Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » CDO: Oracle JDBC driver
CDO: Oracle JDBC driver [message #7347] Tue, 13 December 2005 15:53 Go to next message
Originally posted by: tvalence1.cox.net
Hi Eike,
I am trying to use Oracle in conjunction with CDO to persist a model that
has been previously saved/accessed via CDO/MySQL.
I tried creating a fragment, org.eclipse.net4j.jdbc.oracle (i.e. similar to
org.eclipse.net4j.jdbc.mysql) to enable CDO to interact with the Oracle JDBC
driver, but it failed to properly validate in
org.eclipse.net4j.spring.db.ContextClassLoaderDataSource().
I was able to workaround the above class loader issue, but now an exception
is being thrown in
org.eclipse.net4j.dbgen.impl.SqlDialectImpl.initTypeMappings ().
Do you have any advice/source on how to properly setup CDO to use the Oracle
Thin Client JDBC driver?
Any help would be greatly appreciated.
Thanks!
- Ted
Re: CDO: Oracle JDBC driver [message #7358 is a reply to message #7347] Thu, 15 December 2005 05:04 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Hi Ted,
Starting with a copy of the jdbc.mysql fragment is a godd idea.
I did it for Oracle long time ago and it worked. If only I could
find it, I'd send it to you.
See my other comments inline...
Cheers
/Eike
TVal schrieb:
> Hi Eike,
Just to clarify, you don't mean some data migration feature?
I assume Mysql was simpler to test with and now you want to switch to Oracle
and start with new data.
What was the reason? (copy log)
> is being thrown in
Can I see the stack trace?
Let's have a look at your logs and if you want to, you can send me the fragment...
Re: CDO: Oracle JDBC driver [message #7401 is a reply to message #7358] Thu, 15 December 2005 14:16 Go to previous messageGo to next message
Eike,
Attached is the jdbc.oracle fragment (minus the actual Oracle driver) and
the debug log from the test.
Note that I had to include the Oracle driver in my application's startup
plug-in to resolve a classloader issue. Hopefully, the resolution of the
fragement issue described below will also resolve the classloader problem.
BTW, my proof-of-concept was based on MySql, but my target environment runs
on Oracle.
Cheers.
- Ted
"Eike Stepper" <stepper@sympedia.de> wrote in message
news:dnrf31$637$1@news.eclipse.org...
> Hi Ted,
> Cheers
> /Eike
> TVal schrieb:
>> Hi Eike,
> Oracle
>> to
>> JDBC
>> exception
>> is being thrown in
>> Oracle
> fragment...
Re: CDO: Oracle JDBC driver [message #7413 is a reply to message #7401] Fri, 16 December 2005 03:08 Go to previous message
Ted,
In your new fragment.xml you are referring to an "oracle" dialect:
<extension name="Net4j Pluggable ORACLE Driver" point="org.eclipse.net4j.jdbc.drivers">
<driver className="oracle.jdbc.driver.OracleDriver" exampleURL="jdbc:oracle:thin:@<server>[:<1521>]:<database_name >" name="Oracle">
<supportedDialect name="oracle" />
</driver>
</extension>
Have you developed, configured and deployed this SqlDialect?
The name of the provided oracle dialect is "ORACLE", maybe that helps.
I have coded an additional argument check to detect missing dialects
before an NPE hurts. Please update org.eclipse.net4j.dbgen
Does that help?
Cheers
/Eike
TVal schrieb:
> Eike,
> on Oracle.
> Cheers.
> - Ted
>>Hi Ted,
>>Cheers
>>/Eike
>>TVal schrieb:
>>>Hi Eike,
>>Oracle
>>>to
>>>JDBC
>>>exception
>>>is being thrown in
>>>Oracle
>>fragment...
Re: CDO: Oracle JDBC driver [message #561967 is a reply to message #7347] Thu, 15 December 2005 05:04 Go to previous message
Hi Ted,
Cheers
/Eike
TVal schrieb:
> Hi Eike,
> is being thrown in
Re: CDO: Oracle JDBC driver [message #562056 is a reply to message #7358] Thu, 15 December 2005 14:16 Go to previous message
Eike,
on Oracle.
Cheers.
- Ted
> Hi Ted,
> Cheers
> /Eike
> TVal schrieb:
>> Hi Eike,
> Oracle
>> to
>> JDBC
>> exception
>> is being thrown in
>> Oracle
> fragment...
Re: CDO: Oracle JDBC driver [message #562080 is a reply to message #7401] Fri, 16 December 2005 03:08 Go to previous message
Ted,
</driver>
</extension>
Does that help?
Cheers
/Eike
TVal schrieb:
> Eike,
> on Oracle.
> Cheers.
> - Ted
>>Hi Ted,
>>Cheers
>>/Eike
>>TVal schrieb:
>>>Hi Eike,
>>Oracle
>>>to
>>>JDBC
>>>exception
>>>is being thrown in
>>>Oracle
>>fragment...
Previous Topic:Issue with loading properties from a CDO resource in Library Example project
Next Topic:Newbie question
Current Time: Wed Oct 29 07:10:30 EDT 2025
Powered by FUDForum. Page generated in 0.04804 seconds
