Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP and Agent Controller under Linux EM64T
TPTP and Agent Controller under Linux EM64T [message #86450] |
Sat, 04 November 2006 16:39 |
--------------040908050201080601060609
I am trying to get out test environment running under Linux ES Version 4
on Intel EM64T. I have installed Eclipse 3.2.1 and via the update
manager I have installed the latest release of TPTP and its dependents;
essentially 4.2.1.
I have found that running our AGR regression tests that have been
recorded under Windows XP hang.
I would like to check some basic conclusions that I have arrived at:
1. Release 4.2.1 of TPTP still uses the original Agent Controller not
the New Technology Agent Controller
2. The agent controller has not yet been ported to Linux EM64T, but
the new technology agent controller has been.
3. The Integrated Agent Controller does not work yet under Linux
EM64T. The preferences screen is grayed out.
4. Therefore it is pretty hopeless to test under Linux EM64T with the
current release of TPTP.
Are these conclusions accurate? If they are, when will Linux EM64T be
supported? Is it agreed for TPTP 4.3?
Thanks in advance,
Joel
<html>
<head>
</head>
<font face="Helvetica, Arial, sans-serif">Hi,<br>
<br>
4 on Intel EM64T. I have installed Eclipse 3.2.1 and via the update
essentially 4.2.1.<br>
<br>
recorded under Windows XP hang.<br>
<br>
I would like to check some basic conclusions that I have arrived at:<br>
</font>
<ol>
<li>Release 4.2.1 of TPTP still uses the original Agent Controller
not the New Technology Agent Controller<br>
</li>
<li>The agent controller has not yet been ported to Linux EM64T, but
the new technology agent controller has been.<br>
</li>
<li><font face="Helvetica, Arial, sans-serif">The Integrated Agent
Controller does not work yet under Linux EM64T. The preferences screen
is grayed out.<br>
</font></li>
<li><font face="Helvetica, Arial, sans-serif">Therefore it is pretty
hopeless to test under Linux EM64T with the current release of TPTP.<br>
</font></li>
</ol>
supported? Is it agreed for TPTP 4.3?<br>
<br>
Thanks in advance,<br>
Joel <br>
</body>
</html>
--------------040908050201080601060609--
Re: TPTP and Agent Controller under Linux EM64T [message #86514 is a reply to message #86450] |
Sat, 04 November 2006 23:07 |
Randy D. Smith Messages: 394 Registered: July 2009 |
Joel Rosi-Schwartz wrote:
Which Eclipse 3.2.1? x86? or x86_64?
> essentially 4.2.1.
True on Linux; not true on Windows.
For the agent controller itself, you're correct. Native logging is
ported, but not the probekit, LinuxAgent (perfmon), piAgent (profiler), etc.
The Linux-IA32 version of the IAC loaded and running in the Linux-IA32
version of Eclipse should work on EM64T ... assuming you're only doing
32-bit stuff. You're right that there is no port of the IAC to
Linux-EM64T yet.
Unless you want to run purely 32-bit stuff there. I know... not what
most would expect to run... but some people find it useful.
No, I think it fell of 4.3's plate, so to speak.
> Thanks in advance,
> Joel
Sorry I had nothing more than information to offer!
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: TPTP and Agent Controller under Linux EM64T [message #86699 is a reply to message #86514] |
Wed, 08 November 2006 14:42 |
--------------050708080602000002090101
Thanks Randy. Not exactly what I wanted to hear but then "The truth
shall set you free" and all that jazz :-)
To answer your question below, I am running 64 bit versions of everything.
Now if I get your gist correctly you are saying that if I installed a
32bit JVM and eclipse, then I would be able to develop, build and test
in 32 bit mode. Is that correct. If so, it is not exactly my preference,
but I could live with it for the time being.
Joel
>> Version 4 on Intel EM64T. I have installed Eclipse 3.2.1 and via the
>> update
>> dependents; essentially 4.2.1.
> (profiler), etc.
> Linux-EM64T yet.
>> Thanks in advance,
>> Joel
<html>
<head>
</head>
<font face="Helvetica, Arial, sans-serif">Thanks Randy. Not exactly
what I wanted to hear but then "The truth shall set you free" and all
that jazz :-)<br>
<br>
everything.<br>
<br>
preference, but I could live with it for the time being.<br>
<br>
Thanks,<br>
Joel<br>
</font><br>
<blockquote cite="mideij6fv$12n$1@utils.eclipse.org" type="cite">Joel
<br>
<blockquote type="cite">Hi,
<br>
<br>
4 on Intel EM64T. I have installed Eclipse 3.2.1 and via the update </blockquote>
<br>
<br>
<br>
<blockquote type="cite">manager I have installed the latest release
of TPTP and its dependents; essentially 4.2.1.
<br>
<br>
<br>
<br>
<br>
<br>
not
<br>
<br>
</blockquote>
<br>
<br>
<br>
<blockquote type="cite"> 2. The agent controller has not yet been
<br>
<br>
</blockquote>
<br>
etc.
<br>
<br>
<blockquote type="cite"> 3. The Integrated Agent Controller does
<br>
<br>
</blockquote>
<br>
Linux-EM64T yet.
<br>
<br>
<blockquote type="cite"> 4. Therefore it is pretty hopeless to test
<br>
<br>
</blockquote>
<br>
<br>
<br>
<blockquote type="cite">Are these conclusions accurate? If they are,
when will Linux EM64T be supported? Is it agreed for TPTP 4.3?
<br>
</blockquote>
<br>
<br>
<br>
<blockquote type="cite"><br>
Thanks in advance,
<br>
Joel
<br>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
--------------050708080602000002090101--
Current Time: Wed Oct 16 10:50:33 GMT 2024
Powered by FUDForum. Page generated in 0.14875 seconds
