[ATL] UML stereotype problem [message #83132] |
Sat, 31 May 2008 09:54 |
Originally posted by: hr_mi.live.cn
Hi everyone,
I make a helper to check the stereotype of a class ,the code is as
following :
helper context UML!Class def: hasStereotype(stereotype : String) : Boolean =
self.getAppliedStereotypes()->exists(e|e.name=stereotype);
My code is like this :
module uml2bpel; -- Module Template
create OUT : BPEL from IN : UML;
rule toProcess{
from
u : UML!"uml::Activity",c : UML!"uml::Class"
(u.oclIsTypeOf(UML!"uml::Activity") and
c.oclIsTypeOf(UML!"uml::Class") and c.name='onlinesale' and
c.hasStereotype('Process')
to
p : BPEL!Process(......
I select the UML metamodel by URI:http://www.eclipse.org/uml2/2.0.0/UML
but it dosen't work correctly.
Anyone can help me ??
Thanks very much.
Best for wishes!
Re: [ATL] UML stereotype problem [message #83147 is a reply to message #83132] |
Sat, 31 May 2008 10:39 |
Originally posted by: me.urszeidler.de
unique schrieb:
> Hi everyone,
> following :
Looks ok, but "UML!Class" means this context works only for UML!Class,
you want element.("UML!Element")
Because in the matching phase your guard "c.hasStereotype('Process')"
will be testes with all elements and not all of them are "UML!Class".
If you stick to your helper your guard should be :
if u.oclIsTypeOf(UML!"uml::Activity") and
c.oclIsTypeOf(UML!"uml::Class") then c.name='onlinesale' and
else
false
endif
> rule toProcess{
> from
> to
> Thanks very much.
> Best for wishes!
Re: [ATL] UML stereotype problem [message #83179 is a reply to message #83147] |
Sat, 31 May 2008 11:31 |
urs zeidler 写道:
> unique schrieb:
>> Hi everyone,
>> following :
> else
> false
> endif
>> rule toProcess{
>> from
>> to
>> Thanks very much.
>> Best for wishes!
Hi urs zeidler,
Thanks for your help.
I acted as you advise, but it didn't work correctly. I mean that I
have a class named "onlinesale" and it has a stereotype named "Process"
in fact, but when I run my code , it didn't test it successfully .
what would the problem be ?
Thanks !
Re: [ATL] UML stereotype problem [message #83192 is a reply to message #83179] |
Sat, 31 May 2008 12:32 |
unique schrieb:
> urs zeidler 写道:
>> unique schrieb:
>>> Hi everyone,
>>> following :
>> else
>> false
>> endif
>>> rule toProcess{
>>> from
>>> to
>>> Thanks very much.
>>> Best for wishes!
> Hi urs zeidler,
> Thanks !
try this helper
helper def : isStereotypeApplied (invar : UML2!"uml::Element", name
:String) : Boolean =
if invar.oclIsUndefined() then
false
else
not invar.getAppliedStereotypes() -> select(s| s.name=name)-> isEmpty()
endif
greetings,urs.
Re: [ATL] UML stereotype problem [message #83203 is a reply to message #83192] |
Sat, 31 May 2008 13:37 |
Originally posted by: amehmood.sophia.inria.fr
this simple helper also works well:
-- Checks if the given stereotype is applied or not.
helper context UML2!Element def : isStereotypeApplied(name :
String):Boolean =
not self.getAppliedStereotypes()->select(p | p.name = name).isEmpty();
and call it like this:
rule ABC{
from
s : UML2!Element (s.isStereotypeApplied('MyStereotype'))
Re: [ATL] UML stereotype problem [message #83210 is a reply to message #83203] |
Sun, 01 June 2008 03:33 |
Aamir Mehmood 写道:
> String):Boolean =
> rule ABC{
> from
Hi Aamir Mehmood,
Thanks for your help .I acted as you advised , I rewrite the code as
following :
helper context UML!Class def : isStereotypeApplied(name :
String):Boolean =
rule toProcess{
from
u : UML!"uml::Activity", c :
UML!"uml::Class"(u.oclIsTypeOf(UML!"uml::Activity") and
if c.oclIsTypeOf(UML!"uml::Class") and c.name='onlinesale'
then c.isStereotypeApplied('BPEL::Process')
else false
endif
to
p :BPEL!"model::Process"(...)
but when I debug it ,the result is empty .It didn't test the class named
"onlinesale" having stereotype "Process".
What's the problem??
best regards!
Re: [ATL] UML stereotype problem [message #83233 is a reply to message #83192] |
Sun, 01 June 2008 03:52 |
--------------060808040303000502020308
Content-Type: text/plain; charset=GB2312
urs zeidler д
Re: [ATL] UML stereotype problem [message #83261 is a reply to message #83233] |
Sun, 01 June 2008 10:29 |
> rule toProcess{
> from
> then c.isStereotypeApplied(c,'Process')
> else false
> endif
> to
> I annex my *.atl file , the meta-models and models ,would you please
> check it ??
This helper has no context, so you need to call it with
thisModule.isStereotypeApplied(c,'Process').
greetings, urs.
Re: [ATL] UML stereotype problem [message #83427 is a reply to message #83261] |
Mon, 02 June 2008 12:08 |
urs zeidler 写道:
>> rule toProcess{
>> from
>> else false
>> endif
>> to
>> check it ??
> greetings, urs.
Hi urs ,
I really thank you for you help . I acted it , but it didn't test the
calss what I wanted to get. Actually there is a class named 'onlinesale'
having stereotype named "Process",but the result is empty , I cannot
find where the problem is .
Best regards!
FUDForum. Page generated in 0.04089 seconds
