Dynamic properties view? [message #85080] |
Wed, 13 December 2006 10:58 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: tobk.gmx.de
is there a way to make the properties view dynamic in that sense, that the
displayed properties depend on some other property? The case is that I have
a property 'type' and depending on that property some other properties
shall be visible, e.g. when the type is 'timer' then there might be a
property 'starttime' and 'duration' and when the type is 'message' there
shall be an 'inMessage' and an 'outMessage'.
My first try was to add some conditions to the ItemProvider's
getPropertyDescriptor method. This worked well when opening the first
property source for a given class. Next I changed the singleton-getter in
the ItemProviderAdapterFactory, so it returns a new ItemProvider each for
each instance. Now each instance has it's own property sheet with
attributes depending on it's type, but the displayed properties still do
not change when the type is changed.
Can you give me an advice how to achive this?
thanks,
tobias
Re: Dynamic properties view? [message #85124 is a reply to message #85080] |
Wed, 13 December 2006 12:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
--------------020303000604020903050609
Tobias,
Comments below.
tobias wrote:
> Hello,
Yes, but that means the item providers need to be stateful and you need
to recompute the properties each time the item provider is asked for the
property descriptors.
It might be best for the property itself to provide properties so that
you would expand the property. For example, in GenBaseItemProvider we
define a specialized property descriptor class that does this:
protected Object createPropertyValueWrapper(Object object, Object
propertyValue)
return propertyValue instanceof EModelElement ?
new PropertyValueWrapper(adapterFactory, object, propertyValue,
propertyValue) :
super.createPropertyValueWrapper(object, propertyValue);
This ensures that all the property for the EModelElement are available
as nested properties.
Keep in mind that the properties are cached and computed only once, so
you'd need to change that behavior to compute them each time. Nested
properties seems like a better approach...
> thanks,
> tobias
<html>
<head>
</head>
Tobias,<br>
<br>
Comments below.<br>
<br>
tobias wrote:
<blockquote cite="midelom5d$a54$1@utils.eclipse.org" type="cite">
<pre wrap="">Hello,
displayed properties depend on some other property? </pre>
</blockquote>
the property descriptors.<br>
<pre wrap="">The case is that I have
</pre>
</blockquote>
define a specialized property descriptor class that does this:<br>
<br>
<small> protected Object createPropertyValueWrapper(Object object,
Object propertyValue)<br>
{<br>
return propertyValue instanceof EModelElement ?<br>
propertyValue) :<br>
super.createPropertyValueWrapper(object, propertyValue);<br>
}</small><br>
<br>
as nested properties.<br>
<pre wrap="">
</pre>
</blockquote>
properties seems like a better approach...<br>
<pre wrap="">
thanks,
tobias
</pre>
</blockquote>
<br>
</body>
</html>
--------------020303000604020903050609--
FUDForum. Page generated in 0.03936 seconds
