Home » Language IDEs » AspectJ » ADJT and workspace build errors
ADJT and workspace build errors [message #7123] Mon, 14 October 2002 21:35 Go to next message
Originally posted by: stephen.Townsend.impactblue.com
I have been able to successful use AspectJ as long as the workspace in under
the Eclipse workspace directory (default.) I need to be able to place
workspace directories in other locations. Doing so results in build errors,
even on saving (see below.)
I have not set the project as an AspectJ project so I would not assume this
to be a problem. Any how here's what I get when saving a file. Hope someone
can help.
org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gatingLoaderExce
ption: Attempt to load class "org.eclipse.ajdt.internal.builder.Builder"
from deactivated plug-in "org.eclipse.ajdt.ui".
org.eclipse.core.internal.plugins.PluginClassLoader.shouldLo okForClass(Plugi
nClassLoader.java:206)
org.eclipse.core.internal.plugins.PluginClassLoader.findClas sParentsSelf(Plu
ginClassLoader.java:125)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(Delegating
URLClassLoader.java:750)
URLClassLoader.java:730)
at java.lang.ClassLoader.loadClass(ClassLoader.java:262)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension
(PluginDescriptor.java:127)
(PluginDescriptor.java:164)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExten
sion(ConfigurationElement.java:102)
org.eclipse.core.internal.events.BuildManager.instantiateBui lder(BuildManage
r.java:486)
org.eclipse.core.internal.events.BuildManager.initializeBuil der(BuildManager
..java:441)
org.eclipse.core.internal.events.BuildManager.getBuilder(Bui ldManager.java:3
27)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:1
65)
86)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:146)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:839)
at org.eclipse.core.runtime.Platform.run(Platform.java:416)
60)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:211)
org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:74
5)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1383)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation
..java:78)
org.eclipse.ui.texteditor.AbstractTextEditor.performSaveOper ation(AbstractTe
xtEditor.java:2329)
org.eclipse.ui.texteditor.AbstractTextEditor.doSave(Abstract TextEditor.java:
2183)
at org.eclipse.ui.internal.EditorManager$11.run(EditorManager.j ava:1004)
at org.eclipse.ui.internal.EditorManager$8.run(EditorManager.ja va:873)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.jav
a:299)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:249)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:394)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:391)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:1126)
org.eclipse.ui.internal.EditorManager.runProgressMonitorOper ation(EditorMana
ger.java:879)
at org.eclipse.ui.internal.EditorManager.saveEditor(EditorManag er.java:1009)
at org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:1966)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:32)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:749 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:407)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionCont
ributionItem.java:361)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionI
tem.java:352)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(A
ctionContributionItem.java:47)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:827)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1529)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1256)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1239)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:775)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
Re: ADJT and workspace build errors [message #9301 is a reply to message #7123] Sun, 27 October 2002 07:54 Go to previous message
> can help.
> at
Hi Stephen,
We've had some problems with the plugin when users work outside of the
normal workspace (we did very little testing with that kind of setup).
Can you tell me which directories you want to have outside of the eclipse
workspace? The source for your project? The binaries for your project? Or
both? (We can then include the scenario in our testing)
But I'm a little confused by the fact that you say you have a non AspectJ
project and it is failing to save with an aspectJ error? Looking at the
error, the fact that it says "from deactivated plugin
'org.eclipse.ajdt.ui'" usually means something went wrong previously that
deactivated the plugin - were there other relevant errors in the metadata
log file for your eclipse workspace?
There is some magic to get the plugin re-activated, as you can see
discussed on the other thread "ADJT Plugin Loading/Build Errors".
Andy Clement
AJDT Development
Re: ADJT and workspace build errors [message #562342 is a reply to message #7123] Sun, 27 October 2002 07:54 Go to previous message
> can help.
> at
Hi Stephen,
Andy Clement
AJDT Development
Previous Topic:Novice question on the use of static introductions
Next Topic:Novice question on the use of static introductions
Current Time: Wed Oct 29 14:09:22 EDT 2025
Powered by FUDForum. Page generated in 0.03387 seconds
