Unable to checkout CVS as anonymous user [message #79160] |
Wed, 05 October 2005 09:45 |
Originally posted by: daviskv.crimsonlogic.com
Hi All,
I am trying to checkout the source from the BIRT CVS repository, but I get
error saying "unable to connect as anonymous user, the password is
required". If any one encountered the same or any one knows if its
possible to access the CVS as anonymous login, please help.
Thanks In advance.
Davis
Re: Unable to checkout CVS as anonymous user [message #79289 is a reply to message #79160] |
Wed, 05 October 2005 15:11 |
Davis,
I just tried with anonymous and it works for me.
It didnt require a password. Which version are you trying to download?
Jason Weathersby
BIRT PMC
"Davis" <daviskv@crimsonlogic.com> wrote in message
news:3f6ba40246c3982418d582c38f420cd5$1@www.eclipse.org...
> Hi All,
> Thanks In advance.
> Davis
Re: Unable to checkout CVS as anonymous user [message #79531 is a reply to message #79458] |
Thu, 06 October 2005 14:08 |
Davis,
Which version are you trying to checkout?
Look at
http://www.eclipse.org/birt/index.php?page=build/build_instr .html
Remeber to set the configuration in
"Configuring Your Eclipse Workbench".
Judging from the error message it doesnt appear that you are getting that
far.
Can you browse the CVS repository?
Jason Weathersby
BIRT PMC
"Davis" <davis_k_v@yahoo.com> wrote in message
news:de1cbf1f320ce4f72c1757c37a96c149$1@www.eclipse.org...
> Hi Jason,
> I managed to checkout, actually the page
> ( http://www.eclipse.org/birt/frameizer.php?page=http://dev.ec lipse.org/viewcvs/index.cgi
> } was missleading. I gave /cvsroot/birt instead of /home/birt. This I
> found in another page.
> However I am getting the following error in the midst of checkout out the
> whole build version 2.0. I haven't build yet to see if any dependent files
> are missing.
> cvs checkout: Updating
> source/org.eclipse.birt.tests.regression.data/test/plugins/o rg.eclipse.birt.report.data.oda.jdbc_1.0.0
> source/org.eclipse.birt.tests.regression.data/test/plugins/o rg.eclipse.birt.report.data.oda.jdbc_1.0.0/drivers
> ok (took 7:40.561)
> Error: The following warnings were reported while performing the "cvs
> checkout" command.
> Warning: : cvs checkout: warning: cannot open
> /home/birt/CVSROOT/val-tags read/write: Permission denied
> Error: : cvs checkout: could not read RCS file for
> org.eclipse.birt.converters/.classpath
> org.eclipse.birt.converters/.cvsignore
> org.eclipse.birt.converters/.project
> Davis
FUDForum. Page generated in 0.04701 seconds
