BPEL assign problem [message #7765] |
Tue, 15 May 2007 16:30 |
Originally posted by: yannick.schutz.gmail.com
When i try to assign a part of a response to another request from WSDL
inside the details of assign action it gaves me a problem
!ENTRY org.eclipse.jface 4 2 2007-05-15 18:28:37.121
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null
argument:Namespace prefix cannot be null here
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:84)
org.eclipse.bpel.ui.properties.VariablePartAssignCategory.up dateQueryFieldFromTreeSelection(Unknown
Source)
org.eclipse.bpel.ui.properties.VariablePartAssignCategory$1. selectionChanged(Unknown
Source)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:1976)
org.eclipse.jface.viewers.StructuredViewer.handleSelect(Stru cturedViewer.java:1128)
org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected( StructuredViewer.java:1154)
org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenS trategy.java:213)
at org.eclipse.jface.util.OpenStrategy.access$3(OpenStrategy.ja va:207)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:374)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Don't find anything about that!
I really need some help,
THanks,
Yannick
FUDForum. Page generated in 0.04223 seconds
