GD/hIfvp/wAfH937v+r9uv8AtUAY9t8U7i71iw0a 38PeZqVxqF/p
sqC9AjiltlVtwcoC0ZDgk7QwAbCscAyWvxOmv7+z0e10SM61Pqd7pzxS3hW3 RrVA7sJRGWII
ZMfuxyTnGATT1D4cXVr470O/0S5vobVtQ1LUL+8V4C9tJcRIAEV1IKkpjG1i Mnnoa3IvhppV
s9rdWt/qUGqW97c3w1JXjMryzrtlLKyGLBAUYCDG0YxzkAxx8V7uW/tdLtPD El3qkt7qGnyW
8V8iqJrVFb5HdVDIwcZJCkYPytgA2LfxL4rm+K9ro0tnaQWcmhRXs9i90CYX MoWRt6xEs6ks
gQHawAbcCcDU034caPpmsafq0dzfS31nd3d60sjp/pE1yoWRpAFAHAAAQKBj oea1LzwvbXPi
q18Rw3d3aahDb/ZJGhKFZ4N4fy3Dq2BuB5Xa3J56YANyiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
CvYf8g+2/wCuS/yFR6lq2m6NbrcapqFpYwM4RZLqZYlLYJwCxAzgE49jUlh/ yD7b/rkv8hXP
65f2ekeMtH1HUruCysRp97Abm5kEcYkaS2ZU3NgbiEcgdSFb0NAHQW1/Z3m3 7LdwT7oknHlS
BsxvnY/H8LbWwehwcdKsV5nqN80GpeJNd8PXsdvaWehRX6pFbLtu3WW9fksO YnYOSygF9wZX
A5aS98U6zbz3j2F59t1dJb9G0HykfyIoknMEuxAJhvMdvyzFW8/5QNyYAPSK K83uPEs0NnqH
2LxX9u0yH7Ow1YG2J3sZfMgWYILdGCpER5i8mUKWXzEZT/hI/EEni+C2OpWM Mfm2qR2c26CS
7ieONpJVtWhebgvKAfNVUMfzjEblgD0iiuH8X69e6ZqN5HFqn2GS309bjTLX bH/xNLomXMGH
Us+NkI2xFW/e9csuOb1bWtQ1XRtcsLXWpNVv7l9Xsp9HjSF2tYUW5EThI0Eo JMcCZckHzcYy
ykAHrEc8MzzJFLG7wvslVWBKNtDYb0O1lOD2IPepK83bxLM2qz2l14r+w6Kk pEWsZtl8wi1s
3jTzHQxHzPOnk4XJ2/KQqkUaZ4g8S3Fq+rX939naHUNNtX0z7KqKpuIrTzlc tl/ladyoBBVg
dxcYUAHpFFcn4U11rtNQa/1eO5EVwkW9oliRJHbAjU8FTkovkSDzY2yGZwyM ZNa1a4tPFuk2
aal5EU+ALUQBjMSx3EgjdIoUHJiYGIlXkDxt8oB1FFeR2HjHWJPDFpdad4gj 1m4uNMin1CSQ
wBdMlaS3VstFHiIBJbhv3qvjyM4IVwdCz8Sag9vaR6t4qtLLTXe4261azQus jIIdkRnkgWFy
fMn+5GP9UBnKSZAPRPt9n5/kfa4PO83yPL8wbvM2eZsx/e2fNjrt56VYryua +1/VfFN4bG9k
OpWmmX62KrbLAHdrXTnVWSUEoPNlL4Y5BwCcAg9Rb69qV54X8Q69psUl3EUe 40RHt2Uzxi2Q
qNmFchpRJjOCQRjgqaAOsorzdNc1K61qy0vRvFP9oafcXcUbaqI7eY5aC7eW FWjVY9yiGFxw
SpcFtykKc+98WeJRcLDFqlja/Z/Oit3u5ViOoSx3U8O3yxBI0zbYYiyQ+W2Z ePvoFAPWKK5f
xTqhsdR0+3uNb/sLTZopnk1DMK/vVMYji3TKyDcrytjG4+XwcBsx+B9U1fWI 9SutYeSOdXtU
+xGIRrbMbOCWQAEb875WyGY4wBxzkA6yivL9G8Q68LHS7q51me6Z7TR7qVJY YQshvpjDIp2I
pCoF3Jgg7idxcYAjTxRrFzZ2K2+vSPd3qWv9pJHHAzaRPJdW0ZgC7PkJWacb Zt7fuuuVbIB6
pVd7+zjiupZLuBI7TP2l2kAEOFDnef4flIbnsQelcPo2v67d+OZLS5v7EQ/a 7mGTTfPDTRQI
XEcvkrCHj3BY23vKUIk4ALoBX8Q39na6b8QdKuLuCHUtT8z7BZySBZrvdYQx r5SHl8urINoO
WUjqKAO0m8S6DbaoNLn1vTYtQLqgtHukWUs2No2E5ycjAxzkVoRzwzPMkUsb vC+yVVYEo20N
hvQ7WU4PYg968312PUjY/EaVLu0XS0dzdWzWzGeVRp8G8JL5gVCV4BMb4PJD dKuahqMumDxZ
cR6h9gX+24RJMNinb9itiQskgMUbHGAZBtJwmVLhlAPQKKp6feLc28KPcRyX f2eOaVBE0LAO
DhjExLxglWwG5G0jJINeZ+H9T1bS/DVqq6rP9m0fRNLmuoXii/cr9okF2Gwm 7dHFA8e37w2k
YL80AesUVw+tNqN74AM99LPbSHVYrgTmNUe3tV1BXSRlZcLsgCsd6/LtO8ZD Uadr17P4ogtm
1TzbqTULq3u9I2x/6JaoJvKn2hfNXf5cHzOxU+dwBuTAB2kc8MzzJFLG7wvs lVWBKNtDYb0O
1lOD2IPepK83uNUNj4s1y3uNb/sLTZtQd5NQzCv71bSxEcW6ZWQbleVsY3Hy +DgNmvN411ld
R0F7ieDT7qb+z4bvSrqdIXmecxiR4oGiMrKvmld3mrhomBU7DuAPTDPCtwlu 0sYndGdIyw3M
qkBiB1IBZQT23D1oM8K3CW7Sxid0Z0jLDcyqQGIHUgFlBPbcPWvO/CuqHVvG Wj3Fzrf2zUn0
S6e90/MI/s6VpLUtFtRQ6YbcuJCzDZ1yDmvpFjezeKbe0g1eeym83XXl2xRt LAjXsDqiBlIX
cGjky6vlZDjAZSoB6hRXlek+MPEeratpUst7ptoLlLJ109ptrXMUsMTyyJB5 LyuAZJQHEqov
lfMMI5aTRvEOvCx0u6udZnume00e6lSWGELIb6YwyKdiKQqBdyYIO4ncXGAA D1CisfXNWS18
OXt7azb9m6ETQyLiF9/ls7MQyqsbZLsVbaEYlTjFcP4c1/XvEWsR6SviKAQR faxJe2DQ3TTB
Fs3UrL5Sx7gbh1J8rG3K4LAOAD0yaeG2QPPLHEhdUDOwUFmYKo57liAB3JAq SvI5fE0+vWGl
TaprMdjdz3ujS2+kR+Ui3aO9rK0oVwZWAkeUZVgP3WDkhs9Z4h1mW08Qtaza 9/Y8MdpFNZDy
Uk+3zs8geLYyl5doSL5Iir/vcZyy4AOshnhuULwSxyoHZCyMGAZWKsOO4YEE diCKkry+PUtd
0HR5b3TpvtjXOq6xBb6d9nDJuRryZTx87SGSILwwXa2Nu756sP4lmSc29t4r +1aEZYBP4gzb
N9lLJcFk8xUEIw0VsPmUkefjOWTAB6RRXn9l4j1GW/0RJtWwk8ssUSC2Um9j E7okxGB5qtEi
uWhKiMusjK0T/IeAtf13V9RI1O/sZt9p51zZwziWSxnyv7plWFPIxlwUleRy U4J2OSAegUV5
/H4qvW+I9tp6X0Atbm7ltH02e6j+0QiOGRvNEAiDqrNEGVmlcFJAdo3DbHqO oT6NeeLWS/ks
5bvU7bypJZYoIbZPssX795Hik2o7RPEGKsC6hQFO40AeiUVz/grVrjW/Ctte 3U0E83mzwmaC
QOkojmeNXDAKG3BAdwVQc5CqDgFAGxYf8g+2/wCuS/yFR6lq2m6NbrcapqFp YwM4RZLqZYlL
YJwCxAzgE49jUlh/yD7b/rkv8hXN+K7q40nWdL1e0tZLyeO3uLX7OLe5ZSsj QsXLwQylSDEA
FKjduJz8uCAbia7o8l5a2ceq2L3V3EJ7aFbhC80ZBIdFzllwCcjjg0Q67o9x Fcyw6rYyR2sS
z3DpcIRFGy71diD8qlfmBPBHPSuD8O+AdQsodL+2QxkbLCe4D6lcKLeWCGBC n2eM+VKd0AIk
LcFh8rBAGsSfDy5Ph3w9psT2kJ0vTBDKsEjwiWcT2sx2ugDKHa3fMg+YFw2C cigDtLfXdHu/
sf2bVbGb7dv+yeXcI32jZ9/Zg/Nt74zjvVM+L9BYae9vqdpdQX179gjntp0e NZjG0gVmDYBI
XAHJJZRjmsPTfB+p2l497DPBp91NaXkZkFzNfPFNKLZY3Lz8y4Fvk5CAfKuD gsa+l+DdWt/E
cesTJBD5MtsyQPq1xfFwqXUbkyzIGXC3W4KAQSmPl3FgAdY3iXQVS9dtb00J YOEvGN0mLdix
UCTn5CWBGDjkYoFzovh429g95aWT3txK8EM1wFaeWSQu+wMcsS8nQdNwA7Cu Tj8F6w9tolrM
9ikehxW1rbyJM7G6jjubWRnZSg8tttrwoLgl8bgFydjxZ4bvNe+0fZZIE8zR NQ08eaxH7yfy
dh4B+UeW2T15GAaANSTxLoMOlw6pLrempp8z7IrtrpBE7c8K+cE/K3APY+lV 9d8U6boc1raS
3Vo2oXNxbxRWTXKpK6yzLFvVepC5ZuBztIyOoy38PaxY+Kr3X7BLG5kmllCW 09w8I8uSG0Us
XEb4YNan5dpBD53AjBz7TwXrGk6db6NZvY3VibvTrma7mmeGRPswtlZViCMG 3C2BBLjl8fw5
IB0Go+ItH2+ZbS2OpXVjqFtbSRRzIz2sk0ot9xxkowEj8cE4YcZNalzq2m2d xHb3WoWkE8jx
okcsyqzM5YIACcksUcAd9px0NcHpvw9vrO2sbcmDdp32SKK4k1K5uDNHFcwS uRG/yW+Vtx8i
hhkqNyhfm3Nf8KTatceJLiIWgn1HQhpdrJJndG2Zy2TgkITJEeM52dOBQBqW eoeH9IiOiW+o
2MH9lWil7VrpS9tAijDOCdwUKV+ZvUHPNWLHXdH1OWOKw1Wxu5JIjOiQXCSF owxQuADyoYFc
9MjHWuH8S+B9f1y5uR58Eiv9s2XM2pTgbZbaeKNPsoQxJs81FLqdxCFjy5Fa Gu+CLzWzqcX2
qCGG+1CW434LMkb6YbT7uBlg53YyBt754oA6SO60jxTpcy2Opx3doX2PNp18 VKsMNjzImBU9
MgEcHng1oQQQ2tvFb28UcMESBI441CqigYAAHAAHGK5/wvoVxpdxe3l3BHDP cpFFtGp3N+xV
C5GZZ8EDMhwoUY5OW3YXpKACiiigAooooAKKKKACiiigAooooAjjghheZ4oo 0eZ98rKoBdto
XLep2qoyewA7VX1LS7TVrdbe9SSSAOGaNZXRZOCNrhSA6EEgo2VPcGrlFABR RRQAUUUUAFFF
FABRRRQBHBBDa28VvbxRwwRIEjjjUKqKBgAAcAAcYqSiigAooooAKKKKACii igAooooAKKKK
AK9h/wAg+2/65L/IVYrh1uWVQMzcDHF3Oo/IOAPwpftTes//AIG3H/xygDt6 K4j7U3rP/wCB
tx/8co+1N6z/APgbcf8AxygDt6K4j7U3rP8A+Btx/wDHKPtTes//AIG3H/xy gDt6K4j7U3rP
/wCBtx/8co+1N6z/APgbcf8AxygDt6K4j7U3rP8A+Btx/wDHKPtTes//AIG3 H/xygDt6K4j7
U3rP/wCBtx/8co+1N6z/APgbcf8AxygDt6K4j7U3rP8A+Btx/wDHKPtTes// AIG3H/xygDt6
K4j7U3rP/wCBtx/8co+1N6z/APgbcf8AxygDt6K4j7U3rP8A+Btx/wDHKPtT es//AIG3H/xy
gDt6K4j7U3rP/wCBtx/8co+1N6z/APgbcf8AxygDt6K4j7U3rP8A+Btx/wDH KPtTes//AIG3
H/xygDt6K4j7U3rP/wCBtx/8co+1N6z/APgbcf8AxygDt6K4j7U3rP8A+Btx /wDHKPtTes//
AIG3H/xygDt6K4j7U3rP/wCBtx/8co+1N6z/APgbcf8AxygDt6K4j7U3rP8A +Btx/wDHKPtT
es//AIG3H/xygDt6K4j7U3rP/wCBtx/8co+1N6z/APgbcf8AxygDt6K4j7U3 rP8A+Btx/wDH
KPtTes//AIG3H/xygDt6K4j7U3rP/wCBtx/8co+1N6z/APgbcf8AxygDt6K4 j7U3rP8A+Btx
/wDHKPtTes//AIG3H/xygDt6K4j7U3rP/wCBtx/8co+1N6z/APgbcf8AxygD t6K4j7U3rP8A
+Btx/wDHKPtTes//AIG3H/xygDt6K4j7U3rP/wCBtx/8co+1N6z/APgbcf8A xygDt6K4j7U3
rP8A+Btx/wDHKPtTes//AIG3H/xygDt6K4j7U3rP/wCBtx/8cooAr0UUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUVNFB5sbyN
LHGqkKS+eSc+gPoaAIaKsfZ4v+fyD8n/APiaPs8X/P5B+T//ABNAFeirH2eL /n8g/J//AImj
7PF/z+Qfk/8A8TQBXoqx9ni/5/IPyf8A+Jo+zxf8/kH5P/8AE0AV6KsfZ4v+ fyD8n/8AiaPs
8X/P5B+T/wDxNAFeirH2eL/n8g/J/wD4mj7PF/z+Qfk//wATQBXoqx9ni/5/ IPyf/wCJo+zx
f8/kH5P/APE0AV6KsfZ4v+fyD8n/APiazxfW76vc6bFJ5kttFFLIyqQuJC4A GcHPyEnjHI56
4ALFFWTaKm3fdQoxUNtIfIBGR0X3ooArVm3esw2evabpUow9/HM0T5P3o9p2 4x3VmOSR93He
tKsTWtDk1a+hmSZIRFazIkhBZo5jJDJE4XowVoskE88DkE0APs/Elhcx6rPJ PFb2unXhtHnm
k2KWCpnJbGPmcr74yDzRrXiXTdG0Z9QkvLRt1u89tG1wq/adq7gEPfOR0z1F UI/Dc+ntv05b
fbbXyXFrbySsqmMWi221nwxBHJzhs4A7kinceGdWTTtUhtfsUsuq2ssMwlne Nbdnknk+UhG8
wD7QRyF+4D/FhQDe1PX7LT7XUjHcW895YWr3MlmsyiTaq7uRyVByOcdxVmS/ 8vWbbT/Lz59v
NP5m77vltGuMd8+Z+nvXK3ng27uI9RgTyiJftkkE8t7OQHnWQAeR/q0x5pG8 biQD8oLfL0Op
Wl7/AGnaajYR280sEMsBhnlaJSsjRtu3BW5HlgYxzu6jGCAUx4gvbm4t7ew0 63klla8B8+6a
NVW3mEWciNsltwOMDHqas2Gu/bbu1tjbeW8sd0ZDvyEeCVImA4+YFmJB4OAO BnAoReFI57iy
fVLayu4olvJJIpUEirLPMko27hyFw67uCeOBkgPt/D1zG0Su1o0Mdvf26xyI ZEVJpkaJNnAK
KiBSuQMAAcc0AbdtqNlepE9reW86zKzxmKVWDqpAYjB5AJAPoSKs1laLaXtl CUuo7fMjM7sk
rSOMbVQM5UGU7Rje2CAqg7jljq0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFFFFABVhP+QfN/11j/k9V6sJ/wAg+b/rrH/J6AON13xJc6ZrNxaxXWnp 5NnHcRWkyEz3
rs0g8qI7xgny1AwrHLjg9K2Jte0+CW5ieSUyW0ixOiW8jkuy7wqAKd52/MQu SBycCqeq6Bc6
je3rR30UNrf2aWdzG1uXcoDJko+8BSRKRyrAEA4PSnz6DI1zPd292kdy18L2 EyQl0Rvs4gKs
oYFht3HgryR1xyAWU1/TJFytznHlZHlsCplkMSAjGQd6spB5Ug5xQuv6Y06Q i5y7yNF/q2wr
B2jwxxhcurKu7G4ghc1mr4NsnkVrt/PDxzi5XBQSvI0hyMNlQBPcKBycSDJJ UGprfw9NbSac
66h81vuadxCA0sjsXkKnPyiRiSykMvC7QhUNQBfstZsNRmMVtK7Nt3qWidFl XIG6NmAEi8j5
lJHzLzyM4Nr4jnnOpyya3o8S2TXZktRbNJNDHE7oHYCXJHCscKM5wMZBq54f 8KwaBMGhWyCx
w+RG0FksUrrkcyyZJdvlHI2gkkkHjbZfQt/hzUdI+04+2/av3uz7nnu7dM87 d+OozjtQBDa+
J7UQOb6TZItxcI3lQuyxRpPJGryEAiMEIfmYgcN2Bw/XtWk06a1iF5ZafFMr s17fKWiVlK4j
xvT5m3MR83SNuD1GbP4GgmuHmZ7KZpWk8xrqwWdkVppZR5W44Rh5zAkhgdqn bwQehv4b+Xy2
0+9it3XIZZ7fzUYHHOAykEY4O7GCcg8EADG1a3tz5N46RXKrAZY03OqtM5jQ BtoyC4IzgdMk
Cqb+KLBrixiti84uboW+VRwQGjkdZFG354z5ZAcfLjJ3YU1Tg8OhNTs7dIri PTrC1hhd5HQ/
a2hZWg6ZICHzCeEySv3l4qzb+HpoZYpX1DzHhvPtUQEIVOVZHLKD99lkYkrt Xdhtg+YMATN4
o0hYnlM8uxdu0i2lPnBmVAYvl/egsyDKbh8y+ozZstZsNRmMNtK5kC7trxPH kAgNjcBkqSFY
DlScNg8Vg2PgaCxjjiheyiWFoPLeCwWOV1jljk/evkl2PlgZG0ZJJU8AaVro MlneQXMV2haJ
rskPCSCs9wszD7wwQFKg+pzjjBANuuf07/kede/69LP+c1bUa3IkUySxMnz5 CxEE5b5Odx6L
kHjk8jb0rF07/kede/69LP8AnNQB1F5/r1/65R/+gLRRef69f+uUf/oC0UAV 6KKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKp6k
mqzW6w6Zf21mC4eRprUzFsAgAfOuOpz1zx073KKAOf8A7O8U/wDQxWP/AIKz /wDHaP7O8U/9
DFY/+Cs//Ha6CigDn/7O8U/9DFY/+Cs//HaP7O8U/wDQxWP/AIKz/wDHa6Ci gDn/AOzvFP8A
0MVj/wCCs/8Ax2j+zvFP/QxWP/grP/x2ugooA5/+zvFP/QxWP/grP/x2j+zv FP8A0MVj/wCC
s/8Ax2ugooA5/wDs7xT/ANDFY/8AgrP/AMdo/s7xT/0MVj/4Kz/8droKKAOf /s7xT/0MVj/4
Kz/8do/s7xT/ANDFY/8AgrP/AMdroKKAOf8A7O8U/wDQxWP/AIKz/wDHam0f R72x1K+v7/UI
rue6jij/AHVsYQojL443tnO/26VtUUAY99a+Jbm8klh1yxgiOFjj/s0sVUAA AnzeTgDJ457D
pRWxRQAVm6n4g0jRpI49S1CC1aQbkErbdw9q0qr6F/yVO2/7Alz/AOj4KAMf /hOfC3/Qesf+
/oo/4Tnwt/0HrH/v6K9fooA8g/4Tnwt/0HrH/v6KP+E58Lf9B6x/7+ivX6KA PIP+E58Lf9B6
x/7+ij/hOfC3/Qesf+/or1+igDyD/hOfC3/Qesf+/oo/4Tnwt/0HrH/v6K9f ooA8g/4Tnwt/
0HrH/v6KP+E58Lf9B6x/7+ivX6KAPIP+E58Lf9B6x/7+ij/hOfC3/Qesf+/o r1+igDyD/hOf
C3/Qesf+/oo/4Tnwt/0HrH/v6K9fooA8g/4Tnwt/0HrH/v6KP+E58Lf9B6x/ 7+ivX6KAPIP+
E58Lf9B6x/7+ij/hOfC3/Qesf+/or1+igDyD/hOfC3/Qesf+/oo/4Tnwt/0H rH/v6K9fooA8
g/4Tnwt/0HrH/v6KP+E58Lf9B6x/7+ivX6KAPIP+E58Lf9B6x/7+ij/hOfC3 /Qesf+/or1+i
gDyD/hOfC3/Qesf+/oo/4Tnwt/0HrH/v6K9fooA8g/4Tnwt/0HrH/v6KP+E5 8Lf9B6x/7+iv
X6KAPIP+E58Lf9B6x/7+ij/hOfC3/Qesf+/or1+igDyD/hOfC3/Qesf+/oo/ 4Tnwt/0HrH/v
6K9fooA8g/4Tnwt/0HrH/v6KP+E58Lf9B6x/7+ivX6KAPIP+E58Lf9B6x/7+ ij/hOfC3/Qes
f+/or1+igDyD/hOfC3/Qesf+/oo/4Tnwt/0HrH/v6K9fooA8g/4Tnwt/0HrH /v6KP+E58Lf9
B6x/7+ivX6KAPIP+E58Lf9B6x/7+ij/hOfC3/Qesf+/or1+igDyD/hOfC3/Q esf+/oo/4Tnw
t/0HrH/v6K9fooA8g/4Tnwt/0HrH/v6KK9fooA4Cq+i/uviXBcSfJAujzo0j cKGM0JAJ6ZIV
iB7H0qxUsdzPCu2KeRFJzhXIGaAOy+32f/P3B/38FH2+z/5+4P8Av4K5D7fe f8/c/wD38NH2
+8/5+5/+/hoA6/7fZ/8AP3B/38FH2+z/AOfuD/v4K5D7fef8/c//AH8NH2+8 /wCfuf8A7+Gg
Dr/t9n/z9wf9/BR9vs/+fuD/AL+CuQ+33n/P3P8A9/DR9vvP+fuf/v4aAOv+ 32f/AD9wf9/B
R9vs/wDn7g/7+CuQ+33n/P3P/wB/DR9vvP8An7n/AO/hoA6/7fZ/8/cH/fwU fb7P/n7g/wC/
grkPt95/z9z/APfw0fb7z/n7n/7+GgDr/t9n/wA/cH/fwUfb7P8A5+4P+/gr kPt95/z9z/8A
fw0fb7z/AJ+5/wDv4aAOv+32f/P3B/38FH2+z/5+4P8Av4K5D7fef8/c/wD3 8NH2+8/5+5/+
/hoA6/7fZ/8AP3B/38FH2+z/AOfuD/v4K5D7fef8/c//AH8NH2+8/wCfuf8A 7+GgDr/t9n/z
9wf9/BR9vs/+fuD/AL+CuQ+33n/P3P8A9/DR9vvP+fuf/v4aAOv+32f/AD9w f9/BR9vs/wDn
7g/7+CuQ+33n/P3P/wB/DR9vvP8An7n/AO/hoA6/7fZ/8/cH/fwUfb7P/n7g /wC/grkPt95/
z9z/APfw0fb7z/n7n/7+GgDr/t9n/wA/cH/fwUfb7P8A5+4P+/grkPt95/z9 z/8Afw0fb7z/
AJ+5/wDv4aAOv+32f/P3B/38FH2+z/5+4P8Av4K5D7fef8/c/wD38NH2+8/5 +5/+/hoA6/7f
Z/8AP3B/38FH2+z/AOfuD/v4K5D7fef8/c//AH8NH2+8/wCfuf8A7+GgDr/t 9n/z9wf9/BR9
vs/+fuD/AL+CuQ+33n/P3P8A9/DR9vvP+fuf/v4aAOv+32f/AD9wf9/BR9vs /wDn7g/7+CuQ
+33n/P3P/wB/DR9vvP8An7n/AO/hoA6/7fZ/8/cH/fwUfb7P/n7g/wC/grkP t95/z9z/APfw
0fb7z/n7n/7+GgDr/t9n/wA/cH/fwUfb7P8A5+4P+/grkPt95/z9z/8Afw0f b7z/AJ+5/wDv
4aAOv+32f/P3B/38FH2+z/5+4P8Av4K5D7fef8/c/wD38NH2+8/5+5/+/hoA 6/7fZ/8AP3B/
38FH2+z/AOfuD/v4K5D7fef8/c//AH8NH2+8/wCfuf8A7+GgDr/t9n/z9wf9 /BR9vs/+fuD/
AL+CuQ+33n/P3P8A9/DR9vvP+fuf/v4aAOv+32f/AD9wf9/BR9vs/wDn7g/7 +CuQ+33n/P3P
/wB/DR9vvP8An7n/AO/hoA6/7fZ/8/cH/fwUVyH2+8/5+5/+/hooAr0VFqWp WOi6XFe3sNzK
JJjEBCyjGFB7j61jf8J5oH/PjqX/AH3H/hVqEmrpGFTFUacuWcrM3qKwf+E7 0D/nx1L/AL7j
/wAKX/hO9B/58dS/77j/AMKfsp9jP69hv50btFYX/CdaD/z46l/33H/hR/wn Wg/8+Opf9/E/
wo9lPsH1/Dfzo3aKwv8AhOdB/wCfHUv+/if4Uv8AwnOg/wDPjqX/AH8T/Cj2 U+wfX8N/Ojco
rD/4TjQf+fHUv+/if4Uf8JxoX/PjqX/fxP8ACj2U+wvr+G/nRuUVif8ACb6F /wA+Oo/9/E/w
o/4TfQv+fHUf+/if4Ueyn2D6/hv50bdFYn/CbaF/z5aj/wB/E/wpf+E20L/n y1H/AL+J/hR7
GfYP7Qw386NqisX/AITbQv8Any1H/v4n+FH/AAmuh/8APlqP/fxP8KPYz7B/ aGF/nRtUVjf8
Jrof/PlqP/fxP8KP+E00P/ny1H/v4n+FHsZ9g/tDC/zo2aKxv+E00P8A58tR /wC/if4Uf8Jn
of8Az5aj/wB/E/wp+xqdg/tDC/zo2aKx/wDhM9D/AOfLUf8Av4n+FH/CZaH/ AM+Wof8AfxP8
KPY1Owv7Rwv86Niisf8A4TLRP+fLUP8Av4n+FL/wmOif8+Wof9/E/wAKPY1O wf2jhf50a9FZ
H/CY6J/z5ah/38T/AApf+Ew0T/ny1D/v4n+FHsanYP7Rwv8AOjWorJ/4TDRP +fLUP+/if4Uf
8Jfon/PlqH/fxP8ACj2NTsH9o4X+dGtRWT/wl+if8+Wof9/E/wAKX/hL9F/5 8tQ/7+J/hR7C
p2D+0sJ/OjVorK/4S7Rf+fPUP+/if4Uf8Jbov/Pnf/8AfxP8KPYVOwv7Swn/ AD8Rq0Vlf8Jb
ov8Az53/AP38T/Cl/wCEs0X/AJ87/wD7+J/hR7Cp2D+0sJ/z8RqUVl/8JZov /Pnf/wDfxP8A
Cl/4SzRv+fO//wC/if4Uewqdg/tPCf8APxGnRWZ/wlejf8+d/wD9/E/wo/4S vRv+fO//AO/i
f4Uewqdg/tPCf8/EadFZn/CVaN/z53//AH8T/Cl/4SrRv+fO/wD+/if4U/YV Owv7Twn/AD8R
pUVm/wDCU6N/z53/AP38T/Cj/hKdH/587/8A7+J/hR7Cp2D+08H/AM/EaVFZ 3/CUaP8A8+d9
/wB/E/wo/wCEo0f/AJ877/v4n+FHsKnYP7Uwf/PxGjRWd/wk+j/8+d9/38T/ AApf+En0f/nz
vv8Av4n+FH1er2D+1MH/AM/EaFFZ/wDwk+j/APPnff8AfxP8KKPq9X+UP7Uw f/PxFHx5/wAi
pZ/9fzf+gCn6hYWI8Q+J9GFhaLZWOktNbhbdA6OqRsG8wDeTknOSc55zS+Nb ae68L2aW8Mkz
i9YlY0LHGwc8Vy82oeKriKZJILktPEIZphZASyIMDa0gXewwozk845zWlNXi tTixsuWvK8W9
unk9PxRZk8GxiyDxaizXf9kjVjE1vtTy+Mrv3E7hzj5cH2qxdeA47S7jspNb theefbwyQnZk
+YQCUAcu23cPvKmRyKh1HV9fvLK2tLbS7m1jjsI7GVlt8vKq9fn2Bgp4yucf XJqBtU8WvtJj
u94eKRpBZgPI0f3C7bcvj/aJrS8u5xONBacj/H/Mbr3heLSbGW7tdR+2RQXz WM26AxEShd3y
8nI6gnjkcZBzXOitu5fxHeWk1rPbXbwzXTXki/ZcZmIwWyFz0PTp7VQ/sjUv +gdd/wDflv8A
Cri7LVnLWp3lenBpfMqUVc/snUv+gfd/9+W/wo/snUv+gfd/9+W/wquZdzH2 VT+V/cVKUVb/
ALJ1L/oH3f8A35b/AApf7J1L/oH3f/flv8KfMu4vZVP5X9xUpRVv+ydS/wCg fdf9+W/wo/sn
Uf8AoH3X/flv8KfMu4vZVP5X9xVoFW/7K1H/AKB91/35b/Cl/srUf+fC6/78 t/hRzLuL2NT+
V/cVKUVb/srUf+fC6/78t/hS/wBlaj/z4XX/AH5b/CjmXcXsan8r+4qUtWv7 K1H/AJ8Lr/vy
3+FL/Zeof8+F1/35b/CnzLuHsan8r+4q0Crf9l6h/wA+F1/35b/CgaXqH/Ph df8Aflv8KfMu
4vY1P5X9xVpRVr+y9Q/58br/AL8t/hS/2XqH/Pjc/wDflv8ACjmXcn2NT+V/ cVaWrP8AZmof
8+Nz/wB+W/wpf7M1D/nxuf8Av03+FHNHuHsan8r+4rUtWf7Mv/8Anxuf+/Tf 4Uv9mX//AD43
P/fpv8KfNHuL2NT+V/cVaUVZ/sy//wCfG5/79N/hS/2bf/8APlc/9+m/wo5o 9xexqfyv7itS
1Z/s2/8A+fK5/wC/Tf4Uv9m3/wDz5XP/AH6b/CnzR7i9jU/lf3Falqz/AGbf f8+Vz/36b/Cj
+zb7/nyuP+/Tf4U+aPcXsan8r+4rUoqz/Zt9/wA+Vx/36b/ClGnX3/Plcf8A fpv8KOaPcXsa
v8r+4rUtWP7Ovv8AnzuP+/Tf4Uv9nX3/AD53H/fpv8KOaPcXsKv8r+4r0tWP 7Ovf+fO4/wC/
Tf4Uv9n3v/Pncf8Afpv8KfNHuL2FX+V/cVhSirH9n3v/AD53H/fpv8KUafe/ 8+dx/wB+m/wp
88e5PsKv8r+4r0tWP7Pvf+fO4/79H/Cl/s+9/wCfS4/79n/Cjnj3F7Cr/K/u K9LU/wDZ97/z
6T/9+z/hS/YLz/n0n/79n/Cjnj3F7Cr/ACv7iuKUVYFhef8APpP/AN+z/hSi wvP+fSf/AL9m
nzx7i9hV/lf3FeirH2C8/wCfSf8A79mijnj3D2FX+V/cegP/AMg+H/rrJ/JK r1Yf/kHw/wDX
WT+SVXrwj9MCiiigAooooAKKKrPexx6nBYFX82aGSZSANoVGQHPv+8XH0NAF miiq19ex6fbr
NKrsrTRQgIATukkWNfwywz7UAWaKZM7RwySJE8rKpIjQgM5A6DJAyfcge9Po AKr/AG+z/wCf
uD/v4KsVn+CfDnhq48CxajqHh3Sry6kvLpGluLON3cm7kRdzFScDgd8AfhSl JRTk9kNK7six
9vs/+fuD/v4KPt9n/wA/cH/fwVbOheDYJBv8P+FrlckMsVjbxMv/AH2cH8wf r2s2GheAtRu3
tY/C2iLOgzsawgO4eoKgg/geKwp4qlUsovVlOnJamX9vs/8An7g/7+Cj7fZ/ 8/cH/fwV0/8A
wgng/wD6FTQ//BdD/wDE1XsPCXgfU9Otr+z8MaHJa3USTQv/AGbENyMAVOCu RkEda6CDA+32
f/P3B/38FH2+z/5+4P8Av4Kv2ukeA7zUY7K38IaU7yS3EaN/ZsAUrAQkr8jO 1ZGEfTcWOQCn
zVsf8IJ4P/6FTQ//AAXQ/wDxNAHMfb7P/n7g/wC/go+32f8Az9wf9/BXT/8A CCeD/wDoVND/
APBdD/8AE0f8IJ4P/wChU0P/AMF0P/xNAHMfb7P/AJ+4P+/go+32f/P3B/38 FdP/AMIJ4P8A
+hU0P/wXQ/8AxNH/AAgng/8A6FTQ/wDwXQ//ABNAHMfb7P8A5+4P+/go+32f /P3B/wB/BXT/
APCCeD/+hU0P/wAF0P8A8TR/wgng/wD6FTQ//BdD/wDE0Acx9vs/+fuD/v4K Pt9n/wA/cH/f
wV0//CCeD/8AoVND/wDBdD/8TR/wgng//oVND/8ABdD/APE0Acx9vs/+fuD/ AL+Cj7fZ/wDP
3B/38FdP/wAIJ4P/AOhU0P8A8F0P/wATR/wgng//AKFTQ/8AwXQ//E0Acx9v s/8An7g/7+Cj
7fZ/8/cH/fwV0/8Awgng/wD6FTQ//BdD/wDE0f8ACCeD/wDoVND/APBdD/8A E0Acx9vs/wDn
7g/7+Cj7fZ/8/cH/AH8FdP8A8IJ4P/6FTQ//AAXQ/wDxNH/CCeD/APoVND/8 F0P/AMTQBzH2
+z/5+4P+/go+32f/AD9wf9/BXT/8IJ4P/wChU0P/AMF0P/xNH/CCeD/+hU0P /wAF0P8A8TQB
zH2+z/5+4P8Av4KPt9n/AM/cH/fwV0//AAgng/8A6FTQ/wDwXQ//ABNH/CCe D/8AoVND/wDB
dD/8TQBzH2+z/wCfuD/v4KPt9n/z9wf9/BXT/wDCCeD/APoVND/8F0P/AMTR /wAIJ4P/AOhU
0P8A8F0P/wATQBzH2+z/AOfuD/v4KPt9n/z9wf8AfwV0/wDwgng//oVND/8A BdD/APE0f8IJ
4P8A+hU0P/wXQ/8AxNAHMfb7P/n7g/7+Cj7fZ/8AP3B/38FdP/wgng//AKFT Q/8AwXQ//E1X
vfAnhD7OAPC2iLmSNSVsIgcFwDyFoAwPt9n/AM/cH/fwVLFNFOrNDIkiqQGK MCATnGcfQ/lV
L/hG/C3/AEKWh/8AgIP8aqeEYILa38UQ2ttDbQJrShIYECIg+zpwAKANuiii gCw//IPh/wCu
sn8kqvVh/wDkHw/9dZP5JVegAooooAKKKKACsTVBeW+v6ff2+nXF7FHa3ELi B4gys7wlfvuv
HyN0rbooA5KfS7y51g3R0t1uZbq3uIL52i3WkCiPzICwYuCdkowgZT5vJ5bG avhvUmtrWGGy
eyuIlgS+ukaLdeTLcQObgHJ3lRHK2ZAG+foSzCu/ooA566067fwVqmkx2iLc m1ngj2P8twzI
cOCxJBYtk7znduyW+81CLw9JbeVcnTfPmfUL17td6M0ts/2grH8zY2MWiOzI G45IBya7CigA
qLwmJf8AhUgaBS0iXd1IABk/LeyMePwqWrmgS2/h7RotMtp5JIkeWTdLAMky SNI3Rxxljj2x
161FSCqQcH1VhxlytMjtvGeiWNtFax3vyxIEz5TjJHU9PWodL1M+IfHNtPbS M9nZxyPv2kDc
yhcc/wCeK2P7Wt/+eUX/AICD/wCLp6a3HFnywiZ67bbH/s9cdHAKnNS5m7dD WVW6aSIda0m4
uvFuk30Wm/aFhwPtBnAEA3EsRyHjbG0Ax7hKC0coC7XXkx4U1zSvB17pFhoc cs954cj0nEc8
UUaTRfaPMkYk5xIZtyYBJJ/eeXkkdr/wkH+3/wCS/wD9so/4SD/b/wDJf/7Z XeYmNoXhWWz8
SWeoXGmQJ5cuszvNhCwknuozE/HO5oVIz1CjacdK7isD/hIP9v8A8l//ALZR /wAJB/t/+S//
ANsoA36KwP8AhIP9v/yX/wDtlH/CQf7f/kv/APbKAN+isD/hIP8Ab/8AJf8A +2Uf8JB/t/8A
kv8A/bKAN+isD/hIP9v/AMl//tlH/CQf7f8A5L//AGygDforA/4SD/b/APJf /wC2Uf8ACQf7
f/kv/wDbKAN+isD/AISD/b/8l/8A7ZR/wkH+3/5L/wD2ygDforA/4SD/AG// ACX/APtlH/CQ
f7f/AJL/AP2ygDforA/4SD/b/wDJf/7ZR/wkH+3/AOS//wBsoA36KwP+Eg/2 /wDyX/8AtlH/
AAkH+3/5L/8A2ygDforA/wCEg/2//Jf/AO2Uf8JB/t/+S/8A9soA36KwP+Eg /wBv/wAl/wD7
ZR/wkH+3/wCS/wD9soA36KwP+Eg/2/8AyX/+2Uf8JB/t/wDkv/8AbKAN+q95 /qF/66x/+hrW
R/wkH+3/AOS//wBsqnqmotqemy2a39zZtJjFxbQKJEwQflLMwHTHTvxg80Ac hc+EtFu/EsGv
zWSNfwrgN/CzDG12HdlxgHtn2XD/AAt9zxV/2G1/9J0o/wCEWX/ocPEf/fFv /wDE1f0nSbTR
LC8ggvb29lu7oXMst2qBiwTZ/BgdAO3rQBZooooAsP8A8g+H/rrJ/JK5fXfE 50XUbeyTTZ7y
WaJpQIpEXAUgHO4j+8K6h/8AkHw/9dZP5JXn/ir/AJHLT/8AsHzf+jI6ALH/ AAm91/0LV9/3
/g/+Lo/4Te6/6Fq+/wC/8H/xdZ9FAGh/wm91/wBC1ff9/wCD/wCLo/4Te6/6 Fq+/7/wf/F1J
4dhiuPENlDPGskTyYZWGQRivUX8J6G/XToh9OKqytdivrY8q/wCE3uv+havv +/8AB/8AF0f8
Jvdf9C1ff9/4P/i69E1LwpoUFlNILQrtXkqxyB3xXlLkRXLQMWyMlCylSw/G q9nLl51sTzrm
5XuaX/Cb3X/QtX3/AH/g/wDi6P8AhN7r/oWr7/v/AAf/ABdZ9FZlmh/wm91/ 0LV9/wB/4P8A
4uj/AITe6/6Fq+/7/wAH/wAXWfRQB6HJG0RVWI3FEY46AlQcfrWFp+p69q9p 9s07wneXNqZJ
I1mW7t1DFHKNgNID95T1Arorz/Xr/wBco/8A0BaxfhzKLrwyLVra3uZI7y92 C5+6iC4YnHyn
kl/TnueAKwxFdUYqTXkXCHOx2fFf/QlX3/gdaf8Ax2jPiv8A6Eq+/wDA60/+ O11EsWt28IFp
eRx4dQqyziRACw4OYdxHb72fep4fFUMmg6fqCWdxPPfyGGC0g275JAHLAF2V RhY3bLMOF9SA
SjiYVXaO4Sg4q5yGfFf/AEJV9/4HWn/x2jPiv/oSr7/wOtP/AI7XXnxdZo7x zWd9DNH9kEkU
sQVka4uGt1H3ucOjZIypXBUsCKpp4+smmsw2malHb36RyWV0wi2XEbzQwq6g SF1GbiNsOqnB
PGRityDnM+K/+hKvv/A60/8AjtGfFf8A0JV9/wCB1p/8dro5fHOlTi0jgluw bi42I8Ajbhbm
CIZySNkguInBHJifcMErVzQPF1n4h+yGGzvrVb20+2WjXcQTz4xsDkAMSNpk QfMAG3AoWX5q
AOQz4r/6Eq+/8DrT/wCO0Z8V/wDQlX3/AIHWn/x2vT6KAPMM+K/+hKvv/A60 /wDjtGfFf/Ql
X3/gdaf/AB2vT6KAPMM+K/8AoSr7/wADrT/47RnxX/0JV9/4HWn/AMdr0+ig DzDPiv8A6Eq+
/wDA60/+O0Z8V/8AQlX3/gdaf/Ha9PooA8wz4r/6Eq+/8DrT/wCO0Z8V/wDQ lX3/AIHWn/x2
vT6KAPMM+K/+hKvv/A60/wDjtGfFf/QlX3/gdaf/AB2vT6KAPMM+K/8AoSr7 /wADrT/47Rnx
X/0JV9/4HWn/AMdr0+igDzDPiv8A6Eq+/wDA60/+O0Z8V/8AQlX3/gdaf/Ha 9PooA8wz4r/6
Eq+/8DrT/wCO0Z8V/wDQlX3/AIHWn/x2vT6KAPMM+K/+hKvv/A60/wDjtGfF f/QlX3/gdaf/
AB2vT6KAPMM+K/8AoSr7/wADrT/47RnxX/0JV9/4HWn/AMdr0+igDzDPiv8A 6Eq+/wDA60/+
O0Z8V/8AQlX3/gdaf/Ha9PooA8wz4r/6Eq+/8DrT/wCO0Z8V/wDQlX3/AIHW n/x2vT6KAPMM
+K/+hKvv/A60/wDjtFen0UAcQ/8AyD4f+usn8krz/wAVf8jlp/8A2D5v/Rkd egP/AMg+H/rr
J/JK8/8AFX/I5af/ANg+b/0ZHQBXooooA1PDbbfEmnn/AKbCvT7u+nikl/fl UVj6cD/vivK9
EbZrtgf+m6fzFeh30qrchjs/4+FyMj+935rpopcrbWxz1m7pJ7luI6jdswjd 8r94EqqqfQtt
OT7Acetcf4r0S4nkt7+6cR3KoyxqXU8dSCoAPbqM4+ldvp9066BEY/LMxi3L luGJGcn6nrXI
6Pp+uXniObUtZt7SWZ0dLcGU/uEx90IAQue7bielQlKV30D2iWkdzho5A+4Y IZTtZT1Bp9V5
cRa/PEu3BgjZgpyM845/3dtWKxOgKKKKAPSLz/Xr/wBco/8A0Ba5/wAD6TrA 8LwXukG1fzri
9DrcEjaftTjjH+4P1/DoLz/Xr/1yj/8AQFrK+HV2ZvCiWxS4leK8vAkcExi+ X7Q5LE7lycuB
yfTA6muTGey5F7RXV/x+RrS5r+6arWPjRtvyaT8rK3337EH+laOn+FTF4Y0z T57yWC9sZGmh
u7XbuikbeCVDqynKyOvzKeGzwQCHSXuvW0I8m38/DABZ0jVmBOMFxLjOO+3r 2qy3ivS49Isd
Sla48q+k8qBIbWSeRpArMVCRqzcBHOcY+WpwsaEW/ZKzHUc2vedylD4Xd/EN vd3jeda2cRVH
kuWkkvZS6yLJOu1VHlP5hjX5lUyZUR7QKx9M8DajNKY9Wufs9hb6fJYWFtbX azm1VmiZWjkN
vGytH5KbS3mNkA5BX5tyy8W2l54lOnrNGbea3tzany3DtMxuvMRwfulVtTkM AQQwPOBUl741
0Gwglmmup3jh80zGCzmm8kRu8btJsQ7F3RyAM2AdjYJANdpiE3g3R5Lozxw/ Z8fZdkcCoiR+
RKsi7Rt43eXEreqxRjjaKsab4bs9L/sjyJJ2/srT20+DewO6M+VktgDLfuV5 GByeOmKa+NdD
hmktbrVI3uI3kZxHaygRxLNLEXfg7URomV5CQgIBO0OorUtdb0691Gewt7jf cQ7sjYwV9p2v
sYja+1iFbaTtYgNgnFAGhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAcQ/8AyD4f+usn8krz/wAVf8jlp/8A2D5v/Rkd egP/AMg+H/rr
J/JK8/8AFX/I5af/ANg+b/0ZHQBXooq5YafJqCXhiPzW1ubgr/eAZQe/GASf wx3oAr29yLK6
humUssMiyEDqQCDXRXXxF0m7geJ7O8AcYyImyP0rHk0uePTbS82swujLsRRn 5IwMtx9W+m3N
NsrH7ReiC4aSBfKeZm8vc21Yy/AJGcgcc960hVcFZImUFLcvad4+t7V2hkVn t+qmdGiwT1wc
EfgfXr2C3vxGgTSvslttnupF2yG13F5PbJGIwe5BJ9ADyKNxp8bRW8lm8tzH PI0Sq8O1y67c
jaC2fvrjn149Yk0m8N29tHp85uUG5olhO9RxyRjI6j86PaMSpxXQyrGGfzJ7 y7K/abltzhRh
VHQKPYDA/CrtTLaXL2r3S28rW6Ha0oQlFPHBPQdR+dWINHv57hIPssqO4kKB 42G8xgllHHJ4
xj14rMso0UUUAekXn+vX/rlH/wCgLXNeB4dWsfDsV7Yae16k9xejCSBCh+0s Oc/7n6+3PS3n
+vX/AK5R/wDoC1P8MP8AkQrX/r7vf/SqWsa1CFaPLMuE3B3RVfUPE77R/wAI 1LgOrf8AHyvO
CDjp7UQeHtdh8P8AhS3tDbwXtjfSTzyTR+bHErQ3C8qHQtzIq8Hqc9Aa7qio oYWnQbcOo51H
PRnFw+BJrS9XUrbVYxqCOs6NLalohMXu2kJQOCUP22QKu4Fdq5Zuc4ereENe sbHUNK0Zp76T
V7Se2u7+6t4THiSa4kXOJo2Rl+0vuZY3BG0qgIKn1CiukzOPHgXFj4ktv7R/ 5DVpNbbvI/1P
mTXUu7G75sfasY4zsz3wNjT9GuLLXL+/fUPMhusEQrCEJPZpCDhmUYRWVUOw AOZCqsuxRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
AHEP/wAg+H/rrJ/JK8/8Vf8AI5af/wBg+b/0ZHXoD/8AIPh/66yfySvP/FX/ ACOWn/8AYPm/
9GR0AV6vabqB0/7S6FlmeNREwAO11lRwTn/cNUa1LGY22jXlwkUDSi4hQNLA kmAVlJA3A4+6
PyoAvW+pxXtzCrBYIUkm8zfIo8u3eNIsKTyzKinHBJwDg81Rh1by9WN6BJFt t2hi2N8y/uTG
hzxyPlJIx3IHapLjTbVJJZ5JJILUJAdsSeYweWPfgAsPlGG5JJ6deTUd5pMe nhorq723XzlF
SPdGQjshy2cgko2PlI6ZIycAE1vrhD2st28txcRmdHllAkPlvGFUfN97ad52 njn3NOuNUtLy
F7SaWdYB5ZSWO1jU5XzOBGpUAHzTzuJyPfAbHoKNd38Ul0ypZzvEzLFksFSV iQNw/wCeXTPf
rxTk8PLNIqw3eQNrSGRAm1GjaVSMtgnYpyCQAcDJHzUAObXY3siu6VZVjliA aGOR3Ds5JMxG
4ffIIA5weRu4c2vQyXupyyCdlvLgspOCyRmOWP16gSLgZx8uMioZtFtLeOWe TUlMEZjH7pFk
c79/GFcqCNmcbuhznPy1Jc6JBDcWdm8zJc+XKJhGm/zHWV0GzJGSdvT5enGW OKAMGinSKEkZ
VdXAJAdc4b3GQD+YptAHpF5/r1/65R/+gLU/ww/5EK1/6+73/wBKpagvP9ev /XKP/wBAWp/h
h/yIVr/193v/AKVS0AdhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAcQ/wDyD4f+usn8krz/AMVf 8jlp/wD2D5v/
AEZHXoD/APIPh/66yfySvP8AxV/yOWn/APYPm/8ARkdAFerVrqFxZxyRxeUU kKsyywpICRnB
wwOPvH86q0UAWodRuoZJXDrIZTukEyLKGbn5iGBGeTz15PqacdUvTC8bTbt+ 7LuoaTDZLAOR
uAOTkA4O4+pqmAzMqqpZmYKqqOSScAfnVyLR9SncRpa/vCMhd6uceuE3H9K0 hSnNXiiJVIQd
pMkbW9RaJozcfI2Sw2L8xKshY8csVdgWPJ4yeBiNdUvUORN/zzyNowQiFFBG ORtJBHQg85rU
t/BWtTkZiCDuyqTj8HKGprvwbNpkSS6jNL5LnaHt9oKnsGyGAz25I7dxmo0J SfLdX9SJV4xX
Nrb0MOfUbq5jaOR18tip2Iiqo27sYAAA++xwOpJPWpDq9805meZXdi5bfGrB tx3EEEYI3fMB
0B5ABrGsLlrmFy3JSRkz64OM1brKScW0zVO6uOkkeWRpJHZ3clmZjkknqSab RRSGekXn+vX/
AK5R/wDoC1P8MP8AkQrX/r7vf/SqWoLz/Xr/ANco/wD0Ban+GH/IhWv/AF93 v/pVLQB2FFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFFFFABRRRQBxD/8AIPh/66yfySvP/FX/ACOWn/8AYPm/9GR16A//ACD4 f+usn8krz/xV
/wAjlp//AGD5v/RkdAFeiiigBUYJc2xOcfaIhx/vrXqejWJ0fwtPdqw+2zW5 maQDODtJVRns
M/mT615NcN5cXmZxsdXyPZgf6V6/FIJPBSMCWDacDn1/d1v7Rxoxh0ctfwOa pBOo59VF2NC5
t4Yo2e4urhwoyzNOUAHfIXAx+FcudfgtLK/hFp51tNIfK89/LidSoGFzljk5 6DBz1q54mhi1
PTHt5ZCq7lfHmFAxBzg4IyD6VS0ubTtB0q/1i6iGYSAkjku5G1cKrNzy3bpW 1lCn76vdqyTt
r/XYxbvO0dLLV+R5LpkypqVzaW8jXFuHdvP24BJYnj8O3Y561s1kaAweG6ZV CqbhyAO3Na9c
tWLjUlFu+r/M7oz54xklbRbegUUUVAz0i8/16/8AXKP/ANAWp/hh/wAiFa/9 fd7/AOlUtQXn
+vX/AK5R/wDoC1P8MP8AkQrX/r7vf/SqWgDsKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDiH/5B 8P8A11k/klef
+Kv+Ry0//sHzf+jI69Af/kHw/wDXWT+SV5/4q/5HLT/+wfN/6MjoAr0UUUAQ XoJsLgKMt5bY
GO+OKseGvijdadZy6bqNjJqNuilIdnDAdNpzwVxV2DTfPsluWu7aEPI0UaSl gXZQpPO3aPvD
liBVFrfyJXjaLy5FYhlK4II6g+9bRqxVN05RTvr6fcZSpc01NOxO3jvWZP8A kE+HLGxU9Hnz
Iw/l/KsrU5fEfiBFj1fWC0KtuEMSBVB+gFaltbPdStGhUERvJ83oilj+gNNE EjW73AX90jqj
NnoWBIH/AI6fyqFPlfNBJPv1+/f8R+yjaz1X4fdsUNPsI9PtzFGzNk5JbqTV uiipbbd2aJW0
QUUUUgPSLz/Xr/1yj/8AQFqf4Yf8iFa/9fd7/wClUtQXn+vX/rlH/wCgLU/w w/5EK1/6+73/
ANKpaAOwooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKAOIf/kHw/8AXWT+SV5/4q/5HLT/APsHzf8A oyOvQH/5B8P/
AF1k/klef+Kv+Ry0/wD7B83/AKMjoAr0UUUAakX2S40aCGa9jgeG4lkZCjsz KyxgbcDBPyng
kduR1rUtNeg/0uYiCF57uSeVJfNbzEbBCAIQHx83D4Hze5rl6KAOittUtYre 1824WURwSp5B
jYKMxOuDj7uWbGUPzDDNtYZLYNUtY2laSaSSGa4t55IWX70aFgYSAApxlSBw uFH3T8tc/RQB
1lreu9rdL/bO+8jt2Y3+6X5UMsIVNxXf1D8AY+f3OOf1SeO4v2kibeNiK0mM eY4QBn55+ZgT
k8nPPNU6KACiiigD0i8/16/9co//AEBan+GH/IhWv/X3e/8ApVLUF5/r1/65 R/8AoC1P8MP+
RCtf+vu9/wDSqWgDsKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigDiH/5B8P/AF1k/klef+Kv+Ry0 /wD7B83/AKMj
r0B/+QfD/wBdZP5JXn/ir/kctP8A+wfN/wCjI6AK9FFFABRRRQAUV1lj4Iup 9Ot7uclPNbLL
uA8tP7xz/npWDq+lz6PqT2k4yPvRSDpInYj+o7VTg0rkqabsUaKKKkoKKKKA PSLz/Xr/ANco
/wD0Ban+GH/IhWv/AF93v/pVLUF5/r1/65R/+gLU/wAMP+RCtf8Ar7vf/SqW gDsKKKKACiii
gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigDiH/wCQfD/11k/klef+Kv8AkctP/wCwfN/6Mjr0B/8AkHw/9dZP 5JXn/ir/AJHL
T/8AsHzf+jI6AK9FFFABXf2ng+206C1v5/MuJY8PLFkbRx2GOcfrXAV67Zzy 3QSOJlGIwzO3
QcDt/npXBjMROjODiawp88WNvdQNwqpG37o4OR/FWXqdjb6to8sNzKsZi+aC UjmNv8D3H/1q
0ZtMjs0aUt5wJJ27cIhPfGTn6ZxU1rLBArXUiRRW8MbOWVFXOOp4r0vrtN0O dJJeb6/L/M4f
ZSVXlvdnj6knIYEMCQcgj8RntTqY2oz63qd7rE7H/SpSY1P8MY4UflT6yg24 ps6mrMKKKKoR
6Ref69f+uUf/AKAtT/DD/kQrX/r7vf8A0qlqC8/16/8AXKP/ANAWp/hh/wAi Fa/9fd7/AOlU
tAHYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFAHEP/yD4f8ArrJ/JK8/8Vf8jlp//YPm/wDRkdeg P/yD4f8ArrJ/
JK8/8Vf8jlp//YPm/wDRkdAFeipDBItulwV/dO7IrZ6lQCR/48Pzomgkt3CS rtYorgZzwyhg
fyIoAjr1DSLiO20iGeR1QzIrZY44Cgfz3V5za6fcXkckkXlBIyqs0syRgE5w MsRn7p/Ks670
4TXDLe+e7odhimdsJjttPTHpXHi8K69rO1r/AKGtKooXuj0u+8daBZ5SXUYp G7xxZkP5CuR8
SeM/7d0l9K0uzuoopsJJPKoQeXkEgDOcnFYkVtDCMRxIg9hUtY0sspwacm3+ RUq7eysNjRY4
1RRhVGAKdRRXpGAUU5o3RUZkZQ43KSMbhkjI9eQR+FNoA9IvP9ev/XKP/wBA Wp/hh/yIVr/1
93v/AKVS1Bef69f+uUf/AKAtT/DD/kQrX/r7vf8A0qloA7CiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooA4h/+QfD
/wBdZP5JXn/ir/kctP8A+wfN/wCjI69Af/kHw/8AXWT+SV5/4q/5HLT/APsH zf8AoyOgDWsb
20j0KG0vNskJuZZmi3EHcqxlenI3Demeg3E/w1ca6tr/AFGe8uzFMYhZ3c7l A29VRVkQYHUs
6jHA45IxXK1J5832f7P5snkb9/l7jt3YxnHTOOM0AaFjCbnRry3SWBZTcQuF lnSPICygkbiM
/eH51cE8VxJcNaNaNdIlvFG1yIwjIkexyPN+XllQjOGx2HNc/RQB0F79j8iX +zvsP2H97v8A
Ox5m7e+zbn9593y8Y+XP3v4qtKunQTajch9PYSTyS2sZ2NtTypynykYHzbPl PIIGQOM8rRQB
1EUmlySqZ1tDs8lo1TYmXeB2YE4xjzdg+YFV6YC5FR3t3aQW88sNrYi73wjB Mc2OJdxAVRGe
NgIAI6E/N05uigDqriSzOoW8Fs9m1tAJ4oy5Rtp85iCC/wArfIykbztPzAEN yOZn2/aJdnl7
N52+Xu24z23c4+vPrUdFAHpF5/r1/wCuUf8A6AtT/DD/AJEK1/6+73/0qlqC 8/16/wDXKP8A
9AWp/hh/yIVr/wBfd7/6VS0AdhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAcQ//ACD4f+usn8kr z/xV/wAjlp//
AGD5v/RkdegP/wAg+H/rrJ/JK8/8Vf8AI5af/wBg+b/0ZHQBXooooAKKKsRW N3OMxW0zj1VC
RQBXoq3/AGbcAHd5a4GcGQE/kOapg5AOCPYjFU4tK7QC0UUVIBRRRQB6Ref6 9f8ArlH/AOgL
U/ww/wCRCtf+vu9/9KpagvP9ev8A1yj/APQFqf4Yf8iFa/8AX3e/+lUtAHYU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFAHEP/wAg+H/rrJ/JK8/8Vf8AI5af/wBg+b/0ZHXoD/8AIPh/66yfySvP /FX/ACOWn/8A
YPm/9GR0AV6KKKALmlXAtdWtJ2+6kqlvpnmu3s47VyGu0+0SL94zMX578E15 5XQxamQwJPLg
MfqRk/qa7sDSVWTiedmVSVKmpp9TsLqe3Fu0UcaIhGCEUAVhtqkFroMDyadF cOI1Tk4GemSM
GqEl+7SCAZMzA4j/AIj+HWm3MbDQvLdhvVtxCnOBvz/KuurRhBJGeAlUk5OS smc7qt5NJfWu
ba3tlkkKmOFABjYx/oKbUN/5X2mx8kNsExG49CfLf8PyqavOxNufQ9RbBRRR XOM9IvP9ev8A
1yj/APQFqf4Yf8iFa/8AX3e/+lUtQXn+vX/rlH/6AtT/AAw/5EK1/wCvu9/9 KpaAOwooooAK
KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAKKKKAOIf/AJB8P/XWT+SV5/4q/wCRy0//ALB83/oyOvQH/wCQfD/1 1k/klef+Kv8A
kctP/wCwfN/6MjoAr0UVIYJhM8Jik81N29Np3LtyWyO2MHPpigB1nClxewQy PsSSRVZvQE4z
Xo58M6bawuYZJQWXAG4Dbx6jk/TOPavMiARg9K04rzxNbaeJ7ee4NkBgST25 kQc4+/x3461c
JOOzsJpPclWz+wa7FLH8hZdy47ZXn8jmqkviP7VFcR3Vitx5blFeHHzYPGQf 8az7mbVL1n8+
/VFf74toBGW+rZJpIII7eFYol2ovQVvUxDku7BIa8t7fzQyXOyGGFi8VunOC VIyT64PapqKK
5m7jCiiikB6Ref69f+uUf/oC1P8ADD/kQrX/AK+73/0qlqC8/wBev/XKP/0B an+GH/IhWv8A
193v/pVLQB2FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABRRRQBxD/wDIPh/66yfySvP/ABV/yOWn/wDY Pm/9GR16A/8A
yD4f+usn8krz/wAVf8jlp/8A2D5v/RkdAFeu0u5bM63q0yRx/apkvIGTAwmx JCXA6gsBHz3P
m+1cXRQBrX1raQ6ck8YUNOIGh+ckkBGExxnj94Mc9cHHGak1C1vZJEvreKUW ws4VNwuRHxCq
su/p1BXGeTx14rLubqW7kDylcgbVVECKo9AoAA5JPA6knvUNAHVHS7OOacyW CrFCZfszMzgX
kaxSsHJ3fNykZymB8/uKLfS7OeVtlgrvHGjrErOfNaS2klCn5s8MoAxg465P NcrUkM8lu5eJ
trFGQnGeGUqR+RNAG5c6SslmfJs/Jvz5byW+5h5C5lDEhjlVwsTEseNwOQCK 0rmwsXv0tvsz
SRWsdwkUcStIzsLlh5e0OpbajbsAg4OTkcVxtFAG1rFraW1opt7Zo3e5dSZC Q6BY4yUwGIHz
O3BywwATkGsWiigD0i8/16/9co//AEBan+GH/IhWv/X3e/8ApVLUF5/r1/65 R/8AoC1P8MP+
r0B/+QfD/wBdZP5JXn/ir/kctP8A+wfN/wCjI6AK9FFFABRRV+10a8u4vMRA qYyC56/gOaTa
SuyZSUVeTKFFSSxGGXyiwL+gzUq6feMu77NKF/vMuB+ZppXSa1TFCpGavF3K 1FLIvlTGFiu8
DOFYHj6ikptNaMsKKKKQHpF5/r1/65R/+gLU/wAMP+RCtf8Ar7vf/SqWoLz/ AF6/9co//QFq
f4Yf8iFa/wDX3e/+lUtAHYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHEP/AMg+H/rrJ/JK8/8A FX/I5af/ANg+
b/0ZHXoD/wDIPh/66yfySvP/ABV/yOWn/wDYPm/9GR0AV6KKKAFWRIt0rgMs as+09DgEgH64
rY0PxWsEWJCm5zli361iSIJIZIySA6FSR6EYrkH+2wM0DxsdufmHTit1goYm g5J+/B3t3Vtv
+CeRmKrc8XDax7XaXNvfLFLDI8cJDDbE2zJ3t1I5PGK10t9MjTcLSJn/AL7j efzOa8w8HalO
NLkSdWUxzZUt3DAf/E/rXVDU2ZDgkgDk+lerHBK2it+hyVMVUi1GT1aRieK9 o8UQOgAEluwO
PUEVnUmsanBqGsWa28oleIuJCnIUbT1PTrilrzcZFRq2R7WFcnRjzKzCiiiu U6D0i8/16/8A
XKP/ANAWp/hh/wAiFa/9fd7/AOlUtQXn+vX/AK5R/wDoC1Y8GI/h/wALwade eW06TXEreXPG
QBJM8gGSw5AcA++evWgDr6Kz/wC14P7v/kaL/wCLo/teD+7/AORov/i6ANCi s/8AteD+7/5G
i/8Ai6P7Xg/u/wDkaL/4ugDQorP/ALXg/u/+Rov/AIuj+14P7v8A5Gi/+LoA 0KKz/wC14P7v
/kaL/wCLo/teD+7/AORov/i6ANCis/8AteD+7/5Gi/8Ai6P7Xg/u/wDkaL/4 ugDQorP/ALXg
/u/+Rov/AIuj+14P7v8A5Gi/+LoA0KKz/wC14P7v/kaL/wCLo/teD+7/AORo v/i6ANCis/8A
teD+7/5Gi/8Ai6P7Xg/u/wDkaL/4ugDQorP/ALXg/u/+Rov/AIuj+14P7v8A 5Gi/+LoA0KKz
/wC14P7v/kaL/wCLo/teD+7/AORov/i6ANCis/8AteD+7/5Gi/8Ai6P7Xg/u /wDkaL/4ugDQ
orP/ALXg/u/+Rov/AIuj+14P7v8A5Gi/+LoA0KKz/wC14P7v/kaL/wCLo/te D+7/AORov/i6
ANCis/8AteD+7/5Gi/8Ai6P7Xg/u/wDkaL/4ugDQorP/ALXg/u/+Rov/AIuj +14P7v8A5Gi/
+LoA0KKz/wC14P7v/kaL/wCLo/teD+7/AORov/i6ANCis/8AteD+7/5Gi/8A i6KAOYf/AJB8
P/XWT+SV5/4q/wCRy0//ALB83/oyOvQH/wCQfD/11k/klef+Kv8AkctP/wCw fN/6MjoAr0UU
UAFQT2kNxy6kN/eUlT+YqeimpOLuhNJ7nU+FfA1nLpgvvtTiSZssrkuNqkjH Xrn/APVUPifR
hECscjvEhX5TgDnPYYHVew71k2OtanpQYWU6eWxyYZlymfUY5FJf+I9Xv1Cv ZWAP94zSEH/g
OBn6E11U8TUT1loT7ON+a2pTltIdMNtDFwJ0Lgeh6n+dFVkgmkuvtd5P50+3 aoVdqRj0UVZr
Cq1KTaLCiiiswPSLz/Xr/wBco/8A0Bar1YvP9ev/AFyj/wDQFrIvdc0nTJhD f6pZWkrLvCT3
CRsVyRnBPTg/lQBfoqGG7triR44LiKV4/vqjhivzMvIHT5kYfVSOxqagAooo oAKKKKACiiig
AooooAKKKzPA/gfQde8LRajqMN5LdS3N0rOuo3EYwtxIqgKsgAwqgcDtQBp0 Vf8A+FYeFP8A
n0vv/Brd/wDx2j/hWHhT/n0vv/Brd/8Ax2gChRV//hWHhT/n0vv/AAa3f/x2 j/hWHhT/AJ9L
7/wa3f8A8doAoUVf/wCFYeFP+fS+/wDBrd//AB2j/hWHhT/n0vv/AAa3f/x2 gChRV/8A4Vh4
U/59L7/wa3f/AMdo/wCFYeFP+fS+/wDBrd//AB2gChRV/wD4Vh4U/wCfS+/8 Gt3/APHaP+FY
eFP+fS+/8Gt3/wDHaAKFFX/+FYeFP+fS+/8ABrd//HaP+FYeFP8An0vv/Brd /wDx2gChRV//
AIVh4U/59L7/AMGt3/8AHaP+FYeFP+fS+/8ABrd//HaAKFFX/wDhWHhT/n0v v/Brd/8Ax2j/
AIVh4U/59L7/AMGt3/8AHaAKFFX/APhWHhT/AJ9L7/wa3f8A8do/4Vh4U/59 L7/wa3f/AMdo
AoUVf/4Vh4U/59L7/wAGt3/8do/4Vh4U/wCfS+/8Gt3/APHaAKFFX/8AhWHh T/n0vv8Awa3f
/wAdooAgf/kHw/8AXWT+SV5/4q/5HLT/APsHzf8AoyOvQH/5B8P/AF1k/kle f+Kv+Ry0/wD7
B83/AKMjoAr10ggsptJ0uWdebS3aaZcn99H50gC8fd+cKuRz+9z0WubpzSO6 orOzBBtUE52j
JOB6ckn8aAOi1HTYbnUtTuWaTCXd55xUjbHtGYs8cbnJXnrjA5qG1jS68OW9 jsXz57yX7O+O
fMCxAKT2DBiP97bkgA1RhmuNSaHTl8sSXNwpeVixaWQkhWcknpvboB15yak/ suWaAi3voLmC
Le7bDIFQ7GfoyjlljPT+6M44oA1rnS7G51W/lu7lo3n1GeCJVDEghhyFVG3/ AHx8uV6deeK8
unWE8gdt0IhgtXnCso3IYSzsBjgkhFGerOMn5hjFW/vE8/Zdzr9oz52JCPNz nO716nr6mo/P
m2bPNk2bNm3ccbd27H03c49eaANifSrOwtvOuWkuCm1HSCUKCzNLtYMVPylI 1I45Dg5x1vDR
7az+2WRuGVntnEs7kBTtu1QYXjH3O7YyeSACa52G/vLebzobueKXYE3pIVba MADI7cDj2FR+
fNs2ebJs2bNu4427t2Ppu5x680AE6eXcSp5ckW1yPLkPzLz0PA5H0FR055Hk YM7sxAC5Y54A
wB+AAFNoA9IvP9ev/XKP/wBAWuW2XreOLw2txbxRLY2hmWWBpGdfNuOFIddp 68kN1HHHPU3n
+vX/AK5R/wDoC1XoA83m1nU01K/njuooWeRbeW6mdYVgiS5vwpLlHVfuRpll Od2OpBHQvqOq
f8Ifa3SXdv8AbpLqCFbhEMkbK1ysYbkJvBQ8lQobOVwCDXT0UAcTqGs31otz p7ap5L2
Re: How to import the UML2 Files [message #87573 is a reply to message #87557] |
Sun, 24 December 2006 23:16 |
Hi Ed,
thanks again for showing me the way :)!
I have seen it in your Screenshot, but it does not show up in my version
of eclipse. I did make a fresh installment of eclipse, using the calypso
version of GMF and EMF. Moreover I tried to install the UML Plugin, but
strangely it is not possible to select it. Could it be, that I need to
use an older version of eclipse?
I hope that everyone else is either celebrating or sleeping :)
cheers
Oliver
Ed Merks wrote:
> Oliver,
>>> Ed Merks wrote:
>>>> Oliver,
>> cheers
>> Oliver
FUDForum. Page generated in 0.04253 seconds
