Home » Eclipse Projects » Remote Application Platform (RAP) » Can't build RAP from CVS head
Can't build RAP from CVS head [message #85047] Mon, 28 April 2008 01:20 Go to next message
Paul Norrie is currently offline Paul NorrieFriend
Member
I've tried building RAP from CVS head because we want to see if widget
pooling being disabled helps and I see M4 so far has removed widget
pooling.
But I can't build it. I edited org.eclipse.rap.feature/build.xml to
remove the non-RAP dependancies such as org.apache.commons.logging,
javax.servlet, etc.
However the build complains that org.eclipse.rap.rwt/build.xml is missing
(it is). Also missing is org.eclipse.rap.ui.workbench/build.xml.
Are these missing from CVS?
Re: Can't build RAP from CVS head [message #85197 is a reply to message #85047] Mon, 28 April 2008 12:24 Go to previous message
Benjamin Muskalla is currently offline Benjamin MuskallaFriend
Hi Paul,
how did you tried to build RAP? If you're refering to a headless build,
these build.xml files do not exist as we use the PDE build
infrastructure (see org.eclipse.rap.releng project). If you just want to
test your application, checking out RAP with the provided Team project
set from the website into your workspace should be enough.
Greets
Benny
Paul Norrie wrote:
> Hi
> pooling.
> javax.servlet, etc.
> missing (it is). Also missing is org.eclipse.rap.ui.workbench/build.xml.
Previous Topic:Preferences
Next Topic:Server Side Refresh
Current Time: Wed Jan 15 08:12:55 GMT 2025
Powered by FUDForum. Page generated in 0.03180 seconds
