VE perspective not showing up [message #85122] |
Sun, 10 July 2005 04:08 |
Originally posted by: stevonsager.yahoo.com
I just upgraded to Eclipse 3.1 and installed the Visual Editor plugin
v1.1M2. My operating system is Windows XP SP2. For some reason I can't
see the Visual Editor perspective when I click Window > Open Perspective >
Other. But I can see the preferences options in my Preferences window.
Any ideas why I can't see the perspective?
Re: VE perspective not showing up [message #85169 is a reply to message #85122] |
Sun, 10 July 2005 12:48 |
Originally posted by: myersj.gmail.com
Stephen,
The Visual Editor does not have it's own perspective - it functions in
the Java or Java Browsing perspective. Simply create a new Visual Class
or use Open With->Visual Editor on a Java class. You should also try
using the latest VE integration build with Eclipse 3.1 rather than M2,
because there were a few incompatibilities with Eclipse right at the end
that don't work with M2. The final release of VE 1.1 will be out in a
couple weeks.
Hope this helps,
- Jeff
> window. Any ideas why I can't see the perspective?
Re: VE perspective not showing up [message #85263 is a reply to message #85169] |
Sun, 10 July 2005 22:23 |
Thanks Jeff,
I tried using the Open With -> Visual Editor approach and got the
preview window, but nothing else. I monkeyed around with it a bit more
and decided to try uninstalling the version of VE I had installed and
made sure I had the right EMF and GMF versions for the latest
integration build installed. After that I downloaded and installed the
latest integration build for VE and it works like a champ.
Thanks Again,
Stephen
Jeff Myers wrote:
> Stephen,
> couple weeks.
> Hope this helps,
> - Jeff
>> can't see the Visual Editor perspective when I click Window > Open
>> Perspective > Other. But I can see the preferences options in my
>> Preferences window. Any ideas why I can't see the perspective?
FUDForum. Page generated in 0.09115 seconds
