Home » Newcomers » Newcomers » Launch Configurations
Launch Configurations [message #84794] Fri, 08 July 2005 13:57 Go to next message
Originally posted by: justin.adam.miller.gmail.com
When creating launch configurations, is it possible to create one and be
able to reuse it for any java class (that has a main fcn in it)? What I
mean is, if I have a standard set of flags to pass to the jvm, I would
just like to create one configuration, and use it for multiple java
programs, obviating the need to create duplicates of that configuration
when all that's changed is the source file containing the main function.
Is this possible?
Thanks in advance!
Justin
Re: Launch Configurations [message #84810 is a reply to message #84794] Fri, 08 July 2005 14:06 Go to previous message
You cannot do exactly what you are asking but if you just need a standard
set of args to the JVM check
out:
Window>Preferences>Java>Installed JREs
Hit Edit for your particular JRE
Set the "Default VM Arguments" to be used when executing with this VM
HTH
Darins
"Justin" <justin.adam.miller@gmail.com> wrote in message
news:608eddca7a6bdb86c283c6ca22def028$1@www.eclipse.org...
> Is this possible?
> Thanks in advance!
> Justin
Previous Topic:Strange Problem Causing Hard Exit
Next Topic:clearing out the confusion with rc4, stable, integration
Current Time: Fri Oct 17 23:16:30 EDT 2025
Powered by FUDForum. Page generated in 0.08755 seconds
