Home » Language IDEs » Java Development Tools (JDT) » Creating a Java Project
Creating a Java Project [message #81331] Tue, 29 July 2003 10:13 Go to next message
Originally posted by: bob.donovan.eds.com
I need to have my users create a Java Project. I need to have the java
project setup with a directory structure that is used for development of
our product.
I think what I want to do is subclass the
org.eclipse.jdt.ui.wizards.NewProjectCreationWizard and add a couple of
extra wizard pages. When the wizard completes, I add some of my own
processing to create the directory structure.
I see that the org.eclipse.jdt.ui.wizards.NewProjectCreationWizard (id) is
actually found at
org.eclipse.jdt.internal.ui.wizards.NewProjectCreationWizard which is
"internal".
Is this acceptable to subclass an internal class? Or is there some other
way that I should be doing this operation?
Bob
Re: Creating a Java Project [message #83408 is a reply to message #81331] Wed, 06 August 2003 11:28 Go to previous message
You woudn't reuse the wizard, but you can reuse the wizard page that
lets you configure the build path.
Have a look at 'MyProjectCreationWizard' in org.eclipse.jdt.ui.tests,
it's an example that probably does exactly what you want.
Martin
Bob Donovan wrote:
> our product.
> actually found at
> "internal".
> Bob
Previous Topic:Using ASTRewrite
Next Topic:Running out of memory with eclipse
Current Time: Mon Apr 28 23:50:50 EDT 2025
Powered by FUDForum. Page generated in 0.07205 seconds
