Home » Archived » M2M (model-to-model transformation) » [ATL] Specifying a multi-package metamodel via EMF registry in launch configuration
[ATL] Specifying a multi-package metamodel via EMF registry in launch configuration [message #86250] |
Thu, 10 July 2008 01:42 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: apicard.tampabay.rr.com
As we are working on getting our KDM transformation patterns up to
speed, we are encountering another issue.
We want to reference/declare our OUT KDM metamodel through the EMF
registry in order to pickup the full EMF model, so that we can have
access to its eOperations directly from ATL.
This worked fine with our source model since it has a single default
package, but as you might be aware, the KDM is composed of 12 separate
packages in the same metamodel.
How can we map our single OUT : kdm in the ATL with all those packages,
as it is how it shows up in the EMF registry.
Alain
Re: [ATL] Specifying a multi-package metamodel via EMF registry in launch configuration [message #86280 is a reply to message #86250] |
Thu, 10 July 2008 13:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
William Piers![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=william.piers%40obeo.fr) Messages: 301 Registered: July 2009 |
When you load an EPackage (i.e. specify an URI in the launch
configuration), all the referenced packages are loaded. So I think you
won't have problems if you indicates the package which contents the
metaelements (or one of them) you have in your input model.
William
Alain Picard a écrit :
> Thanks
> Alain
Re: [ATL] Specifying a multi-package metamodel via EMF registry in launch configuration [message #86310 is a reply to message #86280] |
Thu, 10 July 2008 14:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
William,
When I specify a uri in this case it bombs out with a severe exception.
Really not sure what to make of it.
Alain
Exception:
SEVERE: ****** BEGIN Stack Trace
SEVERE: exception:
SEVERE: null
java.lang.ArrayStoreException
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:191)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:645)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUn ique(NotifyingListImpl.java:331)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:315)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 26)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:283)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:305)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:338)
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:326)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:426)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:398)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:880)
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1083)
SEVERE: A.main() : ??#26 null
SEVERE: local variables = {self=STM2KDM : ASMModule}
SEVERE: local stack = []
SEVERE: A.__exec__() : ??#8 null
SEVERE: local variables = {e=TransientLink {rule = 'CreateSegment',
sourceElements = {stmRoot = IN!<unnamed>}, targetElements = {kdmSegment
= OUT!<notnamedyet>}, variables = {}}, self=STM2KDM : ASMModule}
SEVERE: A.__applyCreateSegment(1 : NTransientLink;) : ??#14 13:4-13:36
SEVERE: local variables = {kdmSegment=OUT!<notnamedyet>,
stmRoot=IN!<unnamed>, link=TransientLink {rule = 'CreateSegment',
SEVERE: local stack = [OUT!<notnamedyet>]
SEVERE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to
allow continuation after errors).
SEVERE: null
William Piers wrote:
> Best regards,
> William
>> packages, as it is how it shows up in the EMF registry.
>> Thanks
>> Alain
Re: [ATL] Specifying a multi-package metamodel via EMF registry in launch configuration [message #86377 is a reply to message #86310] |
Fri, 11 July 2008 10:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I am not sure, but the error you get seems to happen during the
execution, and should not be associated with the uri issue.
The problem may comes from your transformation file, if you can post
your example here it would be helpful.
William
> William,
> Cheers,
> Alain
> Exception:
> SEVERE: exception:
> SEVERE: null
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> SEVERE: null
>> Best regards,
>> William
>>> Hi,
>>> separate packages in the same metamodel.
>>> Thanks
>>> Alain
Re: [ATL] Specifying a multi-package metamodel via EMF registry in launch configuration [message #86441 is a reply to message #86377] |
Sat, 12 July 2008 00:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
William,
You were right, the issue was somewhere else. After running a full debug
and watching what was happening and tying that together with an earlier
comment from Hugo, I got it figured out. The strange thing is that the
behavior is different between using a .ecore file and the EMF registry.
The situation was the following:
rule CreateSegment {
from stmRoot : STM!StTreeRoot
to
kdmSegment : kdm!Segment (
-- model <- kdmModel
model <- stmRoot.rootInterpreter
and then:
rule CreateModel {
from stmInterpretation : STM!StInterpretationContext
to
kdmLanguageUnit : kdm!LanguageUnit(
name <- 'Common Java datatypes'
kdmModel : kdm!CodeModel (
name <- 'My project',
where the rootInterpreter of the first rule is of type
InterpretationContext and triggered the 2nd rule.
The issue was due to the fact that the kdmLanguageUnit is not type
compatible with the model element where it was trying to assign in,
since as Hugo said, by default it uses the first target. So I
essentially made sure that the 2nd rule was more like this:
rule CreateModel {
to
and that cleared the issue.
Thanks for your decisive "look somewhere else" statement here.
Alain
> William
>> William,
>> Cheers,
>> Alain
>> Exception:
>> SEVERE: exception:
>> SEVERE: null
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> 'CreateSegment', sourceElements = {stmRoot = IN!<unnamed>},
>> targetElements = {kdmSegment = OUT!<notnamedyet>}, variables = {}},
>> {kdmSegment = OUT!<notnamedyet>}, variables = {}}, self=STM2KDM :
>> ASMModule}
>> SEVERE: null
>>> Hi,
>>> you won't have problems if you indicates the package which contents
>>> the metaelements (or one of them) you have in your input model.
>>> Best regards,
>>> William
>>>> Hi,
>>>> Thanks
>>>> Alain
Re: [ATL] Specifying a multi-package metamodel via EMF registry in launch configuration [message #86545 is a reply to message #86441] |
Tue, 15 July 2008 11:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Dear Alain,
> William,
> to
> and then:
> rule CreateModel {
> to
I just want to add some precisions about your comment above:
The rootInterpreter of the "CreateSegment" does not trigger the
"CreateModel" rule.
ATL is declarative so there is no order specified for the execution of
the rules/matchings (except if you use imperative called rules): the two
rules are matched independently and one may be matched before the other
without any consequence on the result model.
The output model elements created by both rules are linked afterwards by
ATL using a traceability mechanism.
Hugo
> rule CreateModel {
> to
> Alain
>> Regards,
>> William
>>> William,
>>> Cheers,
>>> Alain
>>> Exception:
>>> SEVERE: exception:
>>> SEVERE: null
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ASMModule}
>>> SEVERE: null
>>>> Hi,
>>>> Best regards,
>>>> William
>>>>> Hi,
>>>>> default package, but as you might be aware, the KDM is composed of
>>>>> 12 separate packages in the same metamodel.
>>>>> Thanks
>>>>> Alain
Hugo Bruneliere - R&D Engineer
AtlanMod (INRIA & EMN)
University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: hugo.bruneliere@inria.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Specifying a multi-package metamodel via EMF registry in launch configuration [message #86591 is a reply to message #86545] |
Wed, 16 July 2008 16:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thanks Hugo for the clarification
Alain
Hugo Bruneliere wrote:
> Dear Alain,
>> William,
>> debug and watching what was happening and tying that together with an
>> earlier comment from Hugo, I got it figured out. The strange thing is
>> that the behavior is different between using a .ecore file and the EMF
>> registry.
>> to
>> and then:
>> rule CreateModel {
>> to
> "CreateModel" rule.
> Best regards,
> Hugo
>> rule CreateModel {
>> to
>> Alain
>>> Regards,
>>> William
>>>> William,
>>>> Cheers,
>>>> Alain
>>>> Exception:
>>>> SEVERE: exception:
>>>> SEVERE: null
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ASMModule}
>>>> SEVERE: null
>>>>> Hi,
>>>>> Best regards,
>>>>> William
>>>>>> Hi,
>>>>>> have access to its eOperations directly from ATL.
>>>>>> Thanks
>>>>>> Alain
Current Time: Thu Aug 15 19:16:22 GMT 2024
Powered by FUDForum. Page generated in 0.04192 seconds
