Error opening Web Services explorer [message #82314] |
Fri, 11 March 2005 01:48 |
Originally posted by: footh.yahoo.com
When I attempt to launch the Web Services explorer through eclipse, I
receive an error that says:
"The drive is not ready for use; its door may be open. Please check drive
A: and make sure that a disk is inserted and that that drive door is
closed."
Then, I must end eclipse via the taskbar because the message will keep
popping up even if I press cancel. I don't have a floppy drive on this
machine, and therefore, no valid A: drive. Why would the WSE be looking for
the A: drive anyway? In any case, is there another way to launch WSE, like
perhaps a command line?
JF
Re: Error opening Web Services explorer [message #82746 is a reply to message #82314] |
Fri, 11 March 2005 16:44 |
Raymond Lai Messages: 5 Registered: July 2009 |
Junior Member |
Hi JF,
I believe the Web Services explorer is actually a web app using a internal
bundled tomcat server. So it's probably not easy to launch it in command
line.
What build are you using? M3? Did you install the Web Services related
jars? I usually launch the explorer by File -> Import -> Webservice. And
it's working fine in a Linux laptop without a floppy drive.
Raymond
> closed."
> JF
Re: Error opening Web Services explorer [message #82934 is a reply to message #82746] |
Fri, 11 March 2005 22:20 |
Raymond,
Thanks for your response. The problem was, I don't have a floppy drive, but
I still had an A: drive reference in explorer. So, I just disabled the
floppy drive through device manager, the A: drive disappeared and everything
works now.
JF
"Raymond Lai" <raymond.lai@utoronto.ca> wrote in message
news:pan.2005.03.11.16.44.12.869689@utoronto.ca...
> Hi JF,
> line.
> Cheers,
> Raymond
drive
> > closed."
for
like
> > Thanks,
> > JF
FUDForum. Page generated in 0.03896 seconds
