Some comments on the code [message #7776] |
Thu, 10 February 2005 23:03 |
Originally posted by: csetera.spss.com
Let me start by saying how impressed we are with what we are seeing for
the BIRT code that is starting to roll out into source control. Keep up
the great work!
Although we are aware that the work is still ongoing, there were a
couple of concerns that we had when looking at the current code that we
wanted to get noted while there is still a chance that they can possibly
be considered during the first release timeframe.
We were a bit confused with the logging story in the code. There seems
to be quite a mix of logging involved and the question is whether that
will be merged into a single logging implementation? There is
widespread use of commons logging throughout the BIRT code. This caused
us a large number of headaches even getting parts of the viewer code to
run due to classloader issues.
http://www.qos.ch/logging/classloader.jsp and
http://www.qos.ch/logging/thinkAgain.jsp document the numerous problems
when dealing with commons logging. Would it be possible to eliminate
commons logging from the mix and just pick an appropriate logging
framework? Despite the addition of logging in the JDK, it seems that
log4j is still the best choice due to its ability to be hosted on
multiple JDK levels and its functionality. In addition, it seems odd
that the org.eclipse.birt.data.oda.util.logging package and its contents
exist. It is unclear why this is necessary in addition to the other
logging facilities available.
Eventually, we would like to look at packaging the designer views into a
standalone designer tool for non-Eclipse users. The Eclipse RCP
refactoring makes that very possible, as long as plugin prerequisites
are kept to a minimum. At this time, the designer UI holds a dependency
on the org.eclipse.compare plugin which in turn drags in many non-RCP
plugins (such as the resources plugin). The dependency appears to be so
the UI can use the org.eclipse.compare.Splitter class. If this
dependency can be broken (by reimplementing the Splitter class or
similar), it appears that the designer should be able to be built as an
Eclipse RCP application.
Once again, we'd like to say how cool this stuff is looking. Hopefully
you won't take these comments to mean that we aren't impressed and
thrilled to see what is coming. Our hope is to help make BIRT as good
as it can possibly be.
Craig
Re: Some comments on the code [message #8875 is a reply to message #7776] |
Thu, 17 February 2005 03:06 |
Stanley Wang Messages: 81 Registered: July 2009 |
Member |
Craig,
Thanks for your comments on the source code. I will focus on the logging
part for this response.
We have chosen common logging framework because many other projects use
the framework (including Tomcat). We however, do have concerns about the
classloader issues you reported. We will reevaluate the logging technology
and likely pick either Java 1.4 logging or log4j.
All BIRT projects will use a uniform logging framework even though some
projects have not done so.
Stanley Wang
BIRT Engine Lead
> the great work!
> Craig
FUDForum. Page generated in 0.02292 seconds
