Home » Archived » BIRT » Missing jars for BIRT build
Re: Missing jars for BIRT build [message #7694 is a reply to message #7650] |
Thu, 10 February 2005 03:44 |
Originally posted by: rajeev.bigfoot.com
Is it available for download already? don't see it on esclipse.org. where
did you get it from?
"Thierry Lach" <thierry.lach@bbdodetroit.com> wrote in message
news:cue3b7$r50$1@www.eclipse.org...
> I get the following errors:
> Project org.eclipse.birt.report.engine is missing required library:
> 'org.eclipse.birt.report.engine/lib/Tidy.jar'
> Project org.eclipse.birt.report.designer.ui is missing required library:
> 'org.eclipse.birt.report.designer.ui/lib/jseditor.jar'
> Where can I find these jars?
Re: Missing jars for BIRT build [message #7756 is a reply to message #7737] |
Thu, 10 February 2005 14:57 |
thierry lach Messages: 26 Registered: July 2009 |
Junior Member |
Apparently my attachment was dropped.
Take the lines between ---clip--- and put them into a file called birt.psf.
You can use that as a team project set.
---clip---
<psf version="2.0">
<provider id="org.eclipse.team.cvs.core.cvsnature">
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/birt,org.eclipse.birt.cha rt/or
g.eclipse.birt.chart.device.extension,org.eclipse.birt.chart .device.extensio
n"/>
<project
g.eclipse.birt.chart.engine,org.eclipse.birt.chart.engine"/ >
<project
g.eclipse.birt.chart.engine.extension,org.eclipse.birt.chart .engine.extensio
n"/>
<project
g.eclipse.birt.chart.reportitem,org.eclipse.birt.chart.repor titem "/>
<project
g.eclipse.birt.chart.shared,org.eclipse.birt.chart.shared"/ >
<project
g.eclipse.birt.chart.ui,org.eclipse.birt.chart.ui"/>
<project
g.eclipse.birt.chart.ui.extension,org.eclipse.birt.chart.ui. extension "/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/birt,org.eclipse.birt.cor e/org
..eclipse.birt.core,org.eclipse.birt.core"/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/birt,org.eclipse.birt.dat a/org
..eclipse.birt.data,org.eclipse.birt.data"/>
<project
..eclipse.birt.report.data.oda.jdbc,org.eclipse.birt.report. data.oda.jdbc "/>
<project
..eclipse.birt.report.data.oda.jdbc.ui,org.eclipse.birt.repo rt.data.oda.jdbc.
ui"/>
<project
reference=" 1.0,:pserver:dev.eclipse.org:/home/birt,org.eclipse.birt.rep ort/o
rg.eclipse.birt.report.designer.core,org.eclipse.birt.report .designer.core "/
<project
rg.eclipse.birt.report.designer.tests,org.eclipse.birt.repor t.designer.tests
<project
rg.eclipse.birt.report.designer.ui,org.eclipse.birt.report.d esigner.ui "/>
<project
rg.eclipse.birt.report.engine,org.eclipse.birt.report.engine "/>
<project
rg.eclipse.birt.report.engine.emitter.fo,org.eclipse.birt.re port.engine.emit
ter.fo"/>
<project
rg.eclipse.birt.report.engine.emitter.html,org.eclipse.birt. report.engine.em
itter.html"/>
<project
rg.eclipse.birt.report.model,org.eclipse.birt.report.model"/ >
<project
rg.eclipse.birt.report.viewer,org.eclipse.birt.report.viewer "/>
<project
rg.eclipse.birt-feature,org.eclipse.birt-feature"/>
</provider>
</psf>---clip---
news:cufs8q$2nm$1@www.eclipse.org...
> I've checked it out of CVS. I've attached a Team Project Set of what I've
> got.
> "Rajeev Madnawat" <rajeev@bigfoot.com> wrote in message
> news:cuelct$tbs$1@www.eclipse.org...
where
library:
Current Time: Thu Dec 26 18:55:04 GMT 2024
Powered by FUDForum. Page generated in 0.11299 seconds
