Re: setText(String text) in MenuManager [message #79046 is a reply to message #78729] |
Mon, 24 March 2008 18:35 |
Originally posted by: fappel.innoopract.com
hm I'm not sure, but you can get the Menu widget by
MenuManager#getMenu(). This in turn returns the List of children of type
MenuItem - this inherits Item#setText(). Maybe that helps.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Emmanuel [mailto:emmanuel.marchal@n-side.be]
Bereitgestellt: Mittwoch, 19. März 2008 11:03
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: setText(String text) in MenuManager
Betreff: setText(String text) in MenuManager
Hi all,
I try to implement a multilanguage application. Everything works fine
except the menu.
There is no setText method in MenuManager to change dynamically the text
of my menu items... I though that I can override getText() method but I
did not found any method to update the menu text. It seems that the
update method of IContributionItem does not update the text...
Any suggestion ?
Emmanuel
FUDForum. Page generated in 0.03945 seconds
