Home » Archived » Visual Editor (VE) » About Creation of Table
About Creation of Table [message #84967] Sun, 27 March 2005 14:40 Go to next message
Originally posted by: sushant.xxx.com
I have created one table using SWT widgets. Then i add column to it
, but these columns are not visible. And How can I add more Columns to
table ?
sushant
Re: About Creation of Table [message #84982 is a reply to message #84967] Sun, 27 March 2005 13:34 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Sushant,
The default behaviors of the SWT Table widget is pretty odd. You'll
have to change some of the properties to make columns show up as
expected. On the Table, change the headerVisible and linesVisible
properties to true, then on the TableColumn change the width property to
some reasonable value (e.g. 60).
In the next release of VE these options will be the defaults on dropping
a Table and TableColumn.
Hope this helps,
- Jeff
sushant wrote:
> table ?
> sushant
Re: About Creation of Table [message #87763 is a reply to message #84967] Wed, 20 April 2005 08:23 Go to previous messageGo to next message
after making a table visible what sushant wrote, the table appears but it
seems it has no border? The lines just end without border on the left side,
right side and bottom.
Is there a way to add a border to a table?
Thanks for any help,
best regards,
Mr. Burns
Re: About Creation of Table [message #87791 is a reply to message #87763] Wed, 20 April 2005 09:42 Go to previous messageGo to next message
Have you enabled the SWT Border style on the property sheet?
- Jeff
Mr. Burns wrote:
> Hello,
> best regards,
> Mr. Burns
Re: About Creation of Table [message #88017 is a reply to message #87791] Thu, 21 April 2005 03:48 Go to previous message
thanks, that solved my problem!
Re: About Creation of Table [message #606151 is a reply to message #84967] Sun, 27 March 2005 13:34 Go to previous message
Sushant,
Hope this helps,
- Jeff
sushant wrote:
> table ?
> sushant
Re: About Creation of Table [message #607186 is a reply to message #84967] Wed, 20 April 2005 08:23 Go to previous message
best regards,
Mr. Burns
Re: About Creation of Table [message #607188 is a reply to message #87763] Wed, 20 April 2005 09:42 Go to previous message
- Jeff
Mr. Burns wrote:
> Hello,
> best regards,
> Mr. Burns
Re: About Creation of Table [message #607204 is a reply to message #87791] Thu, 21 April 2005 03:48 Go to previous message
Previous Topic:Initialise an object inside of VE
Next Topic:Icons on the custom widgets in VE are not visible
Current Time: Thu Oct 30 17:36:05 EDT 2025
Powered by FUDForum. Page generated in 0.10796 seconds
