Getting unexpected exceptions in multiple plugins [message #7468] |
Mon, 28 April 2003 12:21 |
I have added both the oXygen XML editor plugin and the Jalopy
pretty-printer plugin to Eclipse 2.1 using Client VM (1.4.0-b92 mixed
mode) under RH Linux 7.3. Both cause eclipse to crash with the following
messge:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4DEFF1F4
Function=_XtSortPerDisplayList+0x84
Library=/usr/X11R6/lib/libXt.so.6
oXygen's tech support say they don't use any native code at all (100% pure
Java) and I presume that's true for Jalopy as well. Any idea what's going
on and what it is I need to fix?
Rob Tanner
Linfield College
McMinnville, Oregon
FUDForum. Page generated in 0.03824 seconds
