Home » Eclipse Projects » Eclipse Platform » compile failing on static class v2.1.0
compile failing on static class v2.1.0 [message #86645] Tue, 01 July 2003 14:21 Go to next message
Originally posted by: carl.fake.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I have an old set of classes that used to work in cvs. today I checked
out and tried to build, and I am getting new errors never before seen.
Code is the same.
"MainApplication.config.ChatConfiguration can not be resolved or is not
a field"
That happens on this line
mas_current = MainApplication.config.ChatConfiguration.mas_shout;
Now ChatConfiguration is indeed not a field, it is a static inner class.
final class Parameters{
~ static class ChatConfiguration {
~ mas_shout = new xyz();
public final class MainApplication {
~ static Parameters config;
What sup? is their something new I dont know about?? I am using 1.4.2,
but I am trying 1.3.1_07 as well...
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE/AdESVbJM14DSCi0RAgN0AJ4h/Dm2MaCjxR/JuFWd2thE093iWQCg 95Mi
qSfCuh0nH1kDe5RNIZQWuMo=
=tlQm
-----END PGP SIGNATURE-----
Re: compile failing on static class v2.1.0 [message #88541 is a reply to message #86645] Thu, 03 July 2003 17:53 Go to previous message
Originally posted by: John_Arthorne.oti.com_
Please enter a bug report against JDT core with a *complete* example.
In your example below, you have not defined mas_shout or described the
context where the reference occurs.
> Hash: SHA1
> Code is the same.
> a field"
> =tlQm
Previous Topic:workbench vs debug
Next Topic:Creating an IFile outside of workspace
Current Time: Fri Oct 31 16:56:57 EDT 2025
Powered by FUDForum. Page generated in 0.04643 seconds
