Home » Language IDEs » C / C++ IDE (CDT) » Include path misbehaves
Include path misbehaves [message #80572] Sat, 20 September 2003 12:31 Go to next message
Ever since i got 1.2.0.51 (yesterday), i've been fooling with it, porting
my VC++7 projects. I put this in the include path:
C:\prog\lib\SDL-devel-1.2.5a-mingw32\SDL-1.2.5\include\SDL
and it didn't work. Which was strange, because the files are there. I then
put quotes around the path:
"C:\prog\lib\SDL-devel-1.2.5a-mingw32\SDL-1.2.5\include\SDL"
and it worked fine.
So I ask: wouldn't it be nicer if the quotes were put in automatically?
Can it be done? Am I just a spoiled brat, whining for a lollipop?
Thanks.
Re: Include path misbehaves [message #80601 is a reply to message #80572] Mon, 22 September 2003 09:13 Go to previous messageGo to next message
Are you talking about the "Paths and Symbols" tab on a Managed Make Project,
or a Standard Make Project?
"perplx" <perplx@hotmail.com> wrote in message
news:bkhvci$7r9$1@eclipse.org...
> and it worked fine.
> Thanks.
Re: Include path misbehaves [message #80631 is a reply to message #80601] Mon, 22 September 2003 13:05 Go to previous messageGo to next message
umm, I thought "Paths and Symbols" referred to standard make projects...
Actually, I'm talking about managed make, In the main menu:
Project->properties->C/C++ Build,
Compiler->General (Include Paths) and
Linker->General (Library Paths)
I think it would work without the quotes if I used "/", not "\". But
nowadays CDT/Managed Make does such a good job of hiding the UNIX stuff, I
forget. I keep thinking it's a Windows-native app :D Anyway, it's just a
minor annoyance.
Keep up the good work!
> > C:proglibSDL-devel-1.2.5a-mingw32SDL-1.2.5includeSDL
> > "C:proglibSDL-devel-1.2.5a-mingw32SDL-1.2.5includeSDL"
> > and it worked fine.
> > Thanks.
Re: Include path misbehaves [message #80659 is a reply to message #80631] Mon, 22 September 2003 13:52 Go to previous message
Please raise a bug to track this issue.
It is most unfortunate, and will likely be something that keeps coming up,
so I'd like a defect to track the problem.
https://bugs.eclipse.org/ (Product : CDT / Component : CDT-parser )
JohnC
news:bkna5j$4je$1@eclipse.org...
Project,
> minor annoyance.
porting
then
> > > and it worked fine.
automatically?
> > > Thanks.
Previous Topic:cdt.ui p-n.xml
Next Topic:Opening SDK headers
Current Time: Mon Oct 27 18:05:41 EDT 2025
Powered by FUDForum. Page generated in 0.04119 seconds
