Home » Eclipse Projects » Nebula » Fixing Columns
Fixing Columns [message #7191] Wed, 26 July 2006 13:58 Go to next message
Serge  is currently offline Serge Friend
Member
is it possible to set one or even more columns fixed so that they don't
move when scrolling horizontally? (something like the row headers which
can be displayed)
regards, Serge
Re: Fixing Columns [message #7264 is a reply to message #7191] Wed, 26 July 2006 15:28 Go to previous messageGo to next message
Chris Gross is currently offline Chris GrossFriend
Not currently, but it is the next significant feature that I plan to add.
-Chris
Serge wrote:
> Hi
> can be displayed)
> regards, Serge
Re: Fixing Columns [message #7989 is a reply to message #7264] Wed, 26 July 2006 18:33 Go to previous messageGo to next message
Member
Hi Chris
ok, great. how many times a month do you publish new releases? like once a
month? looking for alternatives to the swt table i also found a table
named ktable. what are the most significant differences between the nebula
grid and ktable (since ktable is also a grid). when would i use ktable and
when would i use the nebula grid?
regards, Serge
Re: Fixing Columns [message #8021 is a reply to message #7989] Wed, 26 July 2006 19:17 Go to previous message
I don't have any timetable for when I push out a new build. Hopefully,
Nebula will eventually get access to a build machine and that won't be
an issue.
KTable uses a different API than Grid. Grid follows the straightforward
Table API. KTable uses a more complex MVC paradigm. Other than that, I
don't know too much about KTable.
-Chris
Serge wrote:
> Hi Chris
> a month? looking for alternatives to the swt table i also found a table
> nebula grid and ktable (since ktable is also a grid). when would i use
> ktable and when would i use the nebula grid?
> regards, Serge
Re: Fixing Columns [message #563458 is a reply to message #7191] Wed, 26 July 2006 15:28 Go to previous message
-Chris
Serge wrote:
> Hi
> can be displayed)
> regards, Serge
Re: Fixing Columns [message #563480 is a reply to message #7264] Wed, 26 July 2006 18:33 Go to previous message
Member
Hi Chris
regards, Serge
Re: Fixing Columns [message #563500 is a reply to message #7989] Wed, 26 July 2006 19:17 Go to previous message
an issue.
-Chris
Serge wrote:
> Hi Chris
> regards, Serge
Previous Topic:Comp4SWT
Next Topic:Compatibility
Current Time: Wed Feb 05 11:54:05 GMT 2025
Powered by FUDForum. Page generated in 0.04141 seconds
