Home » Eclipse Projects » GEF » EditDomain and CTRL problem
EditDomain and CTRL problem [message #84758] Mon, 23 June 2003 08:37 Go to next message
Originally posted by: scheglov_ke.nlmk.ru
I use CTRL for special handling of mouse event, plus
I draw some figures different, when CTRL is pressed. All
works, but recently I noticed strange behavior. When I click
with CTRL pressed on figure on my layer, I don't receive then
keyDown/keyUp until I move mouse on any edit part. It seams, that
layer lost focus or something like this. How can I avoid this?
Here is how I handle keyDown/keyUp and one mouse event:
public void keyDown(KeyEvent keyEvent, EditPartViewer viewer) {
m_StateMask = keyEvent.stateMask;
if (keyEvent.keyCode == SWT.ESC) {
DesignerEditor editor = (DesignerEditor) getEditorPart();
List selection = editor.getGraphicalViewer().getSelectedEditParts();
if (selection.size() > 0) {
EditPart edit = (EditPart) selection.get(0);
if (edit.getParent() != null)
editor.getGraphicalViewer().select(edit.getParent());
return;
if (keyEvent.keyCode == SWT.CTRL) {
m_StateMask |= SWT.CTRL;
redraw();
return;
super.keyDown(keyEvent, viewer);
public void keyUp(KeyEvent keyEvent, EditPartViewer viewer) {
m_StateMask &= ~SWT.CTRL;
redraw();
return;
super.keyUp(keyEvent, viewer);
private void redraw() {
editor.getGraphicalViewer().getControl().redraw();
public void mouseDown(MouseEvent mouseEvent, EditPartViewer viewer) {
m_StateMask = mouseEvent.stateMask;
mouseEvent.stateMask &= ~SWT.CTRL;
super.mouseDown(mouseEvent, viewer);
And here is code, where I create layer, after clicking on which I don't
receive keyboard events:
protected void configureGraphicalViewer() {
super.configureGraphicalViewer();
GraphicalViewer viewer = getGraphicalViewer();
FreeformGraphicalRootEditPart rootEditPart = new FreeformGraphicalRootEditPart() {
protected void createLayers(LayeredPane layeredPane) {
super.createLayers(layeredPane);
layeredPane.add(new FreeformLayer(), DesignerEditDomain.LAYER_CLICKABLE);
viewer.setRootEditPart(rootEditPart);
viewer.setEditPartFactory(new GraphicalPartFactory());
FigureCanvas canvas = (FigureCanvas) viewer.getControl();
canvas.setBackground(ColorConstants.gray);
(canvas).setScrollBarVisibility(FigureCanvas.ALWAYS);
viewer.setKeyHandler(new GraphicalViewerKeyHandler(viewer).setParent(getCommonKeyHand ler()));
ContextMenuProvider provider = new DesignerContextMenuProvider(viewer, getActionRegistry());
viewer.setContextMenu(provider);
SY, Konstantin.
Re: EditDomain and CTRL problem [message #84951 is a reply to message #84758] Tue, 24 June 2003 05:59 Go to previous messageGo to next message
Konstantin Scheglov <scheglov_ke@nlmk.ru> wrote:
Ok, problem is not in CTRL.
I want to handle mouse click on figure, created on additional
layer. I can do this. But I want prevent GEF from handling this
mouse click, so I call event.consume(). And after this GEF thinks,
that all events should be handled only by this figure. :-(
How can I prevent this?
> return;
> redraw();
> return;
> redraw();
> return;
> SY, Konstantin.
SY, Konstantin.
Re: EditDomain and CTRL problem [message #84966 is a reply to message #84951] Tue, 24 June 2003 07:56 Go to previous messageGo to next message
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> wrote in message
news:Dy#wOdjODHA.3608@fairy.ao.nlmk...
This is by design. Otherwise, your figure wouldn't receive the mouse up.
Once mouse up is received, the mouse capture is released.
> > return;
> > redraw();
> > return;
> > redraw();
> > return;
don't
> > SY, Konstantin.
> SY, Konstantin.
Re: EditDomain and CTRL problem [message #85130 is a reply to message #84966] Wed, 25 June 2003 05:17 Go to previous messageGo to next message
Yes, but I move figure, when mouse pressed on it.
Can I tell GEF, that I don't need mouse anymore, and it can pass
mouse and keyboard events to EditPart's?
>> > return;
>> > redraw();
>> > return;
>> > redraw();
>> > return;
> don't
>> > SY, Konstantin.
>> SY, Konstantin.
SY, Konstantin.
Re: EditDomain and CTRL problem [message #85159 is a reply to message #85130] Wed, 25 June 2003 10:13 Go to previous messageGo to next message
news:fvbReqvODHA.3496@fairy.ao.nlmk...
up.
Yes, release the mouse button, and mouse and keyboard events will go to
EditPart. I don't understand what is happening, so you'll have to debug
this yourself. I know that this working as designed. There are
applications that receive mousedown on figures to expand/collapse a
container, and it is working.
Re: EditDomain and CTRL problem [message #85422 is a reply to message #85159] Thu, 26 June 2003 01:46 Go to previous message
Ok, problem is that when I release button, mouse if already not in figure,
because figure was moved to other place in mouse down event.
I solved problem by not using event.consume(), I just don't pass this
event in EditDomain.
SY, Konstantin.
Previous Topic:Automatic Tests for Graphical Editors
Next Topic:Editor does not close when we close the project
Current Time: Fri Apr 25 20:24:49 EDT 2025
Powered by FUDForum. Page generated in 0.06063 seconds
