[ATL] Ecore model and Jet Template [message #86947] |
Wed, 23 July 2008 19:29 |
Originally posted by: irbull.cs.uvic.ca
Hi all,
We have a mapping tool and we are hoping to use it to generate an ATL
mapping. Does anyone know if there is an ATL Metamodel (in Ecore) and /
or a Jet template that we could use to generate the ATL program from an
instance of this metamodel?
Ian
Re: [ATL] Ecore model and Jet Template [message #87100 is a reply to message #87023] |
Thu, 24 July 2008 17:26 |
Thank-you so much!
I have been very excited about the TCS project, but this is my first
chance to use it.
BTW, I grabbed the ATL-0.2.ecore file, and there are a few problems. The
primitive types don't have instance names associated with them. (so you
can't create the genmodel from it).
Once I added these types, it worked fine.
Do you want me to open a bug about this?
Thanks again,
- Ian
Alain Michel wrote:
> Yes, there is an ATL metamodel. When you launch an ATL transformation
> written in the ATL concrete syntax, it is then injected into an ATL
> model conformed to the ATL metamodel. This also means that you can
> create a ATL transformation model from another ATL transformation.
> The metamodel is here :
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.atl/plugins/org.eclipse.m2m.atl.engine/src/org/ecli pse/m2m/atl/engine/resources/ATL-0.2.ecore?root=Modeling_Pro ject&view=log
> To extract an ATL model to its concrete syntax (the ATL program) and to
> inject an ATL program into a ATL model, a TCS injector and extractor are
> used. TCS is a tool used to bridge the grammar technical space (programs
> defined by a grammar) and the model technical space (models conformed to
> a metamodel).
> Installing the AM3 plugin will let you inject and extract ATL
> transformation from the eclipse UI.
> http://www.eclipse.org/gmt/am3/download/
> Ian Bull wrote :
>> Hi all,
>> / or a Jet template that we could use to generate the ATL program from
>> an instance of this metamodel?
>> Thanks,
>> Ian
FUDForum. Page generated in 0.03132 seconds
