Terminal Server support? [message #7002] |
Thu, 13 April 2006 11:25 |
Originally posted by: michel.loehr.saxsys.de
As it looks now, EPF doesn't really support to be used in a terminal
server environment, or does it?
If not, is it on the feature list?
Michel
Re: Terminal Server support? [message #7098 is a reply to message #7053] |
Thu, 13 April 2006 17:25 |
For Terminal Server, each user must be able to start the same installed
instance of EPF. Currently, if you start EPF for a second time, you get an
error message.
Michel
Re: Terminal Server support? [message #562451 is a reply to message #7053] |
error message.
Michel
FUDForum. Page generated in 0.25593 seconds
