Re: RAP Safari Problem [message #85645 is a reply to message #85601] |
Wed, 30 April 2008 10:05 |
Originally posted by: rherrmann.innoopract.com
I filed a bug in the qooxdoo bugzilla:
854: Safari: odd behavior with TAB key and text field
http://bugzilla.qooxdoo.org/show_bug.cgi?id=854
Rüdiger
Stefan Röck wrote:
> The Safari (tested on windows) seems to have problems with the TAB key
> and text widgets in general. Maybe this is the reason for your problems.
> When having a text widget and some buttons the caret remains within the
> text widget, even if its focus is lost. This only happens if the TAB key
> is used to jump to the next widget.
> The bug contains a snippet on this issue:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=229574
> This seems to be a qooxdoo bug as the problem ocurrs in the qooxdoo demo
> as well (http://demo.qooxdoo.org/current/showcase/#Form)
> Stefan.
> Thomas Kühne schrieb:
>> I have a Problem with RAP using the Safari Browser on Mac OS.
>> I use a login dialog before startup of an application which has two
>> input text fields for username and password. When I enter
>> the username and then click on the password field and then
>> submit the form everything works fine but when I first enter
>> the username and move with the tab key to the password field
>> and then submit the form I can't login. I added a listener
>> to the password field but no key input is received by the input
>> field when I use the tab key to move from one text field to another.
>> This Problem only occurs with Safari 3.1.1 on Mac OS but not
>> with Firefox or IE on Windows. I tried with M3 and HEAD Revision.
>> Any ideas ?
>> Regards,
>> Thomas
FUDForum. Page generated in 0.03845 seconds
