NPE trying to add file association [message #78556] |
Thu, 16 June 2005 19:01 |
Originally posted by: adam.no.spam.cyberspaceroad.spam
I was just setting up xmlBuddy (the plugin) to be the default editor for
the .project and .classpath files, and when closing the preferences
dialog, eclipse threw an NPE into the log (below):.
I then tried doing it step by step and closing the dialog each step, and
it worked.
Here's the NPE stacktrace if anyone's interested:
org.eclipse.ui.internal.registry.EditorRegistry.addExternalE ditorsToEditorMap(EditorRegistry.java:275)
org.eclipse.ui.internal.registry.EditorRegistry.rebuildEdito rMap(EditorRegistry.java:863)
org.eclipse.ui.internal.registry.EditorRegistry.setFileEdito rMappings(EditorRegistry.java:996)
org.eclipse.ui.internal.dialogs.FileEditorsPreferencePage.pe rformOk(FileEditorsPreferencePage.java:508)
org.eclipse.jface.preference.PreferenceDialog$11.run(Prefere nceDialog.java:863)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1038)
at org.eclipse.core.runtime.Platform.run(Platform.java:775)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.preference.PreferenceDialog.okPressed(Pref erenceDialog.java:843)
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.okP ressed(FilteredPreferenceDialog.java:296)
org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.ok Pressed(WorkbenchPreferenceDialog.java:153)
org.eclipse.jface.preference.PreferenceDialog.buttonPressed( PreferenceDialog.java:227)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1016)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2825)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2530)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:66)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1694)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1658)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:366)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:375)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:162)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
FUDForum. Page generated in 0.07238 seconds
