use complex type in service - Type is referenced but not defined [message #83015] |
Sat, 12 March 2005 02:35  |
Originally posted by: nospam_baltov.gmail.com.bg
Can anybody help me?
I am trying to build a web service returning list of objects. The interface
of service is:
public interface IcheckSrv extends Remote{
public ProtokoliList getData(String klientName, String catNumber, String
serNumber);
where
public class ProtokoliList {
private ProtokoliServiceVO[] list = null;
public ProtokoliServiceVO[] getList(){
return list;
When I try to generate the service the folowing error message is shown:
IWAB0399E Error in generating Java from WSDL java.io.IOException: Type
{http://service.sb.bg}ProtokoliServiceVO is referenced but not defined.
Where should I define it!?!?
I am using Eclipse 3.1 M5 and WTP 1.0 M3
thanks
Re: use complex type in service - Type is referenced but not defined [message #86934 is a reply to message #83015] |
Thu, 24 March 2005 13:11  |
Java Web services get generated and deployed via two code generation passes.
First, the tools drive Java2WSDL to generate WSDL from your Java. Second, the
tools drive WSDL2Java to generate Java deployment code, descriptors, etc. from
your WSDL. First guess this is a problem either with the WSDL generated by
Java2WSDL, or with WSDL2Java's ability to handle the WSDL.
A quick test would be to run Apache Axis' WSDL2Java command directly on the
WSDL that should be lurking in your target project in your workspace. You're
also welcome to open a new Web Tools bug [1] against the jst.ws component. If
you do, please attach either your WSDL or you Java code.
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols
Cheers - CB.
stef B wrote:
> Hello,
> of service is:
> serNumber);
> where
> return list;
> thanks
FUDForum. Page generated in 0.04334 seconds
