Java UI Development [message #84386] |
Mon, 11 August 2003 08:39 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mohan.bv.in.bosch.com
I want to develop forms in Java. Does Eclipse IDE provide functionality
for rapid development of UI Components(Swings) like drag and drop
functionality of components, form editor... as in JBuilder.
If yes how to use such a feature.
Mohan
Re: Java UI Development [message #84434 is a reply to message #84386] |
Mon, 11 August 2003 09:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No.
Dani
>Thanks,
>Mohan
Re: Java UI Development [message #85381 is a reply to message #84673] |
Wed, 13 August 2003 14:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Scott Stanchfield![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=scott%40javadude.com) Messages: 263 Registered: July 2009 |
In article <bh8i6i$ku$1@eclipse.org>, Rosés) says...
> [Scott, have you plans to release anything?]
> Francesc Rosés
No plans yet... I've got a demo at work next week (unrelated to
Penumbra), and after that things free up a bit. I'm taking two weeks off
at the start of Sept and plan to dedicate that time to Penumbra.
For the initial release, I'm going to concentrate on just AWT/Swing.
I'll be able to support SWT with the same framework, but I want to get
something out as soon as possible.
I've also been thinking about how the same framework should be able to
support WYSIWYG for HTML, JSP, JSF, Struts w/ pageflows, etc. quite
easily. Not in the initial release, but they should be pretty easy add-
ins, whether I or someone else creates them.
I've been spending a lot of time on the property sheet -- the default
eclipse property sheet isn't flexible enough for some of the things I
want to do, so I've made a copy and extended it. Once I get it "just
right" I'll see if there's any way I can either merge it with the
original or provide it as an alternative opensource property sheet
implementation.
<rant>
I really wish folks wouldn't make so many classes & methods in Eclipse
non-public or final -- I only needed to modify a couple of classes, but
due to the non-public nature of many of the involved classes I had to
copy about 10 classes into my own package... See my "Rules of Reuse"
article at http://javadude.com/articles for more on this. If it's in an
"internal" package, that's already warning that it may change, and if I
depend on it, it's my problem if it changes, so why not just leave it
open to begin with?
No need to reply to this rant, and not intended as flamebait -- just
venting... Grr Arg
</rant>
Hopefully after the first two weeks of Sept I'll at least be able to
post some screen shots (I still want to keep some stuff secret for now).
Take care,
-- Scott
Scott Stanchfield scott@javadude.com http://javadude.com
I haven't gotten *any* spam since joining http://knowspam.net!
Lead author of "Effective VisualAge for Java, Version 3"
http://javadude.com/evaj
Visit for Java Enlightenment! http://www.jguru.com
Re: Java UI Development [message #85585 is a reply to message #85381] |
Wed, 13 August 2003 22:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Francesc Rosés![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=froses%40menta.net) Messages: 213 Registered: July 2009 |
Thanks for your info, Scott!
> <rant>
> open to begin with?
> venting... Grr Arg
> </rant>
I AGREE! Please read the article :)
> ============================================================ =Scott
FUDForum. Page generated in 0.03974 seconds
