Home » Archived » Test and Performance Tools Platform (TPTP) » Agent Controller setup
Agent Controller setup [message #79478] Wed, 02 August 2006 09:52 Go to next message
Originally posted by: vichandoko.yahoo.com
I am trying to follow the installation of TPTP
( http://www.eclipse.org/tptp/home/downloads/installguide/Inst allGuide42.html)
which lead me to installing the Agent Controller.
I've downloaded
http://www.eclipse.org/downloads/download.php?file=/tptp/4.2 .0/TPTP-4.2.0-200606190100A/javaprofiler.win_em64t-TPTP-4.2. 0.zip
and follows the following installation guide
http://www.eclipse.org/tptp/home/downloads/installguide/agen tcontroller_42/win_ia32/getting_started.html
But after when i tried to execute ACServer.exe the following error is
prompted:
"<install_path>\bin\ACServer.exe is not a valid Win32 application" and on
console, message "Access is denied." and the program terminates.
i could not seems to find any logs anywhere.
Any idea?
By the way, is setting up Agent Controller a necessary to run TPTP?
Thanks.
Veny
Re: Agent Controller setup [message #79540 is a reply to message #79478] Wed, 02 August 2006 14:10 Go to previous messageGo to next message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 004DF3F2852571BE_=
Content-Type: text/plain; charset="US-ASCII"
You probably downloaded the wrong Windows version. It's most likely that
you downloaded the Windows-IPF or Windows-EM64T versions. Try downloading
the Windows-IA32 version.
No, you don't need the Agent Controller if you're running things locally.
You can use the Integrated Agent Controller (IAC), which is included as
part of the TPTP plugins. You'll need the Agent Controller on your target
machine if you're running things remotely.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">You probably downloaded the wrong Windows
version. &nbsp;It's most likely that you downloaded the Windows-IPF or
Windows-EM64T versions. &nbsp;Try downloading the Windows-IA32 version.
</font>
<br><tt><font size=2><br>
&gt;By the way, is setting up Agent Controller a necessary to run TPTP?<br>
</font></tt>
<br><font size=2 face="sans-serif">No, you don't need the Agent Controller
if you're running things locally. &nbsp;You can use the Integrated Agent
Controller (IAC), which is included as part of the TPTP plugins. &nbsp;You'll
need the Agent Controller on your target machine if you're running things
remotely.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 004DF3F2852571BE_=--
Re: Agent Controller setup [message #79781 is a reply to message #79540] Thu, 03 August 2006 02:30 Go to previous messageGo to next message
Thanks for your reply.
I've downloaded the IA version too, but does not seems to work properly.
On windows, what should i check on to decide which version of the agent
controller i should be using? How about on Linux?
Also i've extracted the main TPTP package into eclipse installation. But
does not seem to find the new plugin. When i go to File -> New -> Other,
there is no 'Test' menu shown. How do i check what i've configured
wrongly? Or is there any dependency on other eclipse plugin and its
version?
Thanks.
Veny
Re: Agent Controller setup [message #79855 is a reply to message #79781] Thu, 03 August 2006 18:03 Go to previous message
Randy D. Smith is currently offline Randy D. SmithFriend
Veny wrote:
Symptoms/results? What did you see to say it's not working correctly?
On Windows, Right-click on My Computer => Properties and see what System
it says... My EM64T system says "Microsoft Windows Server 2003
Enterprise x64 Edition Service Pack 1" ... I use agntctrl.win_em64t
downloads there; my Itanium system says "Microsoft Windows Server 2003
Enterprise Edition Service Pack 1" ... I use agntctrl.win_ipf downloads
there; and my laptop says "Microsoft Windows XP Professional Version
2002 Service Pack 2" ... I use agntctrl.win_ia32 downloads there.
I think the ia32 version will work on both of the other systems, but you
have to be careful the "environment" you run it in (making sure not to
mix with "native" 64-bit code on those systems).
Linux -- uname -m should give you the info you need. i686 => Linux-IA32,
ia64 => Linux-IPF, and x86_64 => Linux-EM64T.
> version?
Extracted into the eclipse installation? That's SO pre-Callisto! :-) The
Update Manager is your FRIEND!!
If you've done this, I expect you didn't read the download page's
Requirements list, right? Before TPTP will work, you'd need EMF&XSD
installed into your Eclipse installation as well.
Better to (1) Get Eclipse (platform runtime or SDK or Eclipse SDK) and
then use the Help => Software Updates => Find and Install... and go to
the Callisto Discovery Site, select TPTP and "Select Required" to get
Requirements met.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Previous Topic:In need of suggestions debugging the TPTP
Next Topic:Agent Controller Confusion
Current Time: Sat Dec 21 13:14:22 GMT 2024
Powered by FUDForum. Page generated in 0.03101 seconds
