Home » Archived » M2M (model-to-model transformation) » [QVTO] Add UML stereotypes in out model
[QVTO] Add UML stereotypes in out model [message #85295] Thu, 26 June 2008 12:11 Go to next message
Originally posted by: koen.yskout.cs.kuleuven.be
When I create a transformation that needs to generate a UML model and
apply stereotypes from a given profile to its elements, the stereotypes
do not get saved in the resulting .uml file (minimal example of such a
transformation at the end of my post).
Looking at the .uml file with a text editor, the stereotype applications
should appear as siblings of the uml:Model element (and the root should
become an xml:XMI node), but they are not in the file, and the root node
is still uml:Model.
Is this a bug, is it impossible or am I doing something terribly wrong?
Thanks for your help,
Koen
/* run with 'pathmap://UML_PROFILES/Standard.profile.uml' for profile */
modeltype UML uses uml;
transformation demo(in profile : UML, out model : UML);
main() {
var stereo := profile.objects()[Stereotype]->any(name = 'Metamodel');
var myModel := object UML::Model {
name := 'myModel';
myModel.applyProfile(profile.objects()![Profile]);
log('Applied before?', myModel.isStereotypeApplied(stereo)); /*false*/
myModel.applyStereotype(stereo);
log('Applied after?', myModel.isStereotypeApplied(stereo)); /*true*/
Re: [QVTO] Add UML stereotypes in out model [message #85371 is a reply to message #85295] Fri, 27 June 2008 09:01 Go to previous messageGo to next message
Hi Koen,
I ran sample you posted and got correct result.
The only line I changed is metamodel decl:
modeltype UML uses uml('http://www.eclipse.org/uml2/2.1.0/UML');
After executing sample output model is:
<uml:Model xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML"
xmi:id="_eHpUwERIEd29r5TrDvwR5w" name="myModel">
<profileApplication xmi:id="_eHpUwURIEd29r5TrDvwR5w">
<eAnnotations xmi:id="_eHpUwkRIEd29r5TrDvwR5w"
source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage"
href=" pathmap://UML_PROFILES/Standard.profile.uml#_yzU58YinEdqtvbn fB2L_5w"/>
</eAnnotations>
<appliedProfile href="pathmap://UML_PROFILES/Standard.profile.uml#_0"/>
</profileApplication>
</uml:Model>
I'm using latest QVTO build from
http://www.eclipse.org/modeling/m2m/downloads/index.php?proj ect=qvtoml
Looks like something wrong in your environment.
Sergey.
Koen Yskout wrote:
> is still uml:Model.
> Koen
> main() {
> name := 'myModel';
Re: [QVTO] Add UML stereotypes in out model [message #85386 is a reply to message #85371] Fri, 27 June 2008 09:15 Go to previous messageGo to next message
I get the same result. However, the myModel element is not stereotyped
with the 'Metamodel' stereotype.
The expected structure of the result is as follows (obtained by
stereotyping manually using the UML editor):
<xmi:XMI xmi:version="2.1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:Standard="http://www.eclipse.org/uml2/schemas/Standard/1"
xsi:schemaLocation="http://www.eclipse.org/uml2/schemas/Standard/1
pathmap://UML_PROFILES/Standard.profile.uml#_yzU58YinEdqtvbn fB2L_5w">
<uml:Model xmi:id="_Qa7OsEObEd2ILLVSvdBKHA" name="myModel">
<profileApplication xmi:id="_Qa7OsUObEd2ILLVSvdBKHA">
<eAnnotations xmi:id="_Qa7OskObEd2ILLVSvdBKHA"
</eAnnotations>
<appliedProfile
</uml:Model>
<Standard:Metamodel xmi:id="_aDB94ERKEd2j5e9SZqPV4w"
base_Model="_Qa7OsEObEd2ILLVSvdBKHA"/>
</xmi:XMI>
Notice that the stereotype application is at the same level as the
uml:Model element. It seems as if the transformation seems not to
serialize it correctly.
The problem seems related to the one described in the thread
"[QVTO]Incompatible input type 'modelparam::ResourceEObject', expected
'uml::Model'", but then in the other direction.
Koen
Sergey Boyko wrote:
> Hi Koen,
> </eAnnotations>
> </uml:Model>
> Sergey.
> Koen Yskout wrote:
>> stereotypes do not get saved in the resulting .uml file (minimal
>> example of such a transformation at the end of my post).
>> applications should appear as siblings of the uml:Model element (and
>> the root should become an xml:XMI node), but they are not in the file,
>> and the root node is still uml:Model.
>> Koen
>> main() {
>> name := 'myModel';
Re: [QVTO] Add UML stereotypes in out model [message #85398 is a reply to message #85386] Fri, 27 June 2008 11:18 Go to previous message
Hi Koen,
Debugging shows that there's limitation in our impl. that UML stereotype
operations rely on.
I've opened CR for that https://bugs.eclipse.org/bugs/show_bug.cgi?id=238805
Sergey.
> </eAnnotations>
> <appliedProfile
> </uml:Model>
> </xmi:XMI>
> Koen
> Sergey Boyko wrote:
>> Hi Koen,
>> <?xml version="1.0" encoding="UTF-8"?>
>> </eAnnotations>
>> <appliedProfile
>> </uml:Model>
>> Regards,
>> Sergey.
>> Koen Yskout wrote:
>>> Hi,
>>> file, and the root node is still uml:Model.
>>> Koen
>>> main() {
>>> name := 'myModel';
Previous Topic:[ATL] New vs Old Launch Configurations and Ganymede Missing Features
Next Topic:[ATL] Setting details of EAnnotations or maps in general
Current Time: Sun Oct 19 10:15:39 EDT 2025
Powered by FUDForum. Page generated in 0.06240 seconds
