Home » Archived » Test and Performance Tools Platform (TPTP) » Test TPTP menu options not available
Test TPTP menu options not available [message #82224] Thu, 31 August 2006 12:30 Go to next message
Originally posted by: pamelaw.amdocs.com
This is what I've done.
1) Installed Agent controller to c:\TPTPAC.
2) Installed the following to c:\Program files\eclipse.
eclipse-SDK-3.2-win32.zip, emf-sdo-SDK-2.1.2.zip, xsd-SDK-2.1.2.zip,
tptp.runtime-TPTP-4.2.0.zip, tptp.sdk-TPTP-4.2.0.zip,
org.eclipse.tptp.test.auto-TPTP-4.2.0.zip.
3) File | New | Project | Plug-in : to create a project for my test code
4) File | New | Folder : create a folder for resource files
5) File | New | Other : there is no Test folder and no entries for
Automated GUI test JUnit Test, recording etc... any idea on what I did
wrong?
THANKS, Pamela
Re: Test TPTP menu options not available [message #82248 is a reply to message #82224] Thu, 31 August 2006 16:02 Go to previous messageGo to next message
Randy D. Smith is currently offline Randy D. SmithFriend
Pamela Morris wrote:
> This is what I've done. 1) Installed Agent controller to c:\TPTPAC. 2)
> org.eclipse.tptp.test.auto-TPTP-4.2.0.zip. 3) File | New | Project |
> wrong?
> THANKS, Pamela
You've got the wrong version of EMF/XSD; from the Requirements section
of the Downloads page:
Eclipse Modeling Framework (EMF and XSD) SDK 2.2.0
Suggestion: if you're going to use Eclipse-SDK-3.2, just install that,
run Eclipse, go to Help => Software Updates => Find and install new
components => select Callisto Discovery Site => select TPTP part you
want, then Select Required, and you'll get what you nee dwith the right
components.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: Test TPTP menu options not available [message #82263 is a reply to message #82248] Thu, 31 August 2006 17:20 Go to previous messageGo to next message
Yeah, i tried that, but it won't connect, always comes back with network
problems, tried several times. I'm sure and issue on my end, but getting
my IT to address it maybe futile. So I see my error with the version, are
you suggesting there are other dependencies besides xsd, sdo and emf for a
manual install? THANKS Pamela
Re: Test TPTP menu options not available [message #82278 is a reply to message #82263] Thu, 31 August 2006 19:13 Go to previous message
> are you suggesting there are other dependencies besides xsd, sdo and emf
> for a manual install? THANKS Pamela
No, I'm saying you got 2.1.2, and you needed 2.2.0. Download and install
2.2.0, then run eclipse -clean and see if you're good to go.
Re: updates -- Windows => Preferences => Install/Update has a firewall
proxy workaround if you know your proxy settings.
RDS
Previous Topic:Any plans for "Profile As Junit Plug-in Test"?
Next Topic:extending TPTP UI
Current Time: Fri Dec 27 01:16:34 GMT 2024
Powered by FUDForum. Page generated in 0.03439 seconds
