Home » Eclipse Projects » GEF » Bug in Palette
Bug in Palette [message #78535] Thu, 08 May 2003 07:39 Go to next message
Originally posted by: andreas.rummler.tu-ilmenau.de
I think, I've discovered a bug in the palette: When opening a drawer
which contains several entries but there's not enough room to display
them all, the last visible entry becomes greyed out and a small triangle
appears at the bottom of the drawer. Now it's possible to click on the
triangle but not on other drawers anymore.
An example can be found here: http://www.evolvica.org/images/gefbug.png
In this state is is possible to "scroll" down the recombination entry
list but it's impossible to open for instance the evaluation drawer.
Andreas Rummler
+ Andreas Rummler +
+ Technical University of Ilmenau, Germany (__) +
+ Department Of Electronic Circuits & Systems (oo) +
+ MAIL: mailto:arummler@acm.org || | \ +
+ MAIL: mailto:andreas.rummler@tu-ilmenau.de ||----|| * +
+ WEB : http://www.inf-technik.tu-ilmenau.de/~rummler ~~ ~~ +
+ PGP : http://www.inf-technik.tu-ilmenau.de/~rummler/public.pgp +
"Programming today is a race between software engineers striving to
build bigger and better idiot-proof programs and the universe trying
to produce bigger and better idiots. So far, the universe is winning."
Richard Cook
Re: Bug in Palette [message #78622 is a reply to message #78535] Thu, 08 May 2003 10:40 Go to previous messageGo to next message
Why are some of your drawers indented with a margin? Do you have drawers
inside a PaletteGroup? This is not supported.
Please indicate which release of GEF you are using.
"Andreas Rummler" <andreas.rummler@tu-ilmenau.de> wrote in message
news:b9dfgs$nju$1@rogue.oti.com...
> Hello,
> Andreas Rummler
> + Andreas Rummler +
> Richard Cook
Re: Bug in Palette [message #78680 is a reply to message #78622] Thu, 08 May 2003 11:07 Go to previous messageGo to next message
Yes, there are drawers inside another drawer. Didn't know that something
like that is not supported because it seemed to work ...
Release 2.1.0 (2003-03-27)
+ Andreas Rummler +
Richard Cook
Re: Bug in Palette [message #78740 is a reply to message #78680] Thu, 08 May 2003 12:09 Go to previous message
news:b9drob$3an$1@rogue.oti.com...
drawers
It probably does work, but I don't think the margin looks good. If you
allow the user to switch to column layout, the columns will not be aligned.
If you want to debug this, put a breakpoint in
DomainEventDispatcher.dispatchMousePressed(), and find out where the pressed
event is ending up. Sorry, nothing comes to mind that would cause this, but
if the fix is simple, it might be able to go into 2.1.1.
Why don't you open a feature request for sub-drawers. Even if
drawers-in-drawers worked and had no margin, there is no visual distinction
between the two. It is not obvious to the user that closing the parent
drawer also hides the drawers inside it, since this is not default behavior.
> + Andreas Rummler +
> Richard Cook
Previous Topic:Problems with displaying connections
Next Topic:Accesssibility
Current Time: Mon Sep 15 19:53:53 EDT 2025
Powered by FUDForum. Page generated in 0.93812 seconds
