Refreshing from EditPart [message #85040] |
Tue, 24 June 2003 22:31 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ar9357.sbc.com
is it possible to refresh view from EditPart.
with respect to logic example, how do i refresh the view.
thanks for any feedback or information on this.
Re: Refreshing from EditPart [message #85248 is a reply to message #85057] |
Wed, 25 June 2003 15:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Iam able to change the model and figure as you described.
But the image/label is overlapping with or without overriding
propertyChange method.
Eric Bordeau wrote:
> In the logic example, edit parts listen to their model with a
> PropertyChangeListener. refreshVisuals() is called from the
propertyChange()
> method and the view is refreshed in refreshVisuals().
Re: Refreshing from EditPart [message #85306 is a reply to message #85277] |
Wed, 25 June 2003 15:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Initially i have set figure with new Label("initial name").
Iam changing both figure and model dynammically by calling
figure.setImage(new Label("display name"))
model.setName("newname")
when i do this figure is getting set with "new name" but the "initial
name" retaining as it is.
or is it just enough to change the model and fire event programatically to
refresh the visuals.
Eric Bordeau wrote:
> What do you mean by "overlapping"?
> > propertyChange()
Re: Refreshing from EditPart [message #85337 is a reply to message #85306] |
Wed, 25 June 2003 15:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
"Anil" <ar9357@sbc.com> wrote in message news:bdcg01$bad$1@rogue.oti.com...
Always change only the model, and the figure will be refreshed to reflect
the model's contents.
This point is stressed in an upcoming article on getting started with GEF.
> > > propertyChange()
Re: Refreshing from EditPart [message #85347 is a reply to message #85337] |
Wed, 25 June 2003 15:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
yes i did get a reference to the model in EditPart and modified the same.
In order to reflect the changes i have overridden method called
propertyChange which calls refreshVisuals, but the view/figure is not
getting updated.
pls let me know whether the step followed are correct or not.
Randy Hudson wrote:
> \"Anil\" <ar9357@sbc.com> wrote in message news:bdcg01$bad$1@rogue.oti.com...
> > Initially i have set figure with new Label(\"initial name\").
> > figure.setImage(new Label(\"display name\"))
> > model.setName(\"newname\")
> > when i do this figure is getting set with \"new name\" but the \"initial
> > name\" retaining as it is.
> the model\'s contents.
> > Eric Bordeau wrote:
> > > What do you mean by \"overlapping\"?
> > > > propertyChange()
FUDForum. Page generated in 0.03967 seconds
