Home » Eclipse Projects » GEF » Property change does not make the editor dirty
Property change does not make the editor dirty [message #85548] |
Thu, 26 June 2003 11:42  |
I have looked at the Logic example, I dont see any special handling to
make the editor dirty when a property changes. But yet magically this
seems to happen. I have done the same, but the property change does not
make the editor dirty in my case.
any ideas?
Re: Property change does not make the editor dirty [message #85683 is a reply to message #85583] |
Thu, 26 June 2003 18:44   |
Randy Hudson wrote:
> A property change is an executed command, which dirties the editor.
> look for getAdapter(IPropertySheetPage.class) on IEditorPart
> "Naveen Valluri" <naveen.valluri@commerceone.com> wrote in message
> news:bdf49f$l8o$1@rogue.oti.com...
> > any ideas?
But, I'm still not sure how it gets invoked. In my case, I change a
property value, which firesPropertyChange, but it is still not making the
editor dirty. I have tried to step through and the only noticeable
difference is that, in the logic example the celleditor has the
UndoablePropertySheetEntry as a listener. In my case the propertysheet
entry class is the listener. Even this is not set by me. So what gets
invoked is it governed by the edit policies, edit part or the editor.
since the graphical editor class already has the getAdapter method's
default implementation, I'm assuming it should get called and make the
editor dirty.
regards,
Naveen
Re: Property change does not make the editor dirty [message #85703 is a reply to message #85683] |
Thu, 26 June 2003 19:14   |
applyEditorValue() in UndoablePropertySheetEntry gets called when the value is
changed. This method calls setValue(...) which calls valueChanged(...). The
valueChanged(...) method creates a command which gets executed on the command
stack, dirtying the editor.
>>>any ideas?
> editor dirty.
> regards,
> Naveen
Re: Property change does not make the editor dirty [message #85848 is a reply to message #85683] |
Fri, 27 June 2003 14:25   |
Originally posted by: jwoods.journee.com
HOW are you changing the property value? If you do it through the property
sheet, then it will be done with a command run on the editor's command stack
(which makes the editor dirty - unless your editor is broken somehow). If
you are changing the value somehow else (not doing the change through a
command run through the editor's command stack) - then that's your problem.
If you ARE changing the property through the prop sheet, make sure you have
something like the following in your editor's getAdapter() method:
if (type == org.eclipse.ui.views.properties.IPropertySheetPage.class)
PropertySheetPage page = new PropertySheetPage();
page.setRootEntry(new UndoablePropertySheetEntry(getCommandStack()));
return page;
- Jason
news:bdft0r$c9j$1@rogue.oti.com...
not
> > > any ideas?
> editor dirty.
> regards,
> Naveen
Re: Property change does not make the editor dirty [message #86290 is a reply to message #85703] |
Wed, 02 July 2003 01:50  |
is
The
command
> >>>any ideas?
> > editor dirty.
> > regards,
> > Naveen
Thanks a ton guys!. The problem was that my root editor was a multipage
editor which was calling someother getAdapter method, I was expecting the
active editor's getAdapter method to be called. The problem got fixed,
when I added the getAdapter method my multipage editor.
regards,
Naveen
Current Time: Wed Oct 22 18:13:20 EDT 2025
Powered by FUDForum. Page generated in 0.05515 seconds
