| [ATL] Processing GMF [message #80540] |
Thu, 01 May 2008 10:20   |
Eclipse User  |
Originally posted by: bures.dsrg.mff.cuni.cz
--------------020606000507040604020103
Content-Type: text/plain; charset=UTF-8; format=flowed
I've created an ATL module that should create a copy of GMF diagram file (meta-model URI: http://www.eclipse.org/gmf/runtime/1.0.1/notation). The module is attached.
It compiles fine, however when I try to run it on a GMF diagram file, I get the following error:
SEVERE: ****** BEGIN Stack Trace
SEVERE: 	message: trying to register several rules as default for element inM!<unnamed>: 'R_FillStyle' and 'R_LineStyle'
SEVERE: A.main() : ??#22 null
SEVERE: 	local variables = {self=ATLCopier_notation : ASMModule}
SEVERE: 	local stack = []
SEVERE: A.__matcher__() : ??#3 null
SEVERE: A.__matchR_LineStyle() : ??#36 null
SEVERE: 	local variables = {s=inM!<unnamed>, self=ATLCopier_notation : ASMModule}
SEVERE: NativeOperation public static void  org.eclipse.m2m.atl.engine.vm.nativelib.ASMTransientLinkSet. addLink(org.eclipse.m2m.atl.engine.vm.StackFrame,org.eclipse .m2m.atl.engine.vm.nativelib.ASMTransientLinkSet,org.eclipse .m2m.atl.engine.vm.nativelib.ASMTransientLink)
SEVERE: 	args = [TransientLinkSet {TransientLink {rule = 'R_FillStyle', sourceElements = {s = inM!<unnamed>}, targetElements = {t = outM!<unnamed>}, variables = {}}, TransientLink {rule = 'R_FillStyle', sourceElements = {s = inM!<unnamed>}, targetElements = {t = outM!<unnamed>}, variables = {}}, TransientLink {rule = 'R_FillStyle', sourceElements = {s = inM!<unnamed>}, targetElements = {t = outM!<unnamed>}, variables = {}}, TransientLink {rule = 'R_FillStyle', sourceElements = {s = inM!<unnamed>}, targetElements = {t = outM!<unnamed>}, variables = {}}, TransientLink {rule = 'R_FillStyle', sourceElements = {s = inM!<unnamed>}, targetElements = {t = outM!<unnamed>}, variables = {}}, TransientLink {rule = 'R_FillStyle', sourceElements = {s = inM!<unnamed>}, targetElements = {t = outM!<unnamed>}, variables = {}}}, TransientLink {rule = 'R_LineStyle', sourceElements = {s = inM!<unnamed>}, targetElements = {t = outM!<unnamed>}, variables = {}}]
SEVERE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow continuation after errors).
In the end, it looks like the problem lies in having these two rules in the transformation. Actually, the error persists until I have more than one rule for styles.
rule R_FillStyle {
	from s : MM!FillStyle
	to t : MM!FillStyle (
		fillColor <- s.fillColor
rule R_LineStyle {
	from s : MM!LineStyle
	to t : MM!LineStyle (
		lineColor <- s.lineColor
Do you have any idea, what it could mean and how to cope with that?
Thank you,
Tomas
 name="notation.atl"
Content-Disposition: inline;
 filename="notation.atl"
 bW9kdWxlIEFUTENvcGllcl9ub3RhdGlvbjsgLS0gTW9kdWxlIFRlbXBsYXRl CmNyZWF0ZSBv
 dXRNIDogTU0gZnJvbSBpbk0gOiBNTTsKcnVsZSBSX0VkZ2UgewoJZnJvbSBz IDogTU0hRWRn
 ZQoJdG8gdCA6IE1NIUVkZ2UgKAoJCXZpc2libGUgPC0gcy52aXNpYmxlLAoJ CXR5cGUgPC0g
 cy50eXBlLAoJCWNoaWxkcmVuIDwtIHMuY2hpbGRyZW4sCgkJc3R5bGVzIDwt IHMuc3R5bGVz
 LAoJCWVsZW1lbnQgPC0gcy5lbGVtZW50LAoJCXNvdXJjZSA8LSBzLnNvdXJj ZSwKCQl0YXJn
 ZXQgPC0gcy50YXJnZXQsCgkJYmVuZHBvaW50cyA8LSBzLmJlbmRwb2ludHMs CgkJc291cmNl
 QW5jaG9yIDwtIHMuc291cmNlQW5jaG9yLAoJCXRhcmdldEFuY2hvciA8LSBz LnRhcmdldEFu
 Y2hvcgoJKQp9CnJ1bGUgUl9Ob2RlIHsKCWZyb20gcyA6IE1NIU5vZGUKCXRv IHQgOiBNTSFO
 b2RlICgKCQl2aXNpYmxlIDwtIHMudmlzaWJsZSwKCQl0eXBlIDwtIHMudHlw ZSwKCQljaGls
 ZHJlbiA8LSBzLmNoaWxkcmVuLAoJCXN0eWxlcyA8LSBzLnN0eWxlcywKCQll bGVtZW50IDwt
 IHMuZWxlbWVudCwKCQlsYXlvdXRDb25zdHJhaW50IDwtIHMubGF5b3V0Q29u c3RyYWludAoJ
 KQp9CnJ1bGUgUl9GaWxsU3R5bGUgewoJZnJvbSBzIDogTU0hRmlsbFN0eWxl Cgl0byB0IDog
 TU0hRmlsbFN0eWxlICgKCQlmaWxsQ29sb3IgPC0gcy5maWxsQ29sb3IKCSkK fQpydWxlIFJf
 TGluZVN0eWxlIHsKCWZyb20gcyA6IE1NIUxpbmVTdHlsZQoJdG8gdCA6IE1N IUxpbmVTdHls
 ZSAoCgkJbGluZUNvbG9yIDwtIHMubGluZUNvbG9yCgkpCn0KcnVsZSBSX0Zv bnRTdHlsZSB7
 Cglmcm9tIHMgOiBNTSFGb250U3R5bGUKCXRvIHQgOiBNTSFGb250U3R5bGUg KAoJCWZvbnRD
 b2xvciA8LSBzLmZvbnRDb2xvciwKCQlmb250TmFtZSA8LSBzLmZvbnROYW1l LAoJCWZvbnRI
 ZWlnaHQgPC0gcy5mb250SGVpZ2h0LAoJCWJvbGQgPC0gcy5ib2xkLAoJCWl0 YWxpYyA8LSBz
 Lml0YWxpYywKCQl1bmRlcmxpbmUgPC0gcy51bmRlcmxpbmUsCgkJc3RyaWtl VGhyb3VnaCA8
 LSBzLnN0cmlrZVRocm91Z2gKCSkKfQpydWxlIFJfVGl0bGVTdHlsZSB7Cglm cm9tIHMgOiBN
 TSFUaXRsZVN0eWxlCgl0byB0IDogTU0hVGl0bGVTdHlsZSAoCgkJc2hvd1Rp dGxlIDwtIHMu
 c2hvd1RpdGxlCgkpCn0KcnVsZSBSX1NvcnRpbmdTdHlsZSB7Cglmcm9tIHMg OiBNTSFTb3J0
 aW5nU3R5bGUKCXRvIHQgOiBNTSFTb3J0aW5nU3R5bGUgKAoJCXNvcnRpbmcg PC0gcy5zb3J0
 aW5nLAoJCXNvcnRpbmdLZXlzIDwtIHMuc29ydGluZ0tleXMsCgkJc29ydGVk T2JqZWN0cyA8
 LSBzLnNvcnRlZE9iamVjdHMKCSkKfQpydWxlIFJfRGVzY3JpcHRpb25TdHls ZSB7Cglmcm9t
 IHMgOiBNTSFEZXNjcmlwdGlvblN0eWxlCgl0byB0IDogTU0hRGVzY3JpcHRp b25TdHlsZSAo
 CgkJZGVzY3JpcHRpb24gPC0gcy5kZXNjcmlwdGlvbgoJKQp9CnJ1bGUgUl9T aXplIHsKCWZy
 b20gcyA6IE1NIVNpemUKCXRvIHQgOiBNTSFTaXplICgKCQl3aWR0aCA8LSBz LndpZHRoLAoJ
 CWhlaWdodCA8LSBzLmhlaWdodAoJKQp9CnJ1bGUgUl9Mb2NhdGlvbiB7Cglm cm9tIHMgOiBN
 TSFMb2NhdGlvbgoJdG8gdCA6IE1NIUxvY2F0aW9uICgKCQl4IDwtIHMueCwK CQl5IDwtIHMu
 eQoJKQp9CnJ1bGUgUl9Cb3VuZHMgewoJZnJvbSBzIDogTU0hQm91bmRzCgl0 byB0IDogTU0h
 Qm91bmRzICgKCQl4IDwtIHMueCwKCQl5IDwtIHMueSwKCQl3aWR0aCA8LSBz LndpZHRoLAoJ
 CWhlaWdodCA8LSBzLmhlaWdodAoJKQp9CnJ1bGUgUl9SYXRpbyB7Cglmcm9t IHMgOiBNTSFS
 YXRpbwoJdG8gdCA6IE1NIVJhdGlvICgKCQl2YWx1ZSA8LSBzLnZhbHVlCgkp Cn0KcnVsZSBS
 X0lkZW50aXR5QW5jaG9yIHsKCWZyb20gcyA6IE1NIUlkZW50aXR5QW5jaG9y Cgl0byB0IDog
 TU0hSWRlbnRpdHlBbmNob3IgKAoJCWlkIDwtIHMuaWQKCSkKfQpydWxlIFJf Um91dGluZ1N0
 eWxlIHsKCWZyb20gcyA6IE1NIVJvdXRpbmdTdHlsZQoJdG8gdCA6IE1NIVJv dXRpbmdTdHls
 ZSAoCgkJcm91dGluZyA8LSBzLnJvdXRpbmcsCgkJc21vb3RobmVzcyA8LSBz LnNtb290aG5l
 c3MsCgkJYXZvaWRPYnN0cnVjdGlvbnMgPC0gcy5hdm9pZE9ic3RydWN0aW9u cywKCQljbG9z
 ZXN0RGlzdGFuY2UgPC0gcy5jbG9zZXN0RGlzdGFuY2UsCgkJanVtcExpbmtT dGF0dXMgPC0g
 cy5qdW1wTGlua1N0YXR1cywKCQlqdW1wTGlua1R5cGUgPC0gcy5qdW1wTGlu a1R5cGUsCgkJ
 anVtcExpbmtzUmV2ZXJzZSA8LSBzLmp1bXBMaW5rc1JldmVyc2UKCSkKfQpy dWxlIFJfUmVs
 YXRpdmVCZW5kcG9pbnRzIHsKCWZyb20gcyA6IE1NIVJlbGF0aXZlQmVuZHBv aW50cwoJdG8g
 dCA6IE1NIVJlbGF0aXZlQmVuZHBvaW50cyAoCgkJcG9pbnRzIDwtIHMucG9p bnRzCgkpCn0K
 cnVsZSBSX0RpYWdyYW0gewoJZnJvbSBzIDogTU0hRGlhZ3JhbQoJdG8gdCA6 IE1NIURpYWdy
 YW0gKAoJCXZpc2libGUgPC0gcy52aXNpYmxlLAoJCXR5cGUgPC0gcy50eXBl LAoJCWNoaWxk
 cmVuIDwtIHMuY2hpbGRyZW4sCgkJc3R5bGVzIDwtIHMuc3R5bGVzLAoJCWVs ZW1lbnQgPC0g
 cy5lbGVtZW50LAoJCW5hbWUgPC0gcy5uYW1lLAoJCW1lYXN1cmVtZW50VW5p dCA8LSBzLm1l
 YXN1cmVtZW50VW5pdCwKCQllZGdlcyA8LSBzLmVkZ2VzCgkpCn0KcnVsZSBS X0ltYWdlIHsK
 CWZyb20gcyA6IE1NIUltYWdlCgl0byB0IDogTU0hSW1hZ2UgKAoJCWRhdGEg PC0gcy5kYXRh
 CgkpCn0KcnVsZSBSX0Nhbm9uaWNhbFN0eWxlIHsKCWZyb20gcyA6IE1NIUNh bm9uaWNhbFN0
 eWxlCgl0byB0IDogTU0hQ2Fub25pY2FsU3R5bGUgKAoJCWNhbm9uaWNhbCA8 LSBzLmNhbm9u
 aWNhbAoJKQp9CnJ1bGUgUl9TaGFwZVN0eWxlIHsKCWZyb20gcyA6IE1NIVNo YXBlU3R5bGUK
 CXRvIHQgOiBNTSFTaGFwZVN0eWxlICgKCQlmb250Q29sb3IgPC0gcy5mb250 Q29sb3IsCgkJ
 Zm9udE5hbWUgPC0gcy5mb250TmFtZSwKCQlmb250SGVpZ2h0IDwtIHMuZm9u dEhlaWdodCwK
 CQlib2xkIDwtIHMuYm9sZCwKCQlpdGFsaWMgPC0gcy5pdGFsaWMsCgkJdW5k ZXJsaW5lIDwt
 IHMudW5kZXJsaW5lLAoJCXN0cmlrZVRocm91Z2ggPC0gcy5zdHJpa2VUaHJv dWdoLAoJCWRl
 c2NyaXB0aW9uIDwtIHMuZGVzY3JpcHRpb24sCgkJZmlsbENvbG9yIDwtIHMu ZmlsbENvbG9y
 LAoJCWxpbmVDb2xvciA8LSBzLmxpbmVDb2xvcgoJKQp9CnJ1bGUgUl9Db25u ZWN0b3JTdHls
 ZSB7Cglmcm9tIHMgOiBNTSFDb25uZWN0b3JTdHlsZQoJdG8gdCA6IE1NIUNv bm5lY3RvclN0
 eWxlICgKCQlyb3V0aW5nIDwtIHMucm91dGluZywKCQlzbW9vdGhuZXNzIDwt IHMuc21vb3Ro
 bmVzcywKCQlhdm9pZE9ic3RydWN0aW9ucyA8LSBzLmF2b2lkT2JzdHJ1Y3Rp b25zLAoJCWNs
 b3Nlc3REaXN0YW5jZSA8LSBzLmNsb3Nlc3REaXN0YW5jZSwKCQlqdW1wTGlu a1N0YXR1cyA8
 LSBzLmp1bXBMaW5rU3RhdHVzLAoJCWp1bXBMaW5rVHlwZSA8LSBzLmp1bXBM aW5rVHlwZSwK
 CQlqdW1wTGlua3NSZXZlcnNlIDwtIHMuanVtcExpbmtzUmV2ZXJzZSwKCQls aW5lQ29sb3Ig
 PC0gcy5saW5lQ29sb3IKCSkKfQpydWxlIFJfUGFnZVN0eWxlIHsKCWZyb20g cyA6IE1NIVBh
 Z2VTdHlsZQoJdG8gdCA6IE1NIVBhZ2VTdHlsZSAoCgkJcGFnZVggPC0gcy5w YWdlWCwKCQlw
 YWdlWSA8LSBzLnBhZ2VZLAoJCXBhZ2VXaWR0aCA8LSBzLnBhZ2VXaWR0aCwK CQlwYWdlSGVp
 Z2h0IDwtIHMucGFnZUhlaWdodAoJKQp9CnJ1bGUgUl9EcmF3ZXJTdHlsZSB7 Cglmcm9tIHMg
 OiBNTSFEcmF3ZXJTdHlsZQoJdG8gdCA6IE1NIURyYXdlclN0eWxlICgKCQlj b2xsYXBzZWQg
 PC0gcy5jb2xsYXBzZWQKCSkKfQpydWxlIFJfR3VpZGVTdHlsZSB7Cglmcm9t IHMgOiBNTSFH
 dWlkZVN0eWxlCgl0byB0IDogTU0hR3VpZGVTdHlsZSAoCgkJaG9yaXpvbnRh bEd1aWRlcyA8
 LSBzLmhvcml6b250YWxHdWlkZXMsCgkJdmVydGljYWxHdWlkZXMgPC0gcy52 ZXJ0aWNhbEd1
 aWRlcwoJKQp9CnJ1bGUgUl9HdWlkZSB7Cglmcm9tIHMgOiBNTSFHdWlkZQoJ dG8gdCA6IE1N
 IUd1aWRlICgKCQlwb3NpdGlvbiA8LSBzLnBvc2l0aW9uLAoJCW5vZGVNYXAg PC0gcy5ub2Rl
 TWFwCgkpCn0KcnVsZSBSX05vZGVFbnRyeSB7Cglmcm9tIHMgOiBNTSFOb2Rl RW50cnkKCXRv
 IHQgOiBNTSFOb2RlRW50cnkgKAoJCXZhbHVlIDwtIHMudmFsdWUsCgkJa2V5 IDwtIHMua2V5
 CgkpCn0KcnVsZSBSX0ZpbHRlcmluZ1N0eWxlIHsKCWZyb20gcyA6IE1NIUZp bHRlcmluZ1N0
 eWxlCgl0byB0IDogTU0hRmlsdGVyaW5nU3R5bGUgKAoJCWZpbHRlcmluZyA8 LSBzLmZpbHRl
 cmluZywKCQlmaWx0ZXJpbmdLZXlzIDwtIHMuZmlsdGVyaW5nS2V5cywKCQlm aWx0ZXJlZE9i
 amVjdHMgPC0gcy5maWx0ZXJlZE9iamVjdHMKCSkKfQpydWxlIFJfRGlhZ3Jh bVN0eWxlIHsK
 CWZyb20gcyA6IE1NIURpYWdyYW1TdHlsZQoJdG8gdCA6IE1NIURpYWdyYW1T dHlsZSAoCgkJ
 cGFnZVggPC0gcy5wYWdlWCwKCQlwYWdlWSA8LSBzLnBhZ2VZLAoJCXBhZ2VX aWR0aCA8LSBz
 LnBhZ2VXaWR0aCwKCQlwYWdlSGVpZ2h0IDwtIHMucGFnZUhlaWdodCwKCQlo b3Jpem9udGFs
 R3VpZGVzIDwtIHMuaG9yaXpvbnRhbEd1aWRlcywKCQl2ZXJ0aWNhbEd1aWRl cyA8LSBzLnZl
 cnRpY2FsR3VpZGVzLAoJCWRlc2NyaXB0aW9uIDwtIHMuZGVzY3JpcHRpb24K CSkKfQpydWxl
 IFJfSW1hZ2VTdHlsZSB7Cglmcm9tIHMgOiBNTSFJbWFnZVN0eWxlCgl0byB0 IDogTU0hSW1h
 Z2VTdHlsZSAoCgkJYW50aUFsaWFzIDwtIHMuYW50aUFsaWFzLAoJCW1haW50 YWluQXNwZWN0
 UmF0aW8gPC0gcy5tYWludGFpbkFzcGVjdFJhdGlvLAoJCWNyb3BCb3VuZCA8 LSBzLmNyb3BC
 b3VuZAoJKQp9CnJ1bGUgUl9JbWFnZUJ1ZmZlclN0eWxlIHsKCWZyb20gcyA6 IE1NIUltYWdl
 QnVmZmVyU3R5bGUKCXRvIHQgOiBNTSFJbWFnZUJ1ZmZlclN0eWxlICgKCQlh bnRpQWxpYXMg
 PC0gcy5hbnRpQWxpYXMsCgkJbWFpbnRhaW5Bc3BlY3RSYXRpbyA8LSBzLm1h aW50YWluQXNw
 ZWN0UmF0aW8sCgkJY3JvcEJvdW5kIDwtIHMuY3JvcEJvdW5kLAoJCWltYWdl QnVmZmVyIDwt
 IHMuaW1hZ2VCdWZmZXIKCSkKfQpydWxlIFJfUHJvcGVydGllc1NldFN0eWxl IHsKCWZyb20g
 cyA6IE1NIVByb3BlcnRpZXNTZXRTdHlsZQoJdG8gdCA6IE1NIVByb3BlcnRp ZXNTZXRTdHls
 ZSAoCgkJbmFtZSA8LSBzLm5hbWUsCgkJcHJvcGVydGllc01hcCA8LSBzLnBy b3BlcnRpZXNN
 YXAKCSkKfQpydWxlIFJfU3RyaW5nVG9Qcm9wZXJ0eVZhbHVlTWFwRW50cnkg ewoJZnJvbSBz
 IDogTU0hU3RyaW5nVG9Qcm9wZXJ0eVZhbHVlTWFwRW50cnkKCXRvIHQgOiBN TSFTdHJpbmdU
 b1Byb3BlcnR5VmFsdWVNYXBFbnRyeSAoCgkJa2V5IDwtIHMua2V5LAoJCXZh bHVlIDwtIHMu
 dmFsdWUKCSkKfQpydWxlIFJfUHJvcGVydHlWYWx1ZSB7Cglmcm9tIHMgOiBN TSFQcm9wZXJ0
 eVZhbHVlCgl0byB0IDogTU0hUHJvcGVydHlWYWx1ZSAoCgkJcmF3VmFsdWUg PC0gcy5yYXdW
 YWx1ZSwKCQlpbnN0YW5jZVR5cGUgPC0gcy5pbnN0YW5jZVR5cGUKCSkKfQpy dWxlIFJfU2lu
 Z2xlVmFsdWVTdHlsZSB7Cglmcm9tIHMgOiBNTSFTaW5nbGVWYWx1ZVN0eWxl Cgl0byB0IDog
 TU0hU2luZ2xlVmFsdWVTdHlsZSAoCgkJbmFtZSA8LSBzLm5hbWUsCgkJaW5z dGFuY2VUeXBl
 IDwtIHMuaW5zdGFuY2VUeXBlLAoJCXJhd1ZhbHVlIDwtIHMucmF3VmFsdWUK CSkKfQpydWxl
 IFJfTGlzdFZhbHVlU3R5bGUgewoJZnJvbSBzIDogTU0hTGlzdFZhbHVlU3R5 bGUKCXRvIHQg
 OiBNTSFMaXN0VmFsdWVTdHlsZSAoCgkJbmFtZSA8LSBzLm5hbWUsCgkJaW5z dGFuY2VUeXBl
 IDwtIHMuaW5zdGFuY2VUeXBlLAoJCXJhd1ZhbHVlc0xpc3QgPC0gcy5yYXdW YWx1ZXNMaXN0
 CgkpCn0KcnVsZSBSX05hbWVkU3R5bGUgewoJZnJvbSBzIDogTU0hTmFtZWRT dHlsZQoJdG8g
 dCA6IE1NIU5hbWVkU3R5bGUgKAoJCW5hbWUgPC0gcy5uYW1lCgkpCn0KcnVs ZSBSX0RhdGFU
 eXBlU3R5bGUgewoJZnJvbSBzIDogTU0hRGF0YVR5cGVTdHlsZQoJdG8gdCA6 IE1NIURhdGFU
 eXBlU3R5bGUgKAoJCW5hbWUgPC0gcy5uYW1lLAoJCWluc3RhbmNlVHlwZSA8 LSBzLmluc3Rh
 bmNlVHlwZQoJKQp9CnJ1bGUgUl9JbnRWYWx1ZVN0eWxlIHsKCWZyb20gcyA6 IE1NIUludFZh
 bHVlU3R5bGUKCXRvIHQgOiBNTSFJbnRWYWx1ZVN0eWxlICgKCQluYW1lIDwt IHMubmFtZSwK
 CQlpbnRWYWx1ZSA8LSBzLmludFZhbHVlCgkpCn0KcnVsZSBSX0ludExpc3RW YWx1ZVN0eWxl
 IHsKCWZyb20gcyA6IE1NIUludExpc3RWYWx1ZVN0eWxlCgl0byB0IDogTU0h SW50TGlzdFZh
 bHVlU3R5bGUgKAoJCW5hbWUgPC0gcy5uYW1lLAoJCWludExpc3RWYWx1ZSA8 LSBzLmludExp
 c3RWYWx1ZQoJKQp9CnJ1bGUgUl9Cb29sZWFuVmFsdWVTdHlsZSB7Cglmcm9t IHMgOiBNTSFC
 b29sZWFuVmFsdWVTdHlsZQoJdG8gdCA6IE1NIUJvb2xlYW5WYWx1ZVN0eWxl ICgKCQluYW1l
 IDwtIHMubmFtZSwKCQlib29sZWFuVmFsdWUgPC0gcy5ib29sZWFuVmFsdWUK CSkKfQpydWxl
 IFJfRG91YmxlVmFsdWVTdHlsZSB7Cglmcm9tIHMgOiBNTSFEb3VibGVWYWx1 ZVN0eWxlCgl0
 byB0IDogTU0hRG91YmxlVmFsdWVTdHlsZSAoCgkJbmFtZSA8LSBzLm5hbWUs CgkJZG91Ymxl
 VmFsdWUgPC0gcy5kb3VibGVWYWx1ZQoJKQp9CnJ1bGUgUl9Eb3VibGVMaXN0 VmFsdWVTdHls
 ZSB7Cglmcm9tIHMgOiBNTSFEb3VibGVMaXN0VmFsdWVTdHlsZQoJdG8gdCA6 IE1NIURvdWJs
 ZUxpc3RWYWx1ZVN0eWxlICgKCQluYW1lIDwtIHMubmFtZSwKCQlkb3VibGVM aXN0VmFsdWUg
 PC0gcy5kb3VibGVMaXN0VmFsdWUKCSkKfQpydWxlIFJfU3RyaW5nVmFsdWVT dHlsZSB7Cglm
 cm9tIHMgOiBNTSFTdHJpbmdWYWx1ZVN0eWxlCgl0byB0IDogTU0hU3RyaW5n VmFsdWVTdHls
 ZSAoCgkJbmFtZSA8LSBzLm5hbWUsCgkJc3RyaW5nVmFsdWUgPC0gcy5zdHJp bmdWYWx1ZQoJ
 KQp9CnJ1bGUgUl9TdHJpbmdMaXN0VmFsdWVTdHlsZSB7Cglmcm9tIHMgOiBN TSFTdHJpbmdM
 aXN0VmFsdWVTdHlsZQoJdG8gdCA6IE1NIVN0cmluZ0xpc3RWYWx1ZVN0eWxl ICgKCQluYW1l
 IDwtIHMubmFtZSwKCQlzdHJpbmdMaXN0VmFsdWUgPC0gcy5zdHJpbmdMaXN0 VmFsdWUKCSkK
 fQpydWxlIFJfRU9iamVjdFZhbHVlU3R5bGUgewoJZnJvbSBzIDogTU0hRU9i amVjdFZhbHVl
 U3R5bGUKCXRvIHQgOiBNTSFFT2JqZWN0VmFsdWVTdHlsZSAoCgkJbmFtZSA8 LSBzLm5hbWUs
 CgkJZU9iamVjdFZhbHVlIDwtIHMuZU9iamVjdFZhbHVlCgkpCn0KcnVsZSBS X0VPYmplY3RM
 aXN0VmFsdWVTdHlsZSB7Cglmcm9tIHMgOiBNTSFFT2JqZWN0TGlzdFZhbHVl U3R5bGUKCXRv
 IHQgOiBNTSFFT2JqZWN0TGlzdFZhbHVlU3R5bGUgKAoJCW5hbWUgPC0gcy5u YW1lLAoJCWVP
 YmplY3RMaXN0VmFsdWUgPC0gcy5lT2JqZWN0TGlzdFZhbHVlCgkpCn0KcnVs ZSBSX0J5dGVB
 cnJheVZhbHVlU3R5bGUgewoJZnJvbSBzIDogTU0hQnl0ZUFycmF5VmFsdWVT dHlsZQoJdG8g
 dCA6IE1NIUJ5dGVBcnJheVZhbHVlU3R5bGUgKAoJCW5hbWUgPC0gcy5uYW1l LAoJCWJ5dGVB
 cnJheVZhbHVlIDwtIHMuYnl0ZUFycmF5VmFsdWUKCSkKfQpydWxlIFJfQm9v bGVhbkxpc3RW
 YWx1ZVN0eWxlIHsKCWZyb20gcyA6IE1NIUJvb2xlYW5MaXN0VmFsdWVTdHls ZQoJdG8gdCA6
 IE1NIUJvb2xlYW5MaXN0VmFsdWVTdHlsZSAoCgkJbmFtZSA8LSBzLm5hbWUs CgkJYm9vbGVh
 bkxpc3RWYWx1ZSA8LSBzLmJvb2xlYW5MaXN0VmFsdWUKCSkKfQpydWxlIFJf SGludGVkRGlh
 Z3JhbUxpbmtTdHlsZSB7Cglmcm9tIHMgOiBNTSFIaW50ZWREaWFncmFtTGlu a1N0eWxlCgl0
 byB0IDogTU0hSGludGVkRGlhZ3JhbUxpbmtTdHlsZSAoCgkJZGlhZ3JhbUxp bmsgPC0gcy5k
 aWFncmFtTGluaywKCQloaW50IDwtIHMuaGludAoJKQp9CnJ1bGUgUl9EaWFn cmFtTGlua1N0
 eWxlIHsKCWZyb20gcyA6IE1NIURpYWdyYW1MaW5rU3R5bGUKCXRvIHQgOiBN TSFEaWFncmFt
 TGlua1N0eWxlICgKCQlkaWFncmFtTGluayA8LSBzLmRpYWdyYW1MaW5rCgkp Cn0KcnVsZSBS
 X011bHRpRGlhZ3JhbUxpbmtTdHlsZSB7Cglmcm9tIHMgOiBNTSFNdWx0aURp YWdyYW1MaW5r
 U3R5bGUKCXRvIHQgOiBNTSFNdWx0aURpYWdyYW1MaW5rU3R5bGUgKAoJCWRp YWdyYW1MaW5r
cyA8LSBzLmRpYWdyYW1MaW5rcwoJKQp9Cg==
--------------020606000507040604020103--
| Re: [ATL] Processing GMF [message #80584 is a reply to message #80570] |
Thu, 01 May 2008 16:04   |
Eclipse User  |
Thank you. That could be. In GMF, there is an abstract class Style and the specialized styles (e.g. LineStyle, FillStyle, FontStyle, etc.) inherit from it.
Tomas
> Could it be that the problem is caused by a specialization relationship
> between the two classes?
> In that case a rule that matches the more generic class also matches the
> specialized class.
> If that is undesired you should add an additional condition with
> oclIsTypeOf() to the more general rule.
> HTH,
> Goetz
FUDForum. Page generated in 0.45238 seconds
