Running Ant [message #670] |
Sat, 19 April 2003 23:41 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ewoojava.hotmail.com
I can compile an eclipse created Java Project no problem, But when I tried
to Run Ant... on a build.xml I got the following error saying my JAVA_HOME
does not point to the JDK. I check my JAVA_HOME environment variable in
my Win 2000 machine, it has "c:\Program Files\j2sdk1.4.1_02". Would
anyone know what is my problem?
[javac] BUILD FAILED: file:D:/eclipse/workspace/Jade3/build.xml:66:
Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
Re: Running Ant [message #908 is a reply to message #810] |
Sun, 20 April 2003 03:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks.
Eugene
Darin Swanson wrote:
> You need to add a jdk tools.jar to the Ant runtime classpath using the Ant
> preference pages.
> Another option is to start Eclipse using the -vm arg so that Eclipse is
> launched using your JDK install VM (your JAVA_HOME). This way Eclipse will
> automatically add
> the tools.jar to the Ant runtime classpath.
> HTH
> Darins
> "Eugene Woo" <ewoojava@hotmail.com> wrote in message
> news:b7sms1$4th$1@rogue.oti.com...
Re: Running Ant [message #67737 is a reply to message #810] |
Thu, 26 June 2003 00:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: killerapp.sf.net
I added tools.jar (tried 2 different recent JDK's) and I get the
following error:
BUILD FAILED: java.lang.UnsupportedClassVersionError:
com/sun/tools/javac/Main (Unsupported major.minor version 48.0)
> preference pages.
> automatically add
> HTH
> Darins
Re: Running Ant [message #68437 is a reply to message #67737] |
Thu, 26 June 2003 23:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: darin_swanson.oti.com
The tools.jar you are adding is for a different VM version.
It looks like you are trying to use a 1.4 tools.jar with a 1.3 VM
Darins
"Killer App" <killerapp@sf.net> wrote in message
news:bddf2v$7hq$1@rogue.oti.com...
> following error:
Ant
> > preference pages.
will
> > automatically add
> > HTH
> > Darins
tried
JAVA_HOME
FUDForum. Page generated in 0.03511 seconds
