Home » Language IDEs » PHP Development Tools (PDT) » PHP missing since EMF update
PHP missing since EMF update [message #79418] Wed, 03 September 2008 04:47 Go to next message
Originally posted by: dafish.soundtrack-board.de
Eclipse showed an EMF update yesterday and I installed it. After the
neccesary restart, the PHP perspective is gone and I'm unable to get it
back.
I've tried to reinstall PHP both through the Update feature and by
downloading the latest 1.0.3 release. Nothing worked.
Any chance of getting my "old" configuration back?
Marcus
Re: PHP missing since EMF update [message #79433 is a reply to message #79418] Wed, 03 September 2008 08:41 Go to previous messageGo to next message
Marcus,
Try running with "-clean -debug" and have a close look at
<workspace>/.metadata/.log. You might want to delete this file first so
you create a fresh new one. With the -debug flag, there should be
detailed messages about why a feature or plugin fails to activate
(typically because of version range restrictions). Which Eclipse are
you on and which EMF did you update to?
Marcus Stöhr wrote:
> it back.
> Best regards,
> Marcus
Re: PHP missing since EMF update [message #79447 is a reply to message #79433] Wed, 03 September 2008 12:15 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
PDT 1.0.3 is targeted for Eclipse 3.3, WTP 2.0, and EMF 2.3.
http://download.eclipse.org/tools/pdt/downloads/release.php? release=R20080603
If you're using something newer, YMMV.
If you want a PDT that works with Eclipse 3.4, use the latest Nightly
build of PDT 2.0.
If you want one that works with Eclipse 3.5, you'll have to wait until
2.0 is released.The latest EMF build (from yesterday) is for Eclipse 3.5
-- there are no guarantees that the still-in-progress Eclipse 3.5 + EMF
2.5 will work for the still-in-progress PDT 2.0 (which is being built
with Eclipse 3.4, not 3.5.)
If you want to develop PHP without having to worry about Eclipse
version, WTP version, or EMF version, get phpeclipse. It may not be
quite as feature-rich, but it's MUCH easier to install. :)
Nick
Ed Merks wrote:
> Marcus,
> Marcus Stöhr wrote:
>> it back.
>> Best regards,
>> Marcus
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: PHP missing since EMF update [message #79535 is a reply to message #79433] Thu, 04 September 2008 04:32 Go to previous messageGo to next message
Ed Merks schrieb:
> Marcus,
> Marcus Stöhr wrote:
>> it back.
>> Best regards,
>> Marcus
Ed,
thanks for the hint with the .log-File. Some of the entries indicate
problems with EMF:
!ENTRY org.eclipse.osgi 2 0 2008-09-04 09:17:51.212
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-04 09:17:51.212
!MESSAGE Bundle
update@plugins/org.eclipse.wst.web.ui_1.1.101.v200706071630.jar was not
resolved.
!SUBENTRY 2 org.eclipse.wst.web.ui 2 0 2008-09-04 09:17:51.212
!MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.2.0,2.4.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.ecore.change.edit_2.4.0.v200808251517.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.ecore.change.edit 2 0 2008-09-04 09:17:51.213
!MESSAGE Missing required bundle org.eclipse.core.runtime_[3.4.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-04 09:17:51.213
This goes on to the PDT feature:
!MESSAGE Bundle update@plugins/org.eclipse.php.core_1.0.3.v20080603.jar
[181] was not resolved.
!SUBENTRY 2 org.eclipse.php.core 2 0 2008-09-04 09:17:51.230
!MESSAGE Missing required bundle org.eclipse.wst.sse.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.wst.html.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.wst.xml.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.wst.validation_0.0.0.
!MESSAGE Missing required bundle org.eclipse.wst.common.frameworks_0.0.0.
!MESSAGE Missing required bundle org.eclipse.jem.util_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-04 09:17:51.230
I'm using latest 3.3 and EMF is version 2.4.1 now.
Re: PHP missing since EMF update [message #79550 is a reply to message #79535] Thu, 04 September 2008 14:31 Go to previous messageGo to next message
Marcus,
EMF 2.4 targets Eclipse 3.4 and doesn't work with Eclipse 3.3. You'll
need EMF 2.3 for it to work with Eclipse 3.3.
Marcus Stöhr wrote:
> Ed Merks schrieb:
>> Marcus,
>> so you create a fresh new one. With the -debug flag, there should be
>> Marcus Stöhr wrote:
>>> Hi,
>>> it back.
>>> Best regards,
>>> Marcus
> Ed,
> problems with EMF:
> root constraints are not resolved:
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> update@plugins/org.eclipse.php.core_1.0.3.v20080603.jar [181] was not
> resolved.
Re: PHP missing since EMF update [message #79565 is a reply to message #79550] Fri, 05 September 2008 03:25 Go to previous messageGo to next message
Ed Merks schrieb:
> Marcus,
Ed,
this explains my problems. But I'm wondering why Eclipse would show EMF
2.4 in my Eclipse 3.3 environment?
But thanks for the information and I'll try to fix my installation. :)
-Marcus
Re: PHP missing since EMF update [message #79579 is a reply to message #79565] Fri, 05 September 2008 08:05 Go to previous messageGo to next message
Marcus,
Yes, it seems kind of unhelpful to suggest/allow choices that are known
to have unsatisfiable constraints...
Marcus Stöhr wrote:
> Ed Merks schrieb:
>> Marcus,
>> You'll need EMF 2.3 for it to work with Eclipse 3.3.
> Ed,
> EMF 2.4 in my Eclipse 3.3 environment?
> -Marcus
Re: PHP missing since EMF update [message #79623 is a reply to message #79579] Fri, 05 September 2008 13:19 Go to previous message
Ed Merks schrieb:
> Marcus,
> Marcus Stöhr wrote:
>> Ed Merks schrieb:
>>> Marcus,
>> Ed,
>> -Marcus
However,
I did it and made the step to Ganymede today and beside some annoyances,
everything works as expected.
Previous Topic:PDT - 'An internal error occured during Selection Job titile'
Next Topic:PDT 2.0 "Show variables from other files" is slow and cannot be turned off
Current Time: Thu Oct 16 02:48:51 EDT 2025
Powered by FUDForum. Page generated in 0.05829 seconds
