Home » Eclipse Projects » Equinox » Accesing OSGi from a Servlet
Accesing OSGi from a Servlet [message #87303] Tue, 01 May 2007 20:27 Go to next message
Originally posted by: peter.brester.pixtor.org
So I finally got Jetty to be running bundled with Equinox!
But I want to access other OSGi components from my servlet, and I dont
really understand how this can be done.
A simple example on how to use the log service (or something similar) from
my servlet would be appreciated.
BR
P
Re: Accesing OSGi from a Servlet [message #87707 is a reply to message #87303] Sun, 06 May 2007 18:56 Go to previous message
Simon Kaegi is currently offline Simon KaegiFriend
Hi Peter,
If you want your servlet to interact with other OSGi components then you'll
need a BundleContext.
Probably the easiest approach is to add an Activator to your bundle and
stash the bundle context in a static. You can then access the context
statically from your servlet e.g. Activator.getBundleContext().
I don't have a concrete example of what you're looking for however with an
accesible bundlecontext you could create and open a log service Service
Tracker in your servlet's init method and then use it as you see fit.
HTH
-Simon
"Peter B" <peter.brester@pixtor.org> wrote in message
news:f187s6$rmd$1@build.eclipse.org...
> BR
> P
Previous Topic:developing fragments in pde
Next Topic:Jetty Logs
Current Time: Wed Jan 15 09:21:59 GMT 2025
Powered by FUDForum. Page generated in 0.03164 seconds
