Home » Eclipse Projects » Remote Application Platform (RAP) » WorkbenchWindow#getWorkbench uses the PlatformUI singleton (feature request)
WorkbenchWindow#getWorkbench uses the PlatformUI singleton (feature request) [message #84669] Fri, 25 April 2008 02:25 Go to next message
Originally posted by: dpryadkin.rocketsoftware.com
I would like to ask the developer team whether is it possible to alter
WorkbenchWindow#getWorkbench in the next release of RAP.
I'm using "window.getWorkbench().getDisplay()" to resolve the display
from non-ui threads.
Dmitry
Re: WorkbenchWindow#getWorkbench uses the PlatformUI singleton (feature request) [message #84684 is a reply to message #84669] Fri, 25 April 2008 02:41 Go to previous messageGo to next message
Hi Dimitry,
I'm pretty sure they won't do this because IWorkbench is RCP-API and one
of the main concepts of RAP is to be close to the RCP-API (SWT, JFace,
Workbench) as possible.
And even if so, what should be the semantic of this method? There exist
as many displays and workbench instances as sessions in your
application. The easiest way to access a display object from a non-ui
thread is to pass it to the thread when creating it and than call it
when needed.
Hope this helps,
Stefan.
Dmitry schrieb:
> Dmitry
Re: WorkbenchWindow#getWorkbench uses the PlatformUI singleton (feature request) [message #84699 is a reply to message #84684] Fri, 25 April 2008 02:56 Go to previous messageGo to next message
Stefan,
To put it simple, I wish the WorkbenchWindow object to store the
reference to IWorkbench at the construction stage:
public WorkbenchWindow(int number) {
super(null);
this.number = number;
// Make sure there is a workbench. This call will throw
// an exception if workbench not created yet.
final IWorkbench workbench = PlatformUI.getWorkbench();
---> lets say: m_workbench = PlatformUI.getWorkbench();
and then getWorkbench() will be able to return this reference instead of
calling PlatformUI singleton.
I think that would be more correct with respect to RAP concepts. Right?
Dmitry
Re: WorkbenchWindow#getWorkbench uses the PlatformUI singleton (feature request) [message #84731 is a reply to message #84699] Fri, 25 April 2008 04:51 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
Hm,
why don't you use window.getShell().getDisplay()?
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Dmitry [mailto:dpryadkin@rocketsoftware.com]
Bereitgestellt: Freitag, 25. April 2008 08:56
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: WorkbenchWindow#getWorkbench uses the PlatformUI singleton
(feature request)
Betreff: Re: WorkbenchWindow#getWorkbench uses the PlatformUI singleton
(feature request)
Stefan,
super(null);
Dmitry
Re: WorkbenchWindow#getWorkbench uses the PlatformUI singleton (feature request) [message #84759 is a reply to message #84731] Fri, 25 April 2008 05:05 Go to previous message
viola! Thanks. Just stuck to getWorkbench() as I am not really
proficient in RCP either.
Previous Topic:CoolBar item with image and bottom text
Next Topic:Refresh in Browser removes branding
Current Time: Tue Nov 04 14:47:00 EST 2025
Powered by FUDForum. Page generated in 0.03625 seconds
