Re: Query question [message #85048 is a reply to message #84973] |
Thu, 27 October 2005 21:50 |
Mr. Burns,
Marty is correct. You can modify the whole query in the BeforeOpen method
if you need to do something like append to the SQL.
Jason Weathersby
BIRT PMC
"Marty Jones" <marty_jones@dailyaccess.com> wrote in message
news:djrdl2$ur8$1@news.eclipse.org...
> Mr. Burns,
> I am new to Birt but I believe you have to specify the "Amount > ?" in
> your where clause of your query and just specify the actual parameter
> within the parameter window.
> "Mr. Burns" <Mr._Burns@web.de> wrote in message
> news:djq87l$8tq$1@news.eclipse.org...
>> Hello,
>> I tried to use following query in a dataset:
>> SELECT * FROM MyTable WHERE ?
>> And the I added a parameter called dsParam1 with default value:
>> "Amount > 1000"
>> So the query should be combined by BIRT to:
>> SELECT * FROM MyTable WHERE Amount > 1000
>> If I test the result preview there is no result. Only the column headers
>> are shown, now result even if there are records with Amount > 1000.
>> So my quetions are those parameters allowed?
>> Thanks a lot for help!
FUDForum. Page generated in 0.02920 seconds
