Home » Modeling » GMF (Graphical Modeling Framework) » Create a .xxx_diagram by Action
Create a .xxx_diagram by Action [message #79295] Tue, 21 November 2006 09:53 Go to next message
Originally posted by: julias.frb.br
How one can call the digram creation wizard by a custom Action
(org.eclipse.jface.action.Action)?
Julia
Re: Create a .xxx_diagram by Action [message #79310 is a reply to message #79295] Tue, 21 November 2006 09:57 Go to previous messageGo to next message
> Thanks
> Julia
Sorry, being more specific, i've created an Action that have:
public void run() {
try{
final HiperioncadCreationWizard theWiz = new
hiperioncad.diagram.part.HiperioncadCreationWizard();
final Shell shell =
RoxUIPlugin.getDefault().getWorkbench().getActiveWorkbenchWi ndow().getShell();
final WizardDialog dialog = new WizardDialog(shell, (IWizard) theWiz);
dialog.create();
theWiz.init(RoxUIPlugin.getDefault().getWorkbench(), selection);
dialog.open();
}catch(Exception e){
e.printStackTrace();
but i keep getting this:
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.wiza rds.EditorWizardPage.initialPopulateContainerNameField(Edito rWizardPage.java:304)
org.eclipse.ui.dialogs.WizardNewFileCreationPage.createContr ol(WizardNewFileCreationPage.java:199)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.wiza rds.EditorWizardPage.createControl(EditorWizardPage.java:286 )
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:180)
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:614)
org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:502)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1124)
at org.eclipse.jface.window.Window.open(Window.java:785)
org.projetorox.rox.ui.actions.NewResourceAction.run(NewResou rceAction.java:61)
Help please!
Re: Create a .xxx_diagram by Action [message #79412 is a reply to message #79310] Tue, 21 November 2006 11:17 Go to previous messageGo to next message
Hello Julia,
Can you take a look on generated ???InitDiagramFileAction ? Looks this is
implementation of such action.
Alex Shatalin
Re: Create a .xxx_diagram by Action [message #79471 is a reply to message #79412] Tue, 21 November 2006 12:40 Go to previous messageGo to next message
Alex,
the ???InitDiagramFileAction implements an IObjectActionDelegate and not
an IAction.
Because of this it does not implement the setActivePart method that the
InitDiagramFileAction needs..
How can i get the active workbench editpart in a common Action? is that
possible?
im trying to call the whole creation (ecore and diagram) from a simple
menu in my plugin, to ease the process to the final user (will click New
project, then New Diagram rather than New project, then right click on
the project, new, Example, Diagram)
if i could get the wizard to work from the action would be perfect! ^^
can you help me?
Thanks!
Alex Shatalin wrote:
> Hello Julia,
> is implementation of such action.
> Alex Shatalin
Re: Create a .xxx_diagram by Action [message #79529 is a reply to message #79471] Tue, 21 November 2006 13:28 Go to previous messageGo to next message
Hello Julia,
You can take a look on existing implementations of IAction interface dealing
with IObjectActionDelegate - org.eclipse.ui.internal.handlers.ActionDelegateHandlerProxy.
In initDelegate() it is getting active part with the following code snippet:
final IWorkbenchPage page = window.getActivePage();
activePart = page.getActivePart();
window instance you can get using: PlatformUI.getWorkbench().getActiveWorkbenchWindow()
Alex Shatalin
Re: Create a .xxx_diagram by Action [message #79558 is a reply to message #79529] Tue, 21 November 2006 13:59 Go to previous messageGo to next message
Thanks Alex, i found out that i have to put the wizard to work, i did this:
try{
final HiperioncadCreationWizard theWiz = new HiperioncadCreationWizard();
final Shell shell =
final WizardDialog dialog = new WizardDialog(shell, theWiz);
dialog.open();
and im getting a NullPointerException on:
do you have any clue?
thanks again =)
> Hello Julia,
> dealing with IObjectActionDelegate -
> org.eclipse.ui.internal.handlers.ActionDelegateHandlerProxy. In
> Alex Shatalin
Re: Create a .xxx_diagram by Action [message #79573 is a reply to message #79558] Tue, 21 November 2006 14:35 Go to previous messageGo to next message
Hello Julia,
> at
> WizardPage.initialPopulateContainerNameField(EditorWizardPag e.java:304)
Well, I think the selection is null (you can check it in the debugger). You
should create StructuredSelection instance passing desired file as a parameter.
Then you are calling popup menu on some file the selection is equals to this
file, so corresponding parameter will be passed to ???InitDiagramFileAction...
Alex Shatalin
Re: Create a .xxx_diagram by Action [message #79587 is a reply to message #79573] Tue, 21 November 2006 14:49 Go to previous messageGo to next message
Thanks Alex! it worked!! ^^
(by the way, do you know how to show a grid automatically on the diagram?)
here's the final solution:
public void run() {
try{
IStructuredSelection selection = new
StructuredSelection(RoxUIPlugin.getDefault().getWorkbench(). getActiveWorkbenchWindow().getActivePage().getSelection());
WizardDialog(RoxUIPlugin.getDefault().getWorkbench().getActi veWorkbenchWindow().getShell(),
theWiz);
dialog.open();
Thanks!!
> Hello Julia,
>> at
> You should create StructuredSelection instance passing desired file as a
> parameter. Then you are calling popup menu on some file the selection is
> equals to this file, so corresponding parameter will be passed to
> Alex Shatalin
Re: Create a .xxx_diagram by Action [message #165266 is a reply to message #79587] Thu, 13 December 2007 08:20 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
Hi Alex and Julia.
First, thank you Julia for posting your solution!
Second, is it possible to create the diagram without launching the
wizard? (The action creates a new diagram with default values)
Best Regards,
Tomas Zijdemans
> public void run() {
> try{
> theWiz);
> dialog.open();
> Thanks!!
>> Hello Julia,
>>> at
>> debugger). You should create StructuredSelection instance passing
>> desired file as a parameter. Then you are calling popup menu on some
>> file the selection is equals to this file, so corresponding parameter
>> Alex Shatalin
Re: Create a .xxx_diagram by Action [message #169393 is a reply to message #79587] Wed, 23 January 2008 04:00 Go to previous messageGo to next message
I have a follow up on this. Would it be possible to:
1. Create an action which opens a XYZdiagram.
2. Then loads that diagrams resource together with the diagram the
action was lanched from?
Diagram Partitioning does this. There is some code in the
opendiagrambehavior that syncs the resources. Maybe this code could be
made to work in an action?
That would be very cool!
Tomas Zijdemans
> public void run() {
> try{
> theWiz);
> dialog.open();
> Thanks!!
>> Hello Julia,
>>> at
>> Alex Shatalin
Re: Create a .xxx_diagram by Action [message #169432 is a reply to message #169393] Wed, 23 January 2008 05:46 Go to previous messageGo to next message
Hello Tomas,
Sorry, did not get the quiestion.
If you need this question - just copy the code from generated OpenDiagramEditPolicy
- it should contains all you need to open an editor for the diagram file.
By default parent- and child- diagrams will be stored in the same EMF Resource,
so parent diagram will be automatically loaded into the corresponsing ResourceSet
on openning child- one.
Alex Shatalin
Re: Create a .xxx_diagram by Action [message #169481 is a reply to message #169432] Wed, 23 January 2008 07:20 Go to previous messageGo to next message
> Hello Tomas,
Ok. Sorry for explaining unclear. I have 2 different diagrams. I want to
launch one of them from a popupaction (attached to an element in the
other diagram)
> the code from generated OpenDiagramEditPolicy - it should contains all
Ok. Guess It is this:
for (Iterator it = diagramFacet.eResource().getResourceSet()
..getResources().iterator(); it.hasNext();) {
Resource nextResource = (Resource) it.next();
if (nextResource.isLoaded() &&
!getEditingDomain().isReadOnly(nextResource)) {
nextResource.save(EditorDiagramEditorUtil .getSaveOptions());
> Resource, so parent diagram will be automatically loaded into the
> corresponsing ResourceSet on openning child- one.
I see. These diagrams are not parent/child (they are unrelated). Is this
still possible?
Thanks for helping!
Tomas Zijdemans
Re: Create a .xxx_diagram by Action [message #169550 is a reply to message #169481] Wed, 23 January 2008 13:05 Go to previous messageGo to next message
Hello Tomas,
> this still possible?
Well, OpenDiagramEditPolicy will put new "unrelated" diagram for the diagram
element you double-click on into the same diagram Resource, so it is possible.
If you need to store it in a different resource - you should modify DocumentProvider
to preload this resource on creating new instance of EditingDomain.
Alex Shatalin
Re: Create a .xxx_diagram by Action [message #170334 is a reply to message #79587] Tue, 29 January 2008 05:49 Go to previous messageGo to next message
> public void run() {
> try{
Where does RoxUIPlugin come from? What kind of class is it?
> theWiz);
> dialog.open();
> Thanks!!
>> Hello Julia,
>>> at
>> Alex Shatalin
Re: Create a .xxx_diagram by Action [message #170358 is a reply to message #170334] Tue, 29 January 2008 06:13 Go to previous messageGo to next message
Nevermind :)
However: Is it possible to create this new diagram without using the
wizard (like diagrampartitioning does) ?
Tomas
>> diagram?)
>> public void run() {
>> try{
>> theWiz);
>> dialog.open();
>> Thanks!!
>>> Hello Julia,
>>>> at
>>> Alex Shatalin
Re: Create a .xxx_diagram by Action [message #170366 is a reply to message #170358] Tue, 29 January 2008 06:27 Go to previous messageGo to next message
Hello Tomas,
Sure! just copy a code from diagram partitioning into your own action.
Alex Shatalin
Re: Create a .xxx_diagram by Action [message #170396 is a reply to message #170366] Tue, 29 January 2008 07:25 Go to previous messageGo to next message
Thanks for helping (again) Alex :)
I've basically just copied the code in (as you can see below). The only
thing that gave an error was:
EditPart targetEditPart = getTargetEditPart(request);
so I replaced it with:
EditPart targetEditPart = selectedElement;
My question is:
What do I put in the run method? - I guess the getOpenCommand have to be
called.. but with what kind of reqest as parameter?
Tomas
public class UEMLBaseLaunchEditorAction implements IObjectActionDelegate {
public ClassNodeEditPart selectedElement;
public Shell shell;
public void run(IAction action) {
* @generated
protected Command getOpenCommand(Request request) {
if (false == targetEditPart.getModel() instanceof View) {
return null;
View view = (View) targetEditPart.getModel();
Style link = view.getStyle(NotationPackage.eINSTANCE
.getHintedDiagramLinkStyle());
if (false == link instanceof HintedDiagramLinkStyle) {
return null;
return new ICommandProxy(new OpenDiagramCommand(
(HintedDiagramLinkStyle) link));
* @generated
private static class OpenDiagramCommand extends
AbstractTransactionalCommand {
* @generated
private final HintedDiagramLinkStyle diagramFacet;
* @generated
OpenDiagramCommand(HintedDiagramLinkStyle linkStyle) {
// editing domain is taken for original diagram,
// if we open diagram from another file, we should use another
// editing domain
super(TransactionUtil.getEditingDomain(linkStyle),
Messages.CommandName_OpenDiagram, null);
diagramFacet = linkStyle;
// FIXME canExecute if !(readOnly && getDiagramToOpen == null), i.e.
// open works on ro diagrams only when there's associated diagram
// already
* @generated
protected CommandResult doExecuteWithResult(IProgressMonitor monitor,
IAdaptable info) throws ExecutionException {
try {
Diagram diagram = getDiagramToOpen();
if (diagram == null) {
diagram = intializeNewDiagram();
URI uri = EcoreUtil.getURI(diagram);
String editorName = uri.lastSegment()
+ "#" + diagram.eResource().getContents().indexOf(diagram);
//$NON-NLS-1$
IEditorInput editorInput = new URIEditorInput(uri, editorName);
IWorkbenchPage page = PlatformUI.getWorkbench()
.getActiveWorkbenchWindow().getActivePage();
page.openEditor(editorInput, getEditorID());
return CommandResult.newOKCommandResult();
} catch (Exception ex) {
throw new ExecutionException("Can't open diagram", ex);
* @generated
protected Diagram getDiagramToOpen() {
return diagramFacet.getDiagramLink();
* @generated
protected Diagram intializeNewDiagram() throws ExecutionException {
Diagram d = ViewService.createDiagram(getDiagramDomainElement(),
getDiagramKind(), getPreferencesHint());
if (d == null) {
throw new ExecutionException("Can't create diagram of '"
+ getDiagramKind() + "' kind");
diagramFacet.setDiagramLink(d);
assert diagramFacet.eResource() != null;
diagramFacet.eResource().getContents().add(d);
try {
&& !getEditingDomain().isReadOnly(nextResource)) {
.getSaveOptions());
} catch (IOException ex) {
+ getDiagramKind() + "' kind", ex);
return d;
* @generated
protected EObject getDiagramDomainElement() {
// use same element as associated with EP
return ((View) diagramFacet.eContainer()).getElement();
* @generated
protected PreferencesHint getPreferencesHint() {
// XXX prefhint from target diagram's editor?
return EditorDiagramEditorPlugin.DIAGRAM_PREFERENCES_HINT;
* @generated
protected String getDiagramKind() {
return "Class";
* @generated
protected String getEditorID() {
return "org.ueml.uemlbase.editor.diagram.part.ClassDiagramEditorID";
public void selectionChanged(IAction action, ISelection selection) {
selectedElement = null;
if (selection instanceof IStructuredSelection) {
IStructuredSelection structuredSelection = (IStructuredSelection)
selection;
if (structuredSelection.getFirstElement() instanceof ClassNodeEditPart) {
selectedElement = (ClassNodeEditPart) structuredSelection
.getFirstElement();
public void setActivePart(IAction action, IWorkbenchPart targetPart) {
shell = targetPart.getSite().getShell();
Re: Create a .xxx_diagram by Action [message #170404 is a reply to message #170396] Tue, 29 January 2008 07:51 Go to previous messageGo to next message
I've sort of worked it out by putting the code for doExecute into the
run method.
However, this method calls the initializer method (see under) which uses
a variable: diagramFacet. What should this be replaced with?
if (d == null) {
try {
it.hasNext();) {
if (nextResource.isLoaded()) {
nextResource.save(EditorDiagramEditorUtil.getSaveOptions());
return d;
Re: Create a .xxx_diagram by Action [message #170427 is a reply to message #170404] Tue, 29 January 2008 08:13 Go to previous messageGo to next message
Hello Tomas,
> run method.
That's right!
> uses a variable: diagramFacet. What should this be replaced with?
diagramFacet is a kind of reference from original diagram node to the associated
diagram. In the sample of code you pasted here you are creating new diagram
and associating this newly created diagram with the diagram node via diagramFacet.
On next execution of this action you can check if corresponding association
was already created and use existing diagram instead of openning new one.
You can get diagramFacet instance from the original diagram element (EditPart)
by calling
(HintedDiagramLinkStyle) ((View) EditPart.getModel()).getStyle(NotationPackage.eINSTANCE.getH intedDiagramLinkStyle())
Alex Shatalin
Re: Create a .xxx_diagram by Action [message #170458 is a reply to message #170427] Tue, 29 January 2008 08:39 Go to previous messageGo to next message
--------------030605000408000005030906
Content-Type: text/plain; charset=UTF-8; format=flowed
> (EditPart) by calling
Thanks! That got me a lot closer to a working solution. Now, however,
when I launch the action - I get a message that the action is unavailable.
Attaching the code.
name="UEMLBaseLaunchEditorAction.java"
Content-Disposition: inline;
filename="UEMLBaseLaunchEditorAction.java"
cGFja2FnZSBvcmcudWVtbC51ZW1sYmFzZS5lZGl0b3IuZGlhZ3JhbS5wYXJ0 Ow0KDQppbXBv
cnQgamF2YS5pby5JT0V4Y2VwdGlvbjsNCmltcG9ydCBqYXZhLnV0aWwuSXRl cmF0b3I7DQoN
CmltcG9ydCBvcmcuZWNsaXBzZS5jb3JlLmNvbW1hbmRzLkV4ZWN1dGlvbkV4 Y2VwdGlvbjsN
CmltcG9ydCBvcmcuZWNsaXBzZS5lbWYuY29tbW9uLnVpLlVSSUVkaXRvcklu cHV0Ow0KaW1w
b3J0IG9yZy5lY2xpcHNlLmVtZi5jb21tb24udXRpbC5VUkk7DQppbXBvcnQg b3JnLmVjbGlw
c2UuZW1mLmVjb3JlLkVPYmplY3Q7DQppbXBvcnQgb3JnLmVjbGlwc2UuZW1m LmVjb3JlLnJl
c291cmNlLlJlc291cmNlOw0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5lY29y ZS51dGlsLkVj
b3JlVXRpbDsNCmltcG9ydCBvcmcuZWNsaXBzZS5nbWYucnVudGltZS5kaWFn cmFtLmNvcmUu
cHJlZmVyZW5jZXMuUHJlZmVyZW5jZXNIaW50Ow0KaW1wb3J0IG9yZy5lY2xp cHNlLmdtZi5y
dW50aW1lLmRpYWdyYW0uY29yZS5zZXJ2aWNlcy5WaWV3U2VydmljZTsNCmlt cG9ydCBvcmcu
ZWNsaXBzZS5nbWYucnVudGltZS5ub3RhdGlvbi5EaWFncmFtOw0KaW1wb3J0 IG9yZy5lY2xp
cHNlLmdtZi5ydW50aW1lLm5vdGF0aW9uLkhpbnRlZERpYWdyYW1MaW5rU3R5 bGU7DQppbXBv
cnQgb3JnLmVjbGlwc2UuZ21mLnJ1bnRpbWUubm90YXRpb24uTm90YXRpb25Q YWNrYWdlOw0K
aW1wb3J0IG9yZy5lY2xpcHNlLmdtZi5ydW50aW1lLm5vdGF0aW9uLlZpZXc7 DQppbXBvcnQg
b3JnLmVjbGlwc2UuamZhY2UuYWN0aW9uLklBY3Rpb247DQppbXBvcnQgb3Jn LmVjbGlwc2Uu
amZhY2Uudmlld2Vycy5JU2VsZWN0aW9uOw0KaW1wb3J0IG9yZy5lY2xpcHNl LmpmYWNlLnZp
ZXdlcnMuSVN0cnVjdHVyZWRTZWxlY3Rpb247DQppbXBvcnQgb3JnLmVjbGlw c2Uuc3d0Lndp
ZGdldHMuU2hlbGw7DQppbXBvcnQgb3JnLmVjbGlwc2UudWkuSUVkaXRvcklu cHV0Ow0KaW1w
b3J0IG9yZy5lY2xpcHNlLnVpLklPYmplY3RBY3Rpb25EZWxlZ2F0ZTsNCmlt cG9ydCBvcmcu
ZWNsaXBzZS51aS5JV29ya2JlbmNoUGFnZTsNCmltcG9ydCBvcmcuZWNsaXBz ZS51aS5JV29y
a2JlbmNoUGFydDsNCmltcG9ydCBvcmcuZWNsaXBzZS51aS5QbGF0Zm9ybVVJ Ow0KaW1wb3J0
IG9yZy51ZW1sLnVlbWxiYXNlLmVkaXRvci5kaWFncmFtLmVkaXQucGFydHMu Q2xhc3NEaWFn
cmFtRWxlbWVudEVkaXRQYXJ0Ow0KDQpwdWJsaWMgY2xhc3MgVUVNTEJhc2VM YXVuY2hFZGl0
b3JBY3Rpb24gaW1wbGVtZW50cyBJT2JqZWN0QWN0aW9uRGVsZWdhdGUgew0K DQoJcHVibGlj
IENsYXNzRGlhZ3JhbUVsZW1lbnRFZGl0UGFydCBzZWxlY3RlZEVsZW1lbnQ7 DQoJcHVibGlj
IFNoZWxsIHNoZWxsOw0KCXB1YmxpYyBIaW50ZWREaWFncmFtTGlua1N0eWxl IGRpYWdyYW1G
YWNldCA9IChIaW50ZWREaWFncmFtTGlua1N0eWxlKSAoKFZpZXcpIHNlbGVj dGVkRWxlbWVu
dA0KCQkJLmdldE1vZGVsKCkpLmdldFN0eWxlKE5vdGF0aW9uUGFja2FnZS5l SU5TVEFOQ0UN
CgkJCS5nZXRIaW50ZWREaWFncmFtTGlua1N0eWxlKCkpOw0KDQoJcHVibGlj IHZvaWQgcnVu
KElBY3Rpb24gYWN0aW9uKSB7DQoNCgkJdHJ5IHsNCgkJCURpYWdyYW0gZGlh Z3JhbSA9IGdl
dERpYWdyYW1Ub09wZW4oKTsNCgkJCWlmIChkaWFncmFtID09IG51bGwpIHsN CgkJCQlkaWFn
cmFtID0gaW50aWFsaXplTmV3RGlhZ3JhbSgpOw0KCQkJfQ0KCQkJVVJJIHVy aSA9IEVjb3Jl
VXRpbC5nZXRVUkkoZGlhZ3JhbSk7DQoJCQlTdHJpbmcgZWRpdG9yTmFtZSA9 IHVyaS5sYXN0
U2VnbWVudCgpDQoJCQkJCSsgIiMiICsgZGlhZ3JhbS5lUmVzb3VyY2UoKS5n ZXRDb250ZW50
cygpLmluZGV4T2YoZGlhZ3JhbSk7IC8vJE5PTi1OTFMtMSQNCgkJCUlFZGl0 b3JJbnB1dCBl
ZGl0b3JJbnB1dCA9IG5ldyBVUklFZGl0b3JJbnB1dCh1cmksIGVkaXRvck5h bWUpOw0KCQkJ
SVdvcmtiZW5jaFBhZ2UgcGFnZSA9IFBsYXRmb3JtVUkuZ2V0V29ya2JlbmNo KCkNCgkJCQkJ
LmdldEFjdGl2ZVdvcmtiZW5jaFdpbmRvdygpLmdldEFjdGl2ZVBhZ2UoKTsN CgkJCXBhZ2Uu
b3BlbkVkaXRvcihlZGl0b3JJbnB1dCwgZ2V0RWRpdG9ySUQoKSk7DQoNCgkJ fSBjYXRjaCAo
RXhjZXB0aW9uIGV4KSB7DQoNCgkJfQ0KCX0NCg0KCS8qKg0KCSAqIEBnZW5l cmF0ZWQNCgkg
Ki8NCglwcm90ZWN0ZWQgRGlhZ3JhbSBnZXREaWFncmFtVG9PcGVuKCkgew0K CQlyZXR1cm4g
ZGlhZ3JhbUZhY2V0LmdldERpYWdyYW1MaW5rKCk7DQoJfQ0KDQoJcHJvdGVj dGVkIERpYWdy
YW0gaW50aWFsaXplTmV3RGlhZ3JhbSgpIHRocm93cyBFeGVjdXRpb25FeGNl cHRpb24gew0K
CQlEaWFncmFtIGQgPSBWaWV3U2VydmljZS5jcmVhdGVEaWFncmFtKGdldERp YWdyYW1Eb21h
aW5FbGVtZW50KCksDQoJCQkJZ2V0RGlhZ3JhbUtpbmQoKSwgZ2V0UHJlZmVy ZW5jZXNIaW50
KCkpOw0KCQlpZiAoZCA9PSBudWxsKSB7DQoJCQl0aHJvdyBuZXcgRXhlY3V0 aW9uRXhjZXB0
aW9uKCJDYW4ndCBjcmVhdGUgZGlhZ3JhbSBvZiAnIg0KCQkJCQkrIGdldERp YWdyYW1LaW5k
KCkgKyAiJyBraW5kIik7DQoJCX0NCg0KCQlkaWFncmFtRmFjZXQuc2V0RGlh Z3JhbUxpbmso
ZCk7DQoJCWFzc2VydCBkaWFncmFtRmFjZXQuZVJlc291cmNlKCkgIT0gbnVs bDsNCgkJZGlh
Z3JhbUZhY2V0LmVSZXNvdXJjZSgpLmdldENvbnRlbnRzKCkuYWRkKGQpOw0K CQl0cnkgew0K
CQkJZm9yIChJdGVyYXRvciBpdCA9IGRpYWdyYW1GYWNldC5lUmVzb3VyY2Uo KS5nZXRSZXNv
dXJjZVNldCgpDQoJCQkJCS5nZXRSZXNvdXJjZXMoKS5pdGVyYXRvcigpOyBp dC5oYXNOZXh0
KCk7KSB7DQoJCQkJUmVzb3VyY2UgbmV4dFJlc291cmNlID0gKFJlc291cmNl KSBpdC5uZXh0
KCk7DQoJCQkJaWYgKG5leHRSZXNvdXJjZS5pc0xvYWRlZCgpDQoJCQkJCQkm JiAhc2VsZWN0
ZWRFbGVtZW50LmdldEVkaXRpbmdEb21haW4oKS5pc1JlYWRPbmx5KA0KCQkJ CQkJCQluZXh0
UmVzb3VyY2UpKSB7DQoJCQkJCW5leHRSZXNvdXJjZS5zYXZlKEVkaXRvckRp YWdyYW1FZGl0
b3JVdGlsLmdldFNhdmVPcHRpb25zKCkpOw0KCQkJCX0NCgkJCX0NCgkJfSBj YXRjaCAoSU9F
eGNlcHRpb24gZXgpIHsNCgkJCXRocm93IG5ldyBFeGVjdXRpb25FeGNlcHRp b24oIkNhbid0
IGNyZWF0ZSBkaWFncmFtIG9mICciDQoJCQkJCSsgZ2V0RGlhZ3JhbUtpbmQo KSArICInIGtp
bmQiLCBleCk7DQoJCX0NCgkJcmV0dXJuIGQ7DQoJfQ0KDQoJLyoqDQoJICog QGdlbmVyYXRl
ZA0KCSAqLw0KCXByb3RlY3RlZCBFT2JqZWN0IGdldERpYWdyYW1Eb21haW5F bGVtZW50KCkg
ew0KCQkvLyB1c2Ugc2FtZSBlbGVtZW50IGFzIGFzc29jaWF0ZWQgd2l0aCBF UA0KCQlyZXR1
cm4gKChWaWV3KSBkaWFncmFtRmFjZXQuZUNvbnRhaW5lcigpKS5nZXRFbGVt ZW50KCk7DQoJ
fQ0KDQoJLyoqDQoJICogQGdlbmVyYXRlZA0KCSAqLw0KCXByb3RlY3RlZCBQ cmVmZXJlbmNl
c0hpbnQgZ2V0UHJlZmVyZW5jZXNIaW50KCkgew0KCQkvLyBYWFggcHJlZmhp bnQgZnJvbSB0
YXJnZXQgZGlhZ3JhbSdzIGVkaXRvcj8NCgkJcmV0dXJuIENsYXNzRGlhZ3Jh bUVkaXRvclBs
dWdpbi5ESUFHUkFNX1BSRUZFUkVOQ0VTX0hJTlQ7DQoJfQ0KDQoJcHJvdGVj dGVkIFN0cmlu
ZyBnZXRFZGl0b3JJRCgpIHsNCgkJcmV0dXJuICJvcmcudWVtbC51ZW1sYmFz ZS5lZGl0b3Iu
ZGlhZ3JhbS5wYXJ0LkNsYXNzRGlhZ3JhbUVkaXRvcklEIjsNCgl9DQoNCgkv KioNCgkgKiBA
Z2VuZXJhdGVkDQoJICovDQoJcHJvdGVjdGVkIFN0cmluZyBnZXREaWFncmFt S2luZCgpIHsN
CgkJcmV0dXJuICJDbGFzcyI7DQoJfQ0KDQoJcHVibGljIHZvaWQgc2VsZWN0 aW9uQ2hhbmdl
ZChJQWN0aW9uIGFjdGlvbiwgSVNlbGVjdGlvbiBzZWxlY3Rpb24pIHsNCgkJ c2VsZWN0ZWRF
bGVtZW50ID0gbnVsbDsNCgkJaWYgKHNlbGVjdGlvbiBpbnN0YW5jZW9mIElT dHJ1Y3R1cmVk
U2VsZWN0aW9uKSB7DQoJCQlJU3RydWN0dXJlZFNlbGVjdGlvbiBzdHJ1Y3R1 cmVkU2VsZWN0
aW9uID0gKElTdHJ1Y3R1cmVkU2VsZWN0aW9uKSBzZWxlY3Rpb247DQoJCQlp ZiAoc3RydWN0
dXJlZFNlbGVjdGlvbi5nZXRGaXJzdEVsZW1lbnQoKSBpbnN0YW5jZW9mIENs YXNzRGlhZ3Jh
bUVsZW1lbnRFZGl0UGFydCkgew0KCQkJCXNlbGVjdGVkRWxlbWVudCA9IChD bGFzc0RpYWdy
YW1FbGVtZW50RWRpdFBhcnQpIHN0cnVjdHVyZWRTZWxlY3Rpb24NCgkJCQkJ CS5nZXRGaXJz
dEVsZW1lbnQoKTsNCgkJCX0NCgkJfQ0KCX0NCg0KCXB1YmxpYyB2b2lkIHNl dEFjdGl2ZVBh
cnQoSUFjdGlvbiBhY3Rpb24sIElXb3JrYmVuY2hQYXJ0IHRhcmdldFBhcnQp IHsNCgkJc2hl
bGwgPSB0YXJnZXRQYXJ0LmdldFNpdGUoKS5nZXRTaGVsbCgpOw0KCX0NCn0N Cg==
--------------030605000408000005030906--
Re: Create a .xxx_diagram by Action [message #170472 is a reply to message #170458] Tue, 29 January 2008 09:20 Go to previous messageGo to next message
I seem to have avoided the problem by moving the diagramFacet into the
init method, and changing methodcalls to reflect it (not longer being a
field variabel)
This now kinda works. It opens an editor of the same type as it's self.
So the final obstacle is to get it to open another type of editor. I
changed getEditorID - that worked - But the new editor uses the same
diagram element as the first editor (wrong kind).
I guess this has to do with diagramFacet being set with the selected
element:
diagramFacet = (HintedDiagramLinkStyle) ((View)
selectedElement.getModel()...
How can I make a new diagram element of the right kind?
> Attaching the code.
Re: Create a .xxx_diagram by Action [message #170587 is a reply to message #170472] Tue, 29 January 2008 14:52 Go to previous messageGo to next message
Hello Tomas,
AFAIU you have to choose correct diagram element while creating new diagram
- see OpenDiagramEditPolicy.intializeNewDiagram(). getDiagramDomainElement(),
getDiagramKind(), getPreferencesHint() methods are used there. You have to
modify these methods in accordance to return correct results for different
diagram type.
The rest should be working as is (taking into account getEditorID is already
changed). If you need to associate different diagrams with the same diagram
node then you have to attach several HintedDiagramLinkStyle instances to
each node and initialize/process them differently.
Alex Shatalin
Re: Create a .xxx_diagram by Action [message #171521 is a reply to message #170587] Tue, 05 February 2008 11:11 Go to previous messageGo to next message
--------------000403030006060607090402
> Hello Tomas,
> diagram - see OpenDiagramEditPolicy.intializeNewDiagram().
> getDiagramDomainElement(), getDiagramKind(), getPreferencesHint()
> methods are used there. You have to modify these methods in accordance
> to return correct results for different diagram type.
Hi again!
I've tried twisting and hacking on this for quite some time now, but I
can't seem to nail it. Basic steps are: 1. Copy methods from a
OpenDiagram policy. 2. Get diagramfacet 3. Adjust Methods to point at
right kind of diagram.
I'm attaching the body of my action (without selectionChanged etc.). In
it's current state it won't start.
If you or anyone else have time to point out errors, I'd be very
grateful for it!
name="action.txt"
filename="action.txt"
cHVibGljIHZvaWQgcnVuKElBY3Rpb24gYWN0aW9uKSB7DQoJdHJ5IHsNCgkJ RGlhZ3JhbSBk
aWFncmFtID0gZ2V0RGlhZ3JhbVRvT3BlbigpOw0KCQlpZiAoZGlhZ3JhbSA9 PSBudWxsKSB7
DQoJCQlkaWFncmFtID0gaW50aWFsaXplTmV3RGlhZ3JhbSgpOw0KCQl9DQoJ CVVSSSB1cmkg
PSBFY29yZVV0aWwuZ2V0VVJJKGRpYWdyYW0pOw0KCQlTdHJpbmcgZWRpdG9y TmFtZSA9IHVy
aS5sYXN0U2VnbWVudCgpDQoJCQkJKyAiIyIgKyBkaWFncmFtLmVSZXNvdXJj ZSgpLmdldENv
bnRlbnRzKCkuaW5kZXhPZihkaWFncmFtKTsgLy8kTk9OLU5MUy0xJA0KCQlJ RWRpdG9ySW5w
dXQgZWRpdG9ySW5wdXQgPSBuZXcgVVJJRWRpdG9ySW5wdXQodXJpLCBlZGl0 b3JOYW1lKTsN
CgkJSVdvcmtiZW5jaFBhZ2UgcGFnZSA9IFBsYXRmb3JtVUkuZ2V0V29ya2Jl bmNoKCkNCgkJ
CQkuZ2V0QWN0aXZlV29ya2JlbmNoV2luZG93KCkuZ2V0QWN0aXZlUGFnZSgp Ow0KCQlwYWdl
Lm9wZW5FZGl0b3IoZWRpdG9ySW5wdXQsIGdldEVkaXRvcklEKCkpOw0KCX0g Y2F0Y2ggKEV4
Y2VwdGlvbiBleCkgew0KCQl9DQp9DQoNCnByaXZhdGUgZmluYWwgSGludGVk RGlhZ3JhbUxp
bmtTdHlsZSBkaWFncmFtRmFjZXQgPSAoSGludGVkRGlhZ3JhbUxpbmtTdHls ZSkgKChWaWV3
KSBzZWxlY3RlZEVsZW1lbnQNCgkJLmdldE1vZGVsKCkpLmdldFN0eWxlKE5v dGF0aW9uUGFj
a2FnZS5lSU5TVEFOQ0UNCgkJLmdldEhpbnRlZERpYWdyYW1MaW5rU3R5bGUo KSk7DQoNCnBy
b3RlY3RlZCBEaWFncmFtIGludGlhbGl6ZU5ld0RpYWdyYW0oKSB0aHJvd3Mg RXhlY3V0aW9u
RXhjZXB0aW9uIHsNCglEaWFncmFtIGQgPSBWaWV3U2VydmljZS5jcmVhdGVE aWFncmFtKGdl
dERpYWdyYW1Eb21haW5FbGVtZW50KCksDQoJCQlnZXREaWFncmFtS2luZCgp LCBnZXRQcmVm
ZXJlbmNlc0hpbnQoKSk7DQoJaWYgKGQgPT0gbnVsbCkgew0KCQl0aHJvdyBu ZXcgRXhlY3V0
aW9uRXhjZXB0aW9uKCJDYW4ndCBjcmVhdGUgZGlhZ3JhbSBvZiAnIg0KCQkJ CSsgZ2V0RGlh
Z3JhbUtpbmQoKSArICInIGtpbmQiKTsNCgl9DQoJZGlhZ3JhbUZhY2V0LnNl dERpYWdyYW1M
aW5rKGQpOw0KCWFzc2VydCBkaWFncmFtRmFjZXQuZVJlc291cmNlKCkgIT0g bnVsbDsNCglk
aWFncmFtRmFjZXQuZVJlc291cmNlKCkuZ2V0Q29udGVudHMoKS5hZGQoZCk7 DQoJdHJ5IHsN
CgkJZm9yIChJdGVyYXRvciBpdCA9IGRpYWdyYW1GYWNldC5lUmVzb3VyY2Uo KS5nZXRSZXNv
dXJjZVNldCgpDQoJCQkJLmdldFJlc291cmNlcygpLml0ZXJhdG9yKCk7IGl0 Lmhhc05leHQo
KTspIHsNCgkJCVJlc291cmNlIG5leHRSZXNvdXJjZSA9IChSZXNvdXJjZSkg aXQubmV4dCgp
Ow0KCQkJaWYgKG5leHRSZXNvdXJjZS5pc0xvYWRlZCgpDQoJCQkJCSYmICFz ZWxlY3RlZEVs
ZW1lbnQuZ2V0RWRpdGluZ0RvbWFpbigpLmlzUmVhZE9ubHkoDQoJCQkJCQkJ bmV4dFJlc291
cmNlKSkgew0KCQkJCW5leHRSZXNvdXJjZS5zYXZlKEVkaXRvckRpYWdyYW1F ZGl0b3JVdGls
LmdldFNhdmVPcHRpb25zKCkpOw0KCQkJfQ0KCQl9DQoJfSBjYXRjaCAoSU9F eGNlcHRpb24g
ZXgpIHsNCgkJdGhyb3cgbmV3IEV4ZWN1dGlvbkV4Y2VwdGlvbigiQ2FuJ3Qg Y3JlYXRlIGRp
YWdyYW0gb2YgJyINCgkJCQkrIGdldERpYWdyYW1LaW5kKCkgKyAiJyBraW5k IiwgZXgpOw0K
CX0NCglyZXR1cm4gZDsNCn0NCgkNCnByb3RlY3RlZCBFT2JqZWN0IGdldERp YWdyYW1Eb21h
aW5FbGVtZW50KCkgew0KCXJldHVybiAoKFZpZXcpIGRpYWdyYW1GYWNldC5l Q29udGFpbmVy
KCkpLmdldEVsZW1lbnQoKTsNCn0NCgkNCnByb3RlY3RlZCBQcmVmZXJlbmNl c0hpbnQgZ2V0
UHJlZmVyZW5jZXNIaW50KCkgew0KCXJldHVybiBDbGFzc0RpYWdyYW1FZGl0 b3JQbHVnaW4u
RElBR1JBTV9QUkVGRVJFTkNFU19ISU5UOw0KfQ0KCQ0KcHJvdGVjdGVkIERp YWdyYW0gZ2V0
RGlhZ3JhbVRvT3BlbigpIHsNCglyZXR1cm4gZGlhZ3JhbUZhY2V0LmdldERp YWdyYW1MaW5r
KCk7DQp9DQoJDQpwcm90ZWN0ZWQgU3RyaW5nIGdldERpYWdyYW1LaW5kKCkg ew0KCXJldHVy
biAiQ2xhc3MiOw0KfQ0KCQ0KcHJvdGVjdGVkIFN0cmluZyBnZXRFZGl0b3JJ RCgpIHsNCgly
ZXR1cm4gIm9yZy51ZW1sLnVlbWxiYXNlLmVkaXRvci5kaWFncmFtLnBhcnQu Q2xhc3NEaWFn
cmFtRWRpdG9ySUQiOw0KfQ==
--------------000403030006060607090402--
Re: Create a .xxx_diagram by Action [message #171577 is a reply to message #171521] Tue, 05 February 2008 12:59 Go to previous message
Hello Tomas,
I suggest you debugging intializeNewDiagram() method to see which element
will be used as a "diagramDomainElement" in createDiagram() method call.
Alex Shatalin
Previous Topic:Re: Problems with use of EMF contextmenu in GMF Editor
Next Topic:Multiple palette entries to draw same node with different values?
Current Time: Mon Oct 20 09:40:28 EDT 2025
Powered by FUDForum. Page generated in 0.07783 seconds
