Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » OutOfMemoryError in HbDataStore.initialize()
| Re: OutOfMemoryError in HbDataStore.initialize() [message #85972 is a reply to message #85840] |
Mon, 11 June 2007 04:41  |
David,
Sorry for the later reply. I set Xmx1500m and this works but it is strange that so much memory is
required. As far as I know Teneo does not use that much memory. Can you profile the memory use?
One other thing I encountered is that with mysql the column/tables names become too long because of
the long names of a few eclasses. You can set a maximum to the length of the names created by Teneo
but then you get nameclashes because Teneo then just truncates the columnnames resulting in multiple
columns having the same name.
If this is also an issue with your database then you need to set an entity name annotation on the
eclasses with long names: @Entity(name="myuniqueshortname").
gr. Martin
David Skogan wrote:
> I have a ecore model with a total of 481 class/type definitions. But I run
> out of memory when I try to initialize the database through teneo. I
> succeeded with a smaller, but similar model file of approximately 120
> class/type definitons. It seems like the problem occurs when
> org.hibernate.loader.entity.EntityLoader creates static select/actions.
> I have set the heap space to -Xmx1024m. Attached are my ecore model and main
> file.
> Any ideas?
> My setup: Eclipse 3.3M6, EMF 3.3.0.v20070330, EMFT TENEO 0.8, Hibernate
> 3.2.4.sp1,
> Exception in thread "main" java.lang.OutOfMemoryError: Java heap space
> at java.util.Arrays.copyOf(Unknown Source)
> at java.lang.AbstractStringBuilder.expandCapacity(Unknown Source)
> at java.lang.AbstractStringBuilder.append(Unknown Source)
> at java.lang.StringBuffer.append(Unknown Source)
> at org.hibernate.loader.JoinWalker.selectString(JoinWalker.java :953)
> at
> org.hibernate.loader.AbstractEntityJoinWalker.initStatementS tring(AbstractEntityJoinWalker.java:93)
> at
> org.hibernate.loader.AbstractEntityJoinWalker.initStatementS tring(AbstractEntityJoinWalker.java:78)
> at
> org.hibernate.loader.AbstractEntityJoinWalker.initAll(Abstra ctEntityJoinWalker.java:58)
> at
> org.hibernate.loader.entity.CascadeEntityJoinWalker.<init>(CascadeEntityJoinWalker.java:27)
> at
> org.hibernate.loader.entity.CascadeEntityLoader.<init>(CascadeEntityLoader.java:25)
> at
> org.hibernate.persister.entity.AbstractEntityPersister.creat eLoaders(AbstractEntityPersister.java:3013)
> at
> org.hibernate.persister.entity.AbstractEntityPersister.postI nstantiate(AbstractEntityPersister.java:2977)
> at
> org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:290)
> at
> org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1294)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:156)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:79)
> at data.db.InitDB.doQuickStart(InitDB.java:67)
> at data.db.InitDB.main(InitDB.java:29)
> Regards
> David
> package data.db;
> import java.util.Properties;
> import org.apache.commons.logging.Log;
> import org.apache.commons.logging.LogFactory;
> import org.eclipse.emf.ecore.EPackage;
> import org.eclipse.emf.teneo.PersistenceOptions;
> import org.eclipse.emf.teneo.hibernate.HbDataStore;
> import org.eclipse.emf.teneo.hibernate.HbHelper;
> import org.hibernate.cfg.Environment;
> import data.model.ModelPackage;
> * Based on the Quick Start Tutorial
> * @author <a href="mailto:david.skogan@dnv.com">David Skogan</a>
> * @version $Revision: 1.0 $
> public class InitDB {
> private static Log log = LogFactory.getLog(InitDB.class);
> /** The main method */
> public static void main(String[] args) {
> // the name of the database, this database should exist but does not need to contain tables
> String dbName = "db";
> doQuickStart(dbName); //ignore return
> /** Method which can be called by others */
> public static void doQuickStart(String dbName) {
> log.info("initialize db " + dbName);
> ModelPackage ePackage = ModelPackage.eINSTANCE;
> // create the HbDataStore
> HbDataStore hbds = (HbDataStore)HbHelper.INSTANCE.createRegisterDataStore(dbNam e);
> hbds.setEPackages(new EPackage[]{ePackage});
> final Properties hprops = new Properties();
> hprops.setProperty(Environment.DRIVER, "org.hsqldb.jdbcDriver");
> hprops.setProperty(Environment.URL, "jdbc:hsqldb:hsql://localhost/plcs");
> hprops.setProperty(Environment.DIALECT, org.hibernate.dialect.HSQLDialect.class.getName());
> hprops.setProperty(Environment.USER, "sa");
> hprops.setProperty(Environment.PASS, "");
> hprops.setProperty(Environment.C3P0_MIN_SIZE, "5");
> hprops.setProperty(Environment.C3P0_MAX_SIZE, "20");
> hprops.setProperty(Environment.C3P0_TIMEOUT, "300");
> hprops.setProperty(Environment.C3P0_MAX_STATEMENTS, "50");
> hprops.setProperty(Environment.C3P0_IDLE_TEST_PERIOD, "3000");
> hprops.setProperty(Environment.SHOW_SQL, "false");
> hbds.setHibernateProperties(hprops);
> final Properties props = new Properties();
> props.setProperty(PersistenceOptions.USE_MAPPING_FILE, "false");
> props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, "JOINED"); // SINGLE_TABLE || JOINED
> hbds.setPersistenceProperties(props);
> hbds.initialize();
> if (hbds.isInitialized()) {
> System.out.println("Success!");
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: OutOfMemoryError in HbDataStore.initialize() [message #606898 is a reply to message #85840] |
David,
gr. Martin
David Skogan wrote:
> file.
> Any ideas?
> 3.2.4.sp1,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Regards
> David
> package data.db;
> hbds.initialize();
The Netherlands
Current Time: Fri Oct 24 19:58:26 EDT 2025
Powered by FUDForum. Page generated in 0.03947 seconds
