| ATL: reserved keyword name clash [message #82701] | Thu, 29 May 2008 15:02  |  |
| Eclipse User  |  |  |  |  | Originally posted by: min.kong.morganstanley.com
 In my input metamodel called "model", I have oclTypes with names:
 "Integer", "Boolean", "String".
 In a rule that I want to execute, I have, for instance:
 if (self.oclIsKindOf(model!Integer))....
 This line is invalid, because ATL doesn't consider modx!Integer a valid
 oclType NAME, as "Integer" is a reserved keyword.
 How should one get around problem like this, where in a metamodel, some
 oclType names clash with ATL reserved keywords?
 Min
| Re: ATL: reserved keyword name clash [message #82802 is a reply to message #82701] | Fri, 30 May 2008 03:35   |  |
| Eclipse User  |  |  |  |  | Originally posted by: r.c.ladan.tue.nl
 Min wrote:
 The easiest solution would be to change the metamodel, if that is possible.
 Rene
| Re: ATL: reserved keyword name clash [message #82851 is a reply to message #82802] | Fri, 30 May 2008 04:35   |  |
| Eclipse User  |  |  |  |  | Hello,
 There is another workaround you can try :
 model!"Integer" instead of model!Integer
 William
 Rene Ladan a écrit :
 > Min wrote:
 >> valid oclType NAME, as "Integer" is a reserved keyword.
 >> some oclType names clash with ATL reserved keywords?
 > Rene
FUDForum. Page generated in 0.03537 seconds
