Home » Archived » Test and Performance Tools Platform (TPTP) » In need of suggestions debugging the TPTP
In need of suggestions debugging the TPTP [message #79232] |
Sun, 30 July 2006 23:40  |
I'm attempting to use TPTP 4.2 in conjunction with Eclipse 3.2 and I'm
having a world of trouble trying to get even basic TPTP functionality
operational. For now, I'll assume it's user error. My question is how
can I further debug each of the following issues:
1. Unable to start the Agent Controller as a service on Windows XP Pro.
I actually installed the agent on two boxes, on one it was fine, on the
other I cannot start the service. The port is not in use and the path is
correct. I can manually start the agent using the ACServer executable.
It's not worth anything, but here is the corresponding Event Viewer entry:
The Eclipse TPTP Agent service terminated with service-specific error 0
(0x0).
2. The JUnit runner hangs at 93% when executing a deployed
artifact/location pair. I can cancel the test in process and the
execution report is generated. Judging from the execution report
contents, all my unit tests are done. How can I better track down what
the hang up is?
3. The JUnit runner executes the wrong test for some of my testsuites.
In trying to debug #2, I recreated a simple testsuite that only
incorporates one test from the actual test class. The name of the test
that's supposed to be run is 'testCreateProcess' but the execution report
indicates that a similarly named test,
'testCreateProcessOfType_InvalidType', is run.
4. The data in the test execution report is grossly incorrect. Each test
that fails seems to generate multiple 'fail' entries when viewing the
report. The first failure message is correct and includes the text from
the assert. The other two fail entries have no text. My test class was
pretty basic, one unit test that was assertTrue(true) and a second test
whose method body was assertTrue("oops", false). Is stepping through the
code the only way to find out what in the TPTP framework is causing the
bogus entries in the execution report?
5. Related to #4, counts of assertions that don't fail also seem wrong --
I want counts of tests that pass (or more accurately, don't fail), not a
count of my assertions that didn't fail. Is this just how the framework
operates or is it an artifact of bogus test results data?
6. I thought I read in the Deployment Ground Rules section of the Eclipse
SDK doc that test-related items like .deploy, .testsuite, etc. don't get
copied to the remote host. Mine are. I have not added the directory
containing my test resources to the artifact or location CLASSPATH
value(s). Is this a bug or expected behavior?
7. The agent doesn't seem to update files correctly when re-launching
tests. In particular, changes to the testsuite or other test resources
don't seem to make it across the wire. Deleting the file on the remote
host seems to do the trick but that's a suboptimal solution. Is there a
flag to force the agent to perform a full refresh when it's creating the
runtime environment?
That's probably enough for starters.
Thanks in advance,
Jonathan
Re: In need of suggestions debugging the TPTP [message #79262 is a reply to message #79232] |
Mon, 31 July 2006 02:00   |
Even I'm facing certain problems. Some of the solutions are embedded below.
> is correct. I can manually start the agent using the ACServer executable.
No such probs on linux. You may try locating any temporary files it
might be creating. Delete those and then start agent controller and eclipse.
> (0x0).
> the hang up is?
I solved the problem in linux by stopping the agent controller, the
workbench also. Delete the file /tmp/IBMRAC/ramaster(for windows u'll
need to check how it is done). TPTP's error reporting still needs some
work, I guess.
> report indicates that a similarly named test,
Just comment out the other tests from the Java test case source file.
And then rerun the test. Reply with your observation
> test that fails seems to generate multiple 'fail' entries when viewing
> the report. The first failure message is correct and includes the text
> from the assert. The other two fail entries have no text. My test class
> was pretty basic, one unit test that was assertTrue(true) and a second
> test whose method body was assertTrue("oops", false). Is stepping
> through the code the only way to find out what in the TPTP framework is
> causing the bogus entries in the execution report?
> -- I want counts of tests that pass (or more accurately, don't fail),
> not a count of my assertions that didn't fail. Is this just how the
> framework operates or is it an artifact of bogus test results data?
> Eclipse SDK doc that test-related items like .deploy, .testsuite, etc.
> don't get copied to the remote host. Mine are. I have not added the
> directory containing my test resources to the artifact or location
> CLASSPATH value(s). Is this a bug or expected behavior?
> Thanks in advance,
> Jonathan
Re: In need of suggestions debugging the TPTP [message #79643 is a reply to message #79232] |
Wed, 02 August 2006 18:26   |
> (0x0).
> the hang up is?
If you are working with processes and threads, make sure all of them are
killed at the end of the test. I'm experiencing TPTP testing for month
now, and this kind of problem is almost always linked to "survivor"
processes/threads.
Files to be deployed
The files to be deployed at execution time are:
1. Everything on the class path of the test project except the
following file types: .java, .execution, .testsuite, .deploy, .location,
artifact.
2. Any test assets associated with the Artifact being used for test
execution
3. Property CLASSPATH of the General Properties of the Artifact that
is used for test execution.
I think you missed the 2. deployment rule.
> Thanks in advance,
> Jonathan
Re: In need of suggestions debugging the TPTP [message #79840 is a reply to message #79825] |
Thu, 03 August 2006 12:37  |
>>> what the hang up is?
>> are killed at the end of the test. I'm experiencing TPTP testing for
>> month now, and this kind of problem is almost always linked to
>> "survivor" processes/threads.
> I looked into this some more and it appears to have something to do with
> the Spring framework/implementation we're using. If my tests don't
> initialize Spring then no problem. This is just a preliminary
> observation and there could certainly be something else in our framework
> that gets initialized alongside the ApplicationContext that's the real
> cause. For instance, I know we spawn a couple of worker threads as part
> of our framework. I'll create a couple of temporary hooks to allow
> forcefully shutting those down and then retry the test.
Just in case anyone is following this part of the thread, you might want
to add yourselves to bug #136419 <
https://bugs.eclipse.org/bugs/show_bug.cgi?id=136419 >. I'm going to add
the hints/workarounds mentioned here to that bugzilla.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Current Time: Tue Oct 21 01:14:40 EDT 2025
Powered by FUDForum. Page generated in 0.03778 seconds
