Home » Archived » M2M (model-to-model transformation) » [ATL] EMF-VM and modelhandlers
[ATL] EMF-VM and modelhandlers [message #85280] Thu, 26 June 2008 11:33 Go to next message
Originally posted by: yann-riyou.gmail.com
I'm trying to launch a transformation in a standalone application with
the EMF-VM.
I was wondering about the modelhandlers. The only reference to them I
have seen in the EMF-VM source are commented lines.
Are the modelhandlers still used in the EMF-VM and if yes how do I use
them programmaticaly?
Yann
Re: [ATL] EMF-VM and modelhandlers [message #89228 is a reply to message #85280] Thu, 28 August 2008 08:03 Go to previous message
Yann wrote:
> the EMF-VM.
> Yann
Hi Yann,
I haven't explicitly tried it, but you should be able to use the EMF-VM
as an almost drop-in replacement for the standard VM, using the AtlVM
interface. This interface is implemented by the AtlEMFSpecificVM class.
Some example code that uses the AtlVM interface can be found here:
http://ssel.vub.ac.be/viewvc/UML2CaseStudies/uml2cs-instantm essenger-config-editor/src/be/ac/vub/uml2cs/instantmessenger /popup/actions/GenerateBuildFileAction.java?view=markup
Note that when you work outside the Eclipse environment, you have to
access the AtlEMFSpecificVM class directly instead of using AtlVM.getVM().
Dennis
Previous Topic:Detailed UML to less Detailed UML
Next Topic:[ATL] Abstract rule : do {}
Current Time: Tue Jul 01 13:35:11 EDT 2025
Powered by FUDForum. Page generated in 0.08873 seconds
