Error opening jextract'ed dump [message #7877] |
Fri, 28 November 2008 14:17  |
I am trying to use MAT to analyse a jextract'ed dump.
Here is what I do:
1. Run my Eclipse application (using the JVM level shown below).
2. Generate a dump using sendsignal.exe.
3. Run jextract from the JVM, which generates an .xml and .zip file.
4. Open the .xml file in MAT.
5. MAT dies with an exception.
My JVM is:
IBM J9 VM (build 2.4, J2RE 1.6.0 IBM J9 2.4 Windows XP x86-32
jvmwi3260-20081105_25433 (JIT enabled, AOT enabled)
J9VM - 20081105_025433_lHdSMr
JIT - r9_20081031_1330
GC - 20081027_AB)
JCL - 20081106_01
The exception is:
!ENTRY org.eclipse.mat.ui 1 0 2008-11-28 14:15:48.140
!MESSAGE Took 4,125ms to get the DTFJ image from file
C:\eclipse34\eclipse\core.20081128.141346.5808.0001.dmp.xml
!ENTRY org.eclipse.core.jobs 4 2 2008-11-28 14:15:48.140
!MESSAGE An internal error occurred during: "Parsing heap dump from
'C:\eclipse34\eclipse\core.20081128.141346.5808.0001.dmp.xml ' ".
!STACK 0
java.lang.IllegalArgumentException: Only array types have component types
at com.ibm.dtfj.java.j9.JavaClass.getComponentType(JavaClass.ja va:80)
org.eclipse.mat.dtfj.DTFJIndexBuilder.getClassLoader1(DTFJIn dexBuilder.java:3551)
org.eclipse.mat.dtfj.DTFJIndexBuilder.getClassLoader(DTFJInd exBuilder.java:3566)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.fill(DTFJIndexBuilder. java:353)
org.eclipse.mat.parser.internal.SnapshotFactoryImpl.parse(Sn apshotFactoryImpl.java:184)
org.eclipse.mat.parser.internal.SnapshotFactoryImpl.openSnap shot(SnapshotFactoryImpl.java:102)
org.eclipse.mat.snapshot.SnapshotFactory.openSnapshot(Snapsh otFactory.java:87)
org.eclipse.mat.ui.snapshot.ParseHeapDumpJob.run(ParseHeapDu mpJob.java:54)
Re: Error opening jextract'ed dump [message #7918 is a reply to message #7898] |
Mon, 01 December 2008 14:52  |
Hi Andrew,
Thanks for the reply. Your remark about class loaders made me realize
that, although my heapdump was generated with a 6.0 SR3 JVM, the Eclipse
environment in which MAT and DTFJ were installed was actually running on
the system JVM, which was 5.0 SR2. Once I forced Eclipse to launch with
the newer JVM, the error went away.
And FYI, I did not see "No class loader for {0}, trying component type {1}
class loader instead" in the log.
FUDForum. Page generated in 0.09998 seconds
