Home » Modeling » GMF (Graphical Modeling Framework) » java.lang.IllegalArgumentException: Figure must be a child
java.lang.IllegalArgumentException: Figure must be a child [message #81353] Tue, 28 November 2006 08:31 Go to next message
Originally posted by: zzhangh.cn.ibm.com
I got "java.lang.IllegalArgumentException: Figure must be a child" when
drag a figure from palette to canvas, as a workaround I commented codes in
XXXCompartmentEditPart#setRatio() which supposed to call super.Ratio().
As to this exception, where could be the problem? Also I'm interested in
what ShapeCompartmentEditPart#setRatio() would impact.
Caused by: java.lang.IllegalArgumentException: Figure must be a child
at org.eclipse.draw2d.Figure.setConstraint(Figure.java:1455)
org.eclipse.gmf.runtime.diagram.ui.editparts.AbstractBordere dShapeEditPart.setLayoutConstraint(AbstractBorderedShapeEdit Part.java:67)
org.eclipse.gmf.runtime.diagram.ui.editparts.ResizableCompar tmentEditPart.setRatio(ResizableCompartmentEditPart.java:201 )
com.example.bma.diagram.edit.parts.ActorActivitiesEditPart.s etRatio(ActorActivitiesEditPart.java:79)
org.eclipse.gmf.runtime.diagram.ui.editparts.ResizableCompar tmentEditPart.refreshRatio(ResizableCompartmentEditPart.java :152)
org.eclipse.gmf.runtime.diagram.ui.editparts.ResizableCompar tmentEditPart.refreshVisuals(ResizableCompartmentEditPart.ja va:72)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:676)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.access$3(GraphicalEditPart.java:1)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt$3.run(GraphicalEditPart.java:824)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:256)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.refresh(GraphicalEditPart.java:814)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:235)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeCompartmen tEditPart.addNotify(ShapeCompartmentEditPart.java:786)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:727)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:677)
Hao Zhang
Re: java.lang.IllegalArgumentException: Figure must be a child [message #154405 is a reply to message #81353] Tue, 09 October 2007 10:47 Go to previous messageGo to next message
Originally posted by: r.c.ladan.tue.nl
--------------000701010003070301010107
Content-Type: text/plain; charset=ISO-8859-15
Hao Zhang wrote:
> in XXXCompartmentEditPart#setRatio() which supposed to call super.Ratio().
I'm also plagued by this exception (see the attachment), but it happens
when the diagram draws itself upon launch. The diagram still shows up,
but adding elements (except for the standard GMF ones like Triangle,
Octagon, etc) yields a stack overflow exception.
This is with an unmodified gmfgen file and java code. The gmfmap file validates
ok. I don't get any exceptions with the (self-created) mindmap example.
Versions are from the latest Integration:
Eclipse 3.4.0 I20070921-0919
EMF 2.3.0 I20070925-2135
GEF 3.4.0 20070919
GMF 1.0.0 20070809-0000
Any ideas?
Rene
name="IRJS0007E Semantic refresh failed.txt"
Content-Disposition: inline;
filename="IRJS0007E Semantic refresh failed.txt"
at org.eclipse.draw2d.Figure.setConstraint(Figure.java:1458)
at org.eclipse.gmf.runtime.diagram.ui.editparts.BorderedBorderI temEditPart.setLayoutConstraint(BorderedBorderItemEditPart.j ava:133)
at meta.diagram.edit.parts.ProvidesPortNameEditPart.refreshBoun ds(ProvidesPortNameEditPart.java:138)
at meta.diagram.edit.parts.ProvidesPortNameEditPart.refreshVisu als(ProvidesPortNameEditPart.java:428)
at meta.diagram.edit.parts.ProvidesPortNameEditPart.setLabel(Pr ovidesPortNameEditPart.java:194)
at meta.diagram.edit.parts.ProvidesPortEditPart.addFixedChild(P rovidesPortEditPart.java:126)
at meta.diagram.edit.parts.ProvidesPortEditPart.addChildVisual( ProvidesPortEditPart.java:157)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:197)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.addChild(GraphicalEditPart.java:1292)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:727)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:677)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:564)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.access$3(GraphicalEditPart.java:1)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt$3.run(GraphicalEditPart.java:836)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:262)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.refresh(GraphicalEditPart.java:826)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:235)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.postProcessRefreshSemantic(CanonicalEditPolicy.java: 1190)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.refreshSemanticChildren(CanonicalEditPolicy.java:112 5)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.refreshSemantic(CanonicalEditPolicy.java:980)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.refresh(CanonicalEditPolicy.java:962)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.refreshOnActivate(CanonicalEditPolicy.java:662)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.activate(CanonicalEditPolicy.java:652)
at org.eclipse.gef.editparts.AbstractEditPart.activateEditPolic ies(AbstractEditPart.java:165)
at org.eclipse.gef.editparts.AbstractEditPart.activate(Abstract EditPart.java:148)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.activate (AbstractGraphicalEditPart.java:186)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.access$0(GraphicalEditPart.java:1)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.activate(GraphicalEditPart.java:186)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:201)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.handleNotificationEvent(GraphicalEditPart.java:1437)
at org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeEditPart.h andleNotificationEvent(ShapeEditPart.java:111)
at org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeNodeEditPa rt.handleNotificationEvent(ShapeNodeEditPart.java:225)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.notifyChanged(GraphicalEditPart.java:1411)
at org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.fireNotification(DiagramEventBroker.java:500)
at org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.resourceSetChanged(DiagramEventBroker.java:395)
at org.eclipse.gmf.runtime.diagram.ui.internal.DiagramEventBrok erThreadSafe.resourceSetChanged(DiagramEventBrokerThreadSafe .java:72)
at org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFac tory$DiagramEditingDomain.postcommit(DiagramEditingDomainFac tory.java:213)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.deactivate(TransactionalEditingDomainImpl.java:475)
at org.eclipse.emf.transaction.impl.TransactionImpl.close(Trans actionImpl.java:517)
at org.eclipse.emf.transaction.impl.TransactionImpl.commit(Tran sactionImpl.java:358)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:140)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.executeCommand(CanonicalEditPolicy.java:513)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.createViews(CanonicalEditPolicy.java:469)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.refreshSemanticChildren(CanonicalEditPolicy.java:110 2)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalCon nectionEditPolicy.refreshOnActivate(CanonicalConnectionEditP olicy.java:104)
at org.eclipse.gmf.runtime.diagram.ui.editparts.DiagramEditPart .activate(DiagramEditPart.java:349)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(Sim pleRootEditPart.java:101)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:601)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalVie wer.setContents(DiagramGraphicalViewer.java:378)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:610)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initi alizeGraphicalViewerContents(DiagramEditor.java:857)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initi alizeGraphicalViewer(DiagramEditor.java:850)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFl yOutPalette.initializeGraphicalViewer(DiagramEditorWithFlyOu tPalette.java:112)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.creat eGraphicalViewer(DiagramEditor.java:794)
at org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(G raphicalEditor.java:163)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.creat ePartControl(DiagramEditor.java:1548)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFl yOutPalette.createPartControl(DiagramEditorWithFlyOutPalette .java:310)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1459)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1405)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:939)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:124)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3719)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3356)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:801)
at org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 515)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:455)
at org.eclipse.equinox.launcher.Main.run(Main.java:1193)
at org.eclipse.equinox.launcher.Main.main(Main.java:1169)
--------------000701010003070301010107--
Re: java.lang.IllegalArgumentException: Figure must be a child [message #154560 is a reply to message #154405] Wed, 10 October 2007 04:27 Go to previous message
Rene Ladan wrote:
> Hao Zhang wrote:
Even regenerating the gmfgen file and Java code from scratch (i.e. moving the existing
files out of the way) doesn't help. The genmodel file is unmodified, only the following
Java methods are modified:
* MODEL/src/MODEL/MODELPackage.java : change String eNS_URI from
"MODEL" to "LEGACY_MODEL_URI" to be compatible with legacy models.
> GEF 3.4.0 20070919
> Any ideas?
> Rene
Previous Topic:How to create a new Node for a preexisting model element with no representation in the diagram
Next Topic:Programmatically creating a link
Current Time: Wed Oct 29 10:40:44 EDT 2025
Powered by FUDForum. Page generated in 0.04546 seconds
