Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » fetching non-containment relations eagerly
fetching non-containment relations eagerly [message #77978] |
Tue, 03 April 2007 14:53 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: christian.donhofer.net
hi martin, switching back to the newsgroup as discussed. =)
i'm now trying the following in my .ecore:
<eAnnotations source="teneo.jpa">
<details key="@OneToMany(indexed" value="false)"/>
</eAnnotations>
which works, but this doesn't:
<details key="@OneToMany(fetch" value="EAGER)"/>
</eAnnotations>
this produces the following in my subclass of EPackageImpl:
// @OneToMany
create@OneToManyAnnotations();
which obviously causes a Method undefined error.
why' that?
im using teneo 0.8.0.
cheers, chris
Martin Taal wrote:
> Hi Christian,
> You are using a deprecated notation. Instead of this:
> <eAnnotations source="http://annotation.elver.org/Indexed">
> <details key="value" value="false"/>
> </eAnnotations>
> you should do this:
> <xsd:annotation>
> <xsd:appinfo
> source="teneo.jpa">@OneToMany(indexed=false)</xsd:appinfo >
> </xsd:annotation>
> As you can see the source is teneo.jpa , key to appinfo and the contents
> of the annotation follow the java annotation style.
> To set eager loading you would have something like this:
> <xsd:annotation>
> <xsd:appinfo
> source="teneo.jpa">@OneToMany(fetch=EAGER)</xsd:appinfo>
> </xsd:annotation>
> Yes, eclipse.tools.emf is the correct newsgroup.
> Btw, would you mind continuing our discussion on the newsgroup? It can
> also help others.
> gr. Martin
> Christian Donhofer(@fhcampus) wrote:
>> Martin Taal wrote:
Re: fetching non-containment relations eagerly [message #77994 is a reply to message #77978] |
Tue, 03 April 2007 15:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Martin Taal![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mtaal%40springsite.com) Messages: 5468 Registered: July 2009 |
Hi Christian,
The eannotation in ecore should something like this:
<details key="appinfo" value="@ManyToOne(fetch=LAZY)"/>
</eAnnotations>
So the key is appinfo ('value' will also work) and the value contains the annotation(s).
gr. Martin
> </eAnnotations>
> </eAnnotations>
> // @OneToMany
> why' that?
> cheers, chris
> Martin Taal wrote:
>> Hi Christian,
>> </eAnnotations>
>> you should do this:
>> <xsd:annotation>
>> <xsd:appinfo
>> </xsd:annotation>
>> <xsd:annotation>
>> <xsd:appinfo
>> </xsd:annotation>
>> also help others.
>> gr. Martin
>>> Martin Taal wrote:
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: fetching non-containment relations eagerly [message #78010 is a reply to message #77994] |
Tue, 03 April 2007 16:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hi martin,
thanks for the tip, it's looking good(the language object works already),
but its not finished yet. i'll post a report in some hours.
cheers, chris
On Tue, 03 Apr 2007 17:00:47 +0200 wrote Martin Taal:
> Hi Christian,
> </eAnnotations>
> gr. Martin
>> </eAnnotations>
>> </eAnnotations>
>> // @OneToMany
>> why' that?
>> cheers, chris
Re: fetching non-containment relations eagerly [message #78025 is a reply to message #78010] |
Tue, 03 April 2007 16:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hi again,
the DanglingHref exceptions are gone,
but the serialization looks like this:
<lobj:learningUnit> hibernate://?dsname=AuthortoolDataStore&loadStrategy=add ToContents&sessionController=testsc&query1=from ModuleFolder where id='modfo-27C47B58-71F7-6F08-DDCE-E40D4EBA305C'#learn-1C3917 34-EF05-CABA-2E9E-7933863BCE4B </lobj:learningUnit>
might this be caused by the error in EReferencePropertyHandler you told me
about or will i have to fiddle around with some other settings/annotations?
cheers, chris
On Tue, 03 Apr 2007 18:16:42 +0200 wrote Christian Donhofer:
> hi martin,
> cheers, chris
>> Hi Christian,
>> </eAnnotations>
>> gr. Martin
>>> </eAnnotations>
>>> </eAnnotations>
>>> // @OneToMany
>>> why' that?
>>> cheers, chris
Re: fetching non-containment relations eagerly [message #78041 is a reply to message #78025] |
Tue, 03 April 2007 16:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Is the learningunit read using the same hibernate resource as its referencer?
gr. Martin
> hi again,
> cheers, chris
>> hi martin,
>> cheers, chris
>>> Hi Christian,
>>> </eAnnotations>
>>> gr. Martin
>>>> </eAnnotations>
>>>> </eAnnotations>
>>>> // @OneToMany
>>>> why' that?
>>>> cheers, chris
The Netherlands
Re: fetching non-containment relations eagerly [message #78057 is a reply to message #78041] |
Tue, 03 April 2007 17:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On Tue, 03 Apr 2007 18:56:47 +0200 wrote Martin Taal:
all objects are being loaded with a single query.
when using
ModuleFolder modfo =
(ModuleFolder)EcoreUtil.copy((EObject)res1.getContents().get (0));
rs.getContents().add(modfo);
i get the result from my last post,
using
rs.getContents().addAll(res1.getContents());
the xmi looks like this
<lobj:LuNode id="lunod-0900BE6A-D0B1-B88C-0B8C-83C07C34261A">
<lobj:learningUnit> dummy.lobj?sessionController=testsc#learn-DCDF4C0A-088A-F507 -E839-DC264DF1A66B </lobj:learningUnit>
</lobj:LuNode>
<lobj:LearningUnit id="learn-DCDF4C0A-088A-F507-E839-DC264DF1A66B"
timestamp="2007-03-21T12:22:54.000+0100">
<lobj:luMeta id="leame-17C76A7C-7F99-7B2A-BD8E-4019F57B57B7"
<lobj:didacMeta id="didme-802CC3B9-0C51-2E3D-CBD8-A86D484D94CD">
<lobj:language>soEinDummy.lobj?sessionController=testsc#de</lobj:language >
<title>- kein Titel -</title>
</lobj:didacMeta>
<creationDate>2007-03-21T12:22:54.000+0100</creationDate>
</lobj:luMeta>
</lobj:LearningUnit>
so everything is there, but not in a structured form.
but because of that, i assume everything is in the same resource.
i believe that
does copy everything needed, but somehow destroys the relations.
what do you think?
cheers, chris
> gr. Martin
>> hi again,
>> the DanglingHref exceptions are gone, but the serialization looks like
>> this:
>> ModuleFolder where
>> me about or will i have to fiddle around with some other
>> cheers, chris
>>> hi martin,
>>> already),
>>> cheers, chris
>>>> Hi Christian,
>>>> </eAnnotations>
>>>> the annotation(s).
>>>> gr. Martin
>>>>> </eAnnotations>
>>>>> </eAnnotations>
>>>>> // @OneToMany
>>>>> why' that?
>>>>> cheers, chris
Re: fetching non-containment relations eagerly [message #78073 is a reply to message #78057] |
Tue, 03 April 2007 17:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
sorry, that was a bit messy.
the second variant is off course
without
cheers, chris
On Tue, 03 Apr 2007 19:05:49 +0200 wrote Christian Donhofer:
Re: fetching non-containment relations eagerly [message #78088 is a reply to message #78057] |
Tue, 03 April 2007 17:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Is the ereference pointing to the learningunit a containment reference?
Can you try EcoreUtil.copyAll(res1.getContents())? This should also copy the learningunit (if it is
in the root of the resource) and also set the ereferences to this copied eobject.
gr. Martin
> when using
> using
> </lobj:LuNode>
> </lobj:didacMeta>
> </lobj:luMeta>
> i believe that
> what do you think?
> cheers, chris
>> gr. Martin
>>> hi again,
>>> this:
>>> ModuleFolder where
>>> cheers, chris
>>>> hi martin,
>>>> already),
>>>> cheers, chris
>>>>> Hi Christian,
>>>>> </eAnnotations>
>>>>> the annotation(s).
>>>>> gr. Martin
>>>>>> </eAnnotations>
>>>>>> </eAnnotations>
>>>>>> // @OneToMany
>>>>>> why' that?
>>>>>> cheers, chris
The Netherlands
Re: fetching non-containment relations eagerly [message #78117 is a reply to message #78088] |
Tue, 03 April 2007 17:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On Tue, 03 Apr 2007 19:09:05 +0200 wrote Martin Taal:
no, not a containment relation. LUs are contained within a LUFolder, and
referenced by everything else, f.i. LUNodes.
example xmi
<lobj:childnodes xsi:type="lobj:LuNode" id="lunod-927DAFBB-EBBC-864D-7C29-9CA78A9699B5">
</lobj:childnodes>
Collection myCol = EcoreUtil.copyAll(res1.getContents());
throws a ConcurrentModificationException
> gr. Martin
cheers, chris
Re: fetching non-containment relations eagerly [message #78132 is a reply to message #78117] |
Tue, 03 April 2007 17:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Okay that it is not a containment reference, explains why the serialization translates the object
into a href-like string (afaiu).
When you look in the rs resource is the learningunit there and when you debug does the LuNode point
to a learningunit it is same resource (rs)?
Does the serialized string contain the LearningUnit object in the root?
gr. martin
> example xmi
> </lobj:childnodes>
>> gr. Martin
> cheers, chris
The Netherlands
Re: fetching non-containment relations eagerly [message #78146 is a reply to message #78132] |
Tue, 03 April 2007 18:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On Tue, 03 Apr 2007 19:38:20 +0200 wrote Martin Taal:
yes, the LU is present(in both resources) - but i cant see whether its
just a pointer to another resource or really present in the resource - i
can navigate to it in the "variables" list (eclipse debug perspective).
here's the full output:
<lobj:ModuleFolder xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:lobj="lobj.ecore" id="modfo-27C47B58-71F7-6F08-DDCE-E40D4EBA305C" timestamp="2007-03-21T12:22:20.000+0100">
<lobj:folderMeta id="folme-B9B50DAC-4C93-6C2C-906C-27CC08836C32" timestamp="2007-03-21T12:22:20.000+0100">
</lobj:folderMeta>
<lobj:moduleFolder id="modfo-252FEE5B-DD17-8AAA-95EC-2F183B681088" timestamp="2007-03-21T12:22:22.000+0100">
<lobj:folderMeta id="folme-2D60FC6B-255D-6757-1AAE-443557D3C043" timestamp="2007-03-21T12:22:29.000+0100">
</lobj:folderMeta>
<lobj:module id="modul-B3682DBC-4214-5079-5AFA-D1442772E611" timestamp="2007-03-21T12:22:29.000+0100">
<lobj:moduleMeta id="modme-1746A529-4DD0-0712-B3FA-EEA5FA1D6BFD" timestamp="2007-03-21T12:22:31.000+0100">
<lobj:didacMeta id="didme-29DD1E0D-F4D9-A4C9-9FB8-CB1BB8716B39">
<lobj:language> hibernate://?dsname=AuthortoolDataStore&loadStrategy=add ToContents&sessionController=testsc&query1=from ModuleFolder where id='modfo-27C47B58-71F7-6F08-DDCE-E40D4EBA305C'#de</lobj:language >
</lobj:didacMeta>
<creationDate>2007-03-21T12:22:31.000+0100</creationDate>
</lobj:moduleMeta>
<lobj:rootNode xsi:type="lobj:ThemeNode" id="theno-E6ECA384-CBC8-05D5-45EE-EF7D4B439932">
<lobj:childnodes xsi:type="lobj:ThemeNode" id="theno-3919AAAF-2CB9-AFB2-12EB-59F114262B4D">
<lobj:theme id="theme-8F5F78E5-80A2-C5E6-549A-A74EA345B6AF" timestamp="2007-03-21T12:22:33.000+0100">
<lobj:simpleDidacMeta id="simme-A35AC636-3DB6-5817-90D4-B46843E5136E">
</lobj:simpleDidacMeta>
</lobj:theme>
</lobj:childnodes>
<lobj:childnodes xsi:type="lobj:LuNode" id="lunod-0900BE6A-D0B1-B88C-0B8C-83C07C34261A">
<lobj:learningUnit> hibernate://?dsname=AuthortoolDataStore&loadStrategy=add ToContents&sessionController=testsc&query1=from ModuleFolder where id='modfo-27C47B58-71F7-6F08-DDCE-E40D4EBA305C'#learn-DCDF4C 0A-088A-F507-E839-DC264DF1A66B </lobj:learningUnit>
</lobj:childnodes>
</lobj:childnodes>
</lobj:rootNode>
</lobj:module>
</lobj:moduleFolder>
</lobj:ModuleFolder>
> gr. martin
cheers, chris
Re: fetching non-containment relations eagerly [message #78160 is a reply to message #78146] |
Tue, 03 April 2007 18:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
The eobject has an eProperties member which has an eResource member, Does this member point to the
rs resource (for the learningunit)?
After doing this:
the content of res1 should be empty and all objects in res1 should be in rs. Is that the case?
To be sure, the lu object is present in the top/root of the rs resource?
If so then I don't understand why the serialized string does not contain the learningunit.
How do you serialize?
gr. Martin
> </lobj:folderMeta>
> </lobj:folderMeta>
> </lobj:didacMeta>
> </lobj:moduleMeta>
> </lobj:theme>
> </lobj:childnodes>
> </lobj:childnodes>
> </lobj:childnodes>
> </lobj:rootNode>
> </lobj:module>
>> gr. martin
> cheers, chris
The Netherlands
Re: fetching non-containment relations eagerly [message #78175 is a reply to message #78160] |
Tue, 03 April 2007 18:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On Tue, 03 Apr 2007 20:12:27 +0200 wrote Martin Taal:
no, it points to the hibernate resource res1!
(after calling
> After doing this:
all of the objects in res1 are in rs, but still in res1, too.
yes, the LearningUnit is at the root level of contents in rs, but that
produces ther XMI string at the bottom of this post(p.s.).
like this:
public static String resourceToString(Resource rs, String encoding) throws Exception{
EObjectHandler handler = new EObjectHandlerImpl();
StringWriter sw = new StringWriter();
URIConverter.WriteableOutputStream uws = new URIConverter.WriteableOutputStream(sw, encoding);
try{
rs.save(uws, handler.getResourceSaveOptions(""));
}catch(Exception e){
logger.error("ERROR in DatabaseServices.resourceToString...");
throw(e);
String myObject = sw.toString();
return myObject;
> gr. Martin
cheers, chris
p.s.:
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:lobj="lobj.ecore">
<lobj:ModuleFolder id="modfo-27C47B58-71F7-6F08-DDCE-E40D4EBA305C" timestamp="2007-03-21T12:22:20.000+0100">
</lobj:folderMeta>
<lobj:ModuleFolder id="modfo-252FEE5B-DD17-8AAA-95EC-2F183B681088" timestamp="2007-03-21T12:22:22.000+0100">
</lobj:folderMeta>
<lobj:Module id="modul-B3682DBC-4214-5079-5AFA-D1442772E611" timestamp="2007-03-21T12:22:29.000+0100">
</lobj:moduleMeta>
<lobj:rootNode xsi:type="lobj:ThemeNode" id="theno-E6ECA384-CBC8-05D5-45EE-EF7D4B439932"/>
</lobj:Module>
<lobj:DidacMeta id="didme-29DD1E0D-F4D9-A4C9-9FB8-CB1BB8716B39">
</lobj:DidacMeta>
<lobj:Language code="de">
<language>Deutsch</language>
</lobj:Language>
<lobj:ThemeNode id="theno-3919AAAF-2CB9-AFB2-12EB-59F114262B4D">
<lobj:theme id="theme-8F5F78E5-80A2-C5E6-549A-A74EA345B6AF" timestamp="2007-03-21T12:22:33.000+0100"/>
</lobj:ThemeNode>
<lobj:LuNode id="lunod-927DAFBB-EBBC-864D-7C29-9CA78A9699B5">
<lobj:learningUnit> soEinDummy.lobj?sessionController=testsc#learn-1C391734-EF05 -CABA-2E9E-7933863BCE4B </lobj:learningUnit>
</lobj:LuNode>
<lobj:LearningUnit id="learn-1C391734-EF05-CABA-2E9E-7933863BCE4B" timestamp="2007-03-21T12:22:44.000+0100">
<lobj:luMeta id="leame-432C865A-A042-798C-661B-EA8A9E674363" timestamp="2007-03-21T12:22:44.000+0100">
<lobj:didacMeta id="didme-9BBA1CE3-F623-F80B-3C8F-671E9A12AA5B">
</lobj:didacMeta>
<creationDate>2007-03-21T12:22:44.000+0100</creationDate>
</lobj:luMeta>
<lobj:Item id="item-206E5F96-A31F-C1B7-C89B-FE42A8119211"/>
<lobj:CorrBlock id="corbl-7233463F-D96F-6E60-40C2-9158EB0D350E"/>
<lobj:PresentationBlock id="prebl-DA9B5269-00F4-262A-84DB-96B31770E8C3">
<lod>3</lod>
<rendering>default</rendering>
<lobj:block xsi:type="lobj:HypertextBlock"> soEinDummy.lobj?sessionController=testsc#hypbl-17FBF85C-6187 -3251-F42D-DDB6889238EE </lobj:block>
</lobj:PresentationBlock>
<lobj:HypertextBlock id="hypbl-17FBF85C-6187-3251-F42D-DDB6889238EE" timestamp="2007-03-21T12:23:07.000+0100">
<lobj:blockMeta id="blome-CD0D20F6-37E9-83FC-7884-828E5B2B026E" timestamp="2007-03-21T12:23:07.000+0100">
<simpleDidacMeta id="simme-A00FD56E-ABBD-DFA4-5F37-C95E666A5300">
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
</lobj:HypertextBlock>
<lobj:HypertextContent id="hypco-94DE35B4-BBC4-B891-8EAF-ECA6F8F38EF4" timestamp="2007-03-21T12:23:07.000+0100"/>
<lobj:PresentationBlock id="prebl-DD20D74A-96E9-8361-3566-67AD8A90CB6E">
<lod>2</lod>
<lobj:block xsi:type="lobj:HypertextBlock"> soEinDummy.lobj?sessionController=testsc#hypbl-AA39CC32-26EB -701B-1FF5-F079E3A2DF84 </lobj:block>
<lobj:HypertextBlock id="hypbl-AA39CC32-26EB-701B-1FF5-F079E3A2DF84" timestamp="2007-03-21T12:23:07.000+0100">
<lobj:blockMeta id="blome-D7F583E8-F18C-EAFF-33CE-FF68AD1BDB40" timestamp="2007-03-21T12:23:07.000+0100">
<simpleDidacMeta id="simme-129D4844-F7ED-2C0D-E702-5EEC35DA84E2">
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lobj:HypertextContent id="hypco-60263238-77DC-0BC4-66E1-C2FEFA34FEAF" timestamp="2007-03-21T12:23:07.000+0100"/>
<lobj:PresentationBlock id="prebl-E3BF4D5E-BBB0-B784-950C-EE144E5DCBAA">
<lod>1</lod>
<lobj:block xsi:type="lobj:HypertextBlock"> soEinDummy.lobj?sessionController=testsc#hypbl-F4535848-42AF -555D-980F-E46E1BC1FB2F </lobj:block>
<lobj:HypertextBlock id="hypbl-F4535848-42AF-555D-980F-E46E1BC1FB2F" timestamp="2007-03-21T12:23:07.000+0100">
<lobj:blockMeta id="blome-5AA59965-FF07-D9E8-B5BE-2FD29A06C66D" timestamp="2007-03-21T12:23:07.000+0100">
<simpleDidacMeta id="simme-42D4EE0A-797E-C6C4-35EF-13812FBCC33E">
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lobj:HypertextContent id="hypco-23951B34-4B5B-8202-173B-A091C8CEDEAE" timestamp="2007-03-21T12:23:07.000+0100"/>
<lobj:TitleMeta id="titme-9BCA4D6B-E5B0-7F26-9B4B-1ECE89433600">
<title></title>
</lobj:TitleMeta>
<lobj:learningUnit> soEinDummy.lobj?sessionController=testsc#learn-DCDF4C0A-088A -F507-E839-DC264DF1A66B </lobj:learningUnit>
</lobj:LuNode>
<lobj:LearningUnit id="learn-DCDF4C0A-088A-F507-E839-DC264DF1A66B" timestamp="2007-03-21T12:22:54.000+0100">
<lobj:luMeta id="leame-17C76A7C-7F99-7B2A-BD8E-4019F57B57B7" timestamp="2007-03-21T12:22:54.000+0100">
</lobj:didacMeta>
</lobj:luMeta>
<lobj:Item id="item-2ACFD644-5C22-3394-351C-8E12A64578C2"/>
<lobj:CorrBlock id="corbl-E6928623-2050-AC94-3C17-84F897EC61E0"/>
<lobj:PresentationBlock id="prebl-054DA96C-4B80-9F03-67D4-05D278B9CFC0">
<lod>1</lod>
<lobj:block xsi:type="lobj:HypertextBlock"> soEinDummy.lobj?sessionController=testsc#hypbl-5F3C7CE3-B80E -19A7-79AD-E2DC563ABEB3 </lobj:block>
<lobj:HypertextBlock id="hypbl-5F3C7CE3-B80E-19A7-79AD-E2DC563ABEB3" timestamp="2007-03-21T12:23:01.000+0100">
<lobj:blockMeta id="blome-51687967-5314-D3BA-245E-7237AC5B09F2" timestamp="2007-03-21T12:23:01.000+0100">
<simpleDidacMeta id="simme-29FAD89D-8D7A-CDA4-C43D-C43C19D8523F">
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lobj:HypertextContent id="hypco-E3CB41CC-609A-FC11-78FF-6EFC2CE2AF60" timestamp="2007-03-21T12:23:01.000+0100"/>
<lobj:PresentationBlock id="prebl-28BB4C31-EC26-97C2-EAE0-7AA375EA68C1">
<lod>2</lod>
<lobj:block xsi:type="lobj:HypertextBlock"> soEinDummy.lobj?sessionController=testsc#hypbl-3CEED0D8-1225 -AC7C-E36E-3BBF70319CE7 </lobj:block>
<lobj:HypertextBlock id="hypbl-3CEED0D8-1225-AC7C-E36E-3BBF70319CE7" timestamp="2007-03-21T12:23:01.000+0100">
<lobj:blockMeta id="blome-F9040586-12CF-A206-6ACA-A1DFD0A6A194" timestamp="2007-03-21T12:23:01.000+0100">
<simpleDidacMeta id="simme-C54C85E6-A497-E843-831A-78FFC23863CE">
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lobj:HypertextContent id="hypco-A413E8D3-26AB-7EED-FE53-3036373AC004" timestamp="2007-03-21T12:23:01.000+0100"/>
<lobj:PresentationBlock id="prebl-A4FF4DA7-9296-DDC5-58A2-0449836FBCB5">
<lod>3</lod>
<lobj:block xsi:type="lobj:HypertextBlock"> soEinDummy.lobj?sessionController=testsc#hypbl-67E547F9-3A13 -F4B5-EB83-F0B9E81398A4 </lobj:block>
<lobj:HypertextBlock id="hypbl-67E547F9-3A13-F4B5-EB83-F0B9E81398A4" timestamp="2007-03-21T12:23:01.000+0100">
<lobj:blockMeta id="blome-4F8C0AC9-30E5-1C87-F6B7-EA5D52969B00" timestamp="2007-03-21T12:23:01.000+0100">
<simpleDidacMeta id="simme-4BFCBA16-BE6D-CD8A-1534-B4F02674CD48">
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lobj:HypertextContent id="hypco-E0921B62-747D-53E9-8661-44063AF217C9" timestamp="2007-03-21T12:23:01.000+0100"/>
<lobj:TitleMeta id="titme-307733BD-EE1A-DF65-0BC2-5DFFB168C4A7">
<title></title>
</lobj:TitleMeta>
<lobj:SimpleDidacMeta id="simme-A35AC636-3DB6-5817-90D4-B46843E5136E">
</lobj:SimpleDidacMeta>
</xmi:XMI>
Re: fetching non-containment relations eagerly [message #78191 is a reply to message #78175] |
Tue, 03 April 2007 18:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Is res1 read from the db? If so then I do not understand this part of the serialized xmi:
This seems to come from the xmi files.
Do you do this:
create res1
load res1 from the db
copyall to rs
serialize rs
gr. Martin
> (after calling
>> After doing this:
> like this:
> try{
> throw(e);
> return myObject;
>> gr. Martin
> cheers, chris
> p.s.:
> </lobj:folderMeta>
> </lobj:folderMeta>
> </lobj:moduleMeta>
> </lobj:Module>
> </lobj:DidacMeta>
> </lobj:Language>
> </lobj:ThemeNode>
> </lobj:LuNode>
> </lobj:didacMeta>
> </lobj:luMeta>
> <lod>3</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>2</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>1</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <title></title>
> </lobj:TitleMeta>
> </lobj:LuNode>
> </lobj:didacMeta>
> </lobj:luMeta>
> <lod>1</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>2</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>3</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <title></title>
> </lobj:TitleMeta>
> </xmi:XMI>
The Netherlands
Re: fetching non-containment relations eagerly [message #78206 is a reply to message #78191] |
Tue, 03 April 2007 19:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On Tue, 03 Apr 2007 20:53:31 +0200 wrote Martin Taal:
i guess thats because im serializing rs(the XMI resource). here's the
actual code:
private Object[] loadObject(String id, String encoding, String eclassname,
boolean serialize){
Object[] ret = new Object[]{"", ""};
//create datastore, session and transaction session = getSession();
Transaction tx = session.getTransaction();
SessionController sc = new SessionController(); // when creating a
SessionController you have to pass your HbDataStore instance
sc.setHbDataStore(dataStore);
// register the SessionController, the name is used in the uri of the
resource SessionController.registerSessionController("testsc", sc);
ResourceSet resourceSet = getResourceSet();
Resource rs =
resourceSet.createResource(URI.createURI("soEinDummy.lobj?"+
HibernateResource.SESSION_CONTROLLER_PARAM + "=testsc")); // create an
uri using the SessionController name URI uri1 =
URI.createURI("hibernate://?dsname=" + dataStore.getName() + "&" +
StoreResource.LOAD_STRATEGY_PARAM + "=" + StoreResource.ADD_TO_CONTENTS
+ "&" + HibernateResource.SESSION_CONTROLLER_PARAM +
"=testsc&query1=from "+eclassname+" where id='"+id+"'");
System.out.println("Loading with this QUERY: "+uri1.toString());
// resourceSet has to be set before somehow.. final Resource res1 =
resourceSet.createResource(uri1);
tx.begin();
// now load the resources
try {
res1.load(Collections.EMPTY_MAP);
} catch (IOException e1) {
// TODO Auto-generated catch block
e1.printStackTrace();
tx.commit();
//rs.getContents().add(modfo); //<--version producing HB uris
System.out.println("LOADED RESOURCESET CONTAINS
"+res1.getResourceSet().getResources().size()+" RESOURCES!");
if(serialize){
System.out.println("CD DEBUG: SERIALIZING OBJECTS!"); //translate
resource into string
String myObject = "";
try{
myObject = resourceToString(rs, encoding);
System.out.println("EXCEPTION WHEN SERIALIZING:"); e.printStackTrace();
//return error/status code and exit
//500 - Internal Server Error
ret[0] = "500";
return ret;
// return xml-String
ret[1] = myObject;
}else{
System.out.println("CD DEBUG: NOT SERIALIZING OBJECTS!"); //ret[1] = eo;
// end transaction & session
session.close();
return ret;
when replacing
with
i get the "hibernate://" style uris like this one:
</lobj:childnodes>
which means that the reference linked to the hibernate resource res1,
probably because i only copy the top level object directly to rs from res1.
> Do you do this:
> create res1
> copyall to rs
> serialize rs
Re: fetching non-containment relations eagerly [message #78251 is a reply to message #78236] |
Tue, 03 April 2007 19:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On Tue, 03 Apr 2007 21:13:56 +0200 wrote Martin Taal:
> Hi Christian,
> Okay, why do you create the rs resource using the resourceset using the uri with a
> sessioncontroller? Is it also read from the db?
you're right, that was a mistake.
i changed that to
Resource rs = resourceSet.createResource(URI.createURI("soEinDummy.lobj"));
now(without seeing changes in the result).
> What happens if you create an empty XMI resource and only the res1 resource as you do now and then
> myXMIResource.getContents().addAll(res1.getContents());
do you mean like this?:
// create an uri using the SessionController name
URI uri1 = URI.createURI("hibernate://?dsname=" + dataStore.getName() + "&" +
+ "&" + HibernateResource.SESSION_CONTROLLER_PARAM + "=testsc&query1=from "+eclassname+" where id='"+id+"'");
final Resource res1 = resourceSet.createResource(uri1);
tx.begin();
try {
tx.commit();
> and then serialize the myXMIResource.
that outputs everything at toplevel beneatch the XMI root, without
cascading.(see p.s.)
> gr. Martin
cheers, christian
p.s.:
</lobj:folderMeta>
</lobj:folderMeta>
</lobj:moduleMeta>
</lobj:Module>
<lobj:language>soEinDummy.lobj#de</lobj:language>
</lobj:DidacMeta>
</lobj:Language>
</lobj:ThemeNode>
<lobj:learningUnit>soEinDummy.lobj#learn-1C391734-EF05-CABA-2E9E-7933863BCE4B </lobj:learningUnit>
</lobj:LuNode>
</lobj:didacMeta>
</lobj:luMeta>
<lod>3</lod>
<lobj:block xsi:type="lobj:HypertextBlock">soEinDummy.lobj#hypbl-17FBF85C-6187-3251-F42D-DDB6889238EE </lobj:block>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lod>2</lod>
<lobj:block xsi:type="lobj:HypertextBlock">soEinDummy.lobj#hypbl-AA39CC32-26EB-701B-1FF5-F079E3A2DF84 </lobj:block>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lod>1</lod>
<lobj:block xsi:type="lobj:HypertextBlock">soEinDummy.lobj#hypbl-F4535848-42AF-555D-980F-E46E1BC1FB2F </lobj:block>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<title></title>
</lobj:TitleMeta>
<lobj:learningUnit>soEinDummy.lobj#learn-DCDF4C0A-088A-F507-E839-DC264DF1A66B </lobj:learningUnit>
</lobj:LuNode>
</lobj:didacMeta>
</lobj:luMeta>
<lod>1</lod>
<lobj:block xsi:type="lobj:HypertextBlock">soEinDummy.lobj#hypbl-5F3C7CE3-B80E-19A7-79AD-E2DC563ABEB3 </lobj:block>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lod>2</lod>
<lobj:block xsi:type="lobj:HypertextBlock">soEinDummy.lobj#hypbl-3CEED0D8-1225-AC7C-E36E-3BBF70319CE7 </lobj:block>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lod>3</lod>
<lobj:block xsi:type="lobj:HypertextBlock">soEinDummy.lobj#hypbl-67E547F9-3A13-F4B5-EB83-F0B9E81398A4 </lobj:block>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<title></title>
</lobj:TitleMeta>
</xmi:XMI>
Re: fetching non-containment relations eagerly [message #78276 is a reply to message #78251] |
Tue, 03 April 2007 20:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Christian,
I understand now that soEinDummy.lobj is an empty xmi resource.
What do you mean without cascading?
Do you mean that for example the following xmi contains a href and not a real learningunit instance:
</lobj:LuNode>
As far as I can see this is correct. LearningUnit is present in the resource (soEindDummy.lobj) and
the reference (soEinDummy.lobj#learn-1C391734-EF05-CABA-2E9E-7933863BCE4B) points inside the
resource (soEindDummy.lobj).
The learningUnit is not contained in the LuNode because the ereference has containment==false
(afaik), therefore learningunit is serialized separately and not as part of the LuNode.
So if you deserialize everything it should be correct (LuNode points to the correct learningunit).
Or do I miss/oversee something?
gr. Martin
>> Hi Christian,
> i changed that to
> tx.begin();
> try {
> tx.commit();
>> gr. Martin
> cheers, christian
> p.s.:
> </lobj:folderMeta>
> </lobj:folderMeta>
> </lobj:moduleMeta>
> </lobj:Module>
> </lobj:DidacMeta>
> </lobj:Language>
> </lobj:ThemeNode>
> </lobj:LuNode>
> </lobj:didacMeta>
> </lobj:luMeta>
> <lod>3</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>2</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>1</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <title></title>
> </lobj:TitleMeta>
> </lobj:LuNode>
> </lobj:didacMeta>
> </lobj:luMeta>
> <lod>1</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>2</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>3</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <title></title>
> </lobj:TitleMeta>
> </xmi:XMI>
The Netherlands
Re: fetching non-containment relations eagerly [message #78384 is a reply to message #78276] |
Wed, 04 April 2007 14:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
hi!
On Tue, 03 Apr 2007 22:50:38 +0200 wrote Martin Taal:
> Hi Christian,
> </lobj:LuNode>
that would be ok, but Blocks/HypertextBlocks, for instance, should be
nested inside a learningunit. i just posted to the emf newsgroup, since i
believe i might be misunderstanding how EMF works. please have a look at
it, if your time allows!
cheers, chris
Re: fetching non-containment relations eagerly [message #604217 is a reply to message #77978] |
Tue, 03 April 2007 15:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Christian,
</eAnnotations>
gr. Martin
> </eAnnotations>
> </eAnnotations>
> // @OneToMany
> why' that?
> cheers, chris
> Martin Taal wrote:
>> Hi Christian,
>> </eAnnotations>
>> you should do this:
>> <xsd:annotation>
>> <xsd:appinfo
>> </xsd:annotation>
>> <xsd:annotation>
>> <xsd:appinfo
>> </xsd:annotation>
>> also help others.
>> gr. Martin
The Netherlands
Re: fetching non-containment relations eagerly [message #604225 is a reply to message #77994] |
Tue, 03 April 2007 16:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Christian Donhofer![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=emf_bugzilla%40donhofer.net) Messages: 94 Registered: July 2009 |
Member |
hi martin,
cheers, chris
> Hi Christian,
> </eAnnotations>
> gr. Martin
>> </eAnnotations>
>> </eAnnotations>
>> // @OneToMany
>> why' that?
>> cheers, chris
Re: fetching non-containment relations eagerly [message #604232 is a reply to message #78010] |
Tue, 03 April 2007 16:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
hi again,
cheers, chris
> hi martin,
> cheers, chris
>> Hi Christian,
>> </eAnnotations>
>> gr. Martin
>>> </eAnnotations>
>>> </eAnnotations>
>>> // @OneToMany
>>> why' that?
>>> cheers, chris
Re: fetching non-containment relations eagerly [message #604236 is a reply to message #78025] |
Tue, 03 April 2007 16:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
gr. Martin
> hi again,
> cheers, chris
>> hi martin,
>> cheers, chris
>>> Hi Christian,
>>> </eAnnotations>
>>> gr. Martin
>>>> </eAnnotations>
>>>> </eAnnotations>
>>>> // @OneToMany
>>>> why' that?
>>>> cheers, chris
The Netherlands
Re: fetching non-containment relations eagerly [message #604242 is a reply to message #78041] |
Tue, 03 April 2007 17:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
when using
using
</lobj:LuNode>
</lobj:didacMeta>
</lobj:luMeta>
i believe that
what do you think?
cheers, chris
> gr. Martin
>> hi again,
>> this:
>> ModuleFolder where
>> cheers, chris
>>> hi martin,
>>> already),
>>> cheers, chris
>>>> Hi Christian,
>>>> </eAnnotations>
>>>> the annotation(s).
>>>> gr. Martin
>>>>> </eAnnotations>
>>>>> </eAnnotations>
>>>>> // @OneToMany
>>>>> why' that?
>>>>> cheers, chris
Re: fetching non-containment relations eagerly [message #604249 is a reply to message #78057] |
Tue, 03 April 2007 17:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
gr. Martin
> when using
> using
> </lobj:LuNode>
> </lobj:didacMeta>
> </lobj:luMeta>
> i believe that
> what do you think?
> cheers, chris
>> gr. Martin
>>> hi again,
>>> this:
>>> ModuleFolder where
>>> cheers, chris
>>>> hi martin,
>>>> already),
>>>> cheers, chris
>>>>> Hi Christian,
>>>>> </eAnnotations>
>>>>> the annotation(s).
>>>>> gr. Martin
>>>>>> </eAnnotations>
>>>>>> </eAnnotations>
>>>>>> // @OneToMany
>>>>>> why' that?
>>>>>> cheers, chris
The Netherlands
Re: fetching non-containment relations eagerly [message #604261 is a reply to message #78117] |
Tue, 03 April 2007 17:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
gr. martin
> example xmi
> </lobj:childnodes>
>> gr. Martin
> cheers, chris
The Netherlands
Re: fetching non-containment relations eagerly [message #604268 is a reply to message #78146] |
Tue, 03 April 2007 18:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
After doing this:
gr. Martin
> </lobj:folderMeta>
> </lobj:folderMeta>
> </lobj:didacMeta>
> </lobj:moduleMeta>
> </lobj:theme>
> </lobj:childnodes>
> </lobj:childnodes>
> </lobj:childnodes>
> </lobj:rootNode>
> </lobj:module>
>> gr. martin
> cheers, chris
The Netherlands
Re: fetching non-containment relations eagerly [message #604276 is a reply to message #78160] |
Tue, 03 April 2007 18:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
(after calling
> After doing this:
like this:
try{
throw(e);
return myObject;
> gr. Martin
cheers, chris
p.s.:
</lobj:folderMeta>
</lobj:folderMeta>
</lobj:moduleMeta>
</lobj:Module>
</lobj:DidacMeta>
</lobj:Language>
</lobj:ThemeNode>
</lobj:LuNode>
</lobj:didacMeta>
</lobj:luMeta>
<lod>3</lod>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lod>2</lod>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lod>1</lod>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<title></title>
</lobj:TitleMeta>
</lobj:LuNode>
</lobj:didacMeta>
</lobj:luMeta>
<lod>1</lod>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lod>2</lod>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<lod>3</lod>
<title></title>
</simpleDidacMeta>
</lobj:blockMeta>
<title></title>
</lobj:TitleMeta>
</xmi:XMI>
Re: fetching non-containment relations eagerly [message #604279 is a reply to message #78175] |
Tue, 03 April 2007 18:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Do you do this:
create res1
copyall to rs
serialize rs
gr. Martin
> (after calling
>> After doing this:
> like this:
> try{
> throw(e);
> return myObject;
>> gr. Martin
> cheers, chris
> p.s.:
> </lobj:folderMeta>
> </lobj:folderMeta>
> </lobj:moduleMeta>
> </lobj:Module>
> </lobj:DidacMeta>
> </lobj:Language>
> </lobj:ThemeNode>
> </lobj:LuNode>
> </lobj:didacMeta>
> </lobj:luMeta>
> <lod>3</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>2</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>1</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <title></title>
> </lobj:TitleMeta>
> </lobj:LuNode>
> </lobj:didacMeta>
> </lobj:luMeta>
> <lod>1</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>2</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>3</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <title></title>
> </lobj:TitleMeta>
> </xmi:XMI>
The Netherlands
Re: fetching non-containment relations eagerly [message #604287 is a reply to message #78191] |
Tue, 03 April 2007 19:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
actual code:
boolean serialize){
Resource rs =
tx.begin();
try {
tx.commit();
if(serialize){
try{
ret[0] = "500";
return ret;
ret[1] = myObject;
}else{
session.close();
return ret;
when replacing
with
</lobj:childnodes>
> Do you do this:
> create res1
> copyall to rs
> serialize rs
Re: fetching non-containment relations eagerly [message #604304 is a reply to message #78251] |
Tue, 03 April 2007 20:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Christian,
</lobj:LuNode>
gr. Martin
>> Hi Christian,
> i changed that to
> tx.begin();
> try {
> tx.commit();
>> gr. Martin
> cheers, christian
> p.s.:
> </lobj:folderMeta>
> </lobj:folderMeta>
> </lobj:moduleMeta>
> </lobj:Module>
> </lobj:DidacMeta>
> </lobj:Language>
> </lobj:ThemeNode>
> </lobj:LuNode>
> </lobj:didacMeta>
> </lobj:luMeta>
> <lod>3</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>2</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>1</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <title></title>
> </lobj:TitleMeta>
> </lobj:LuNode>
> </lobj:didacMeta>
> </lobj:luMeta>
> <lod>1</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>2</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <lod>3</lod>
> <title></title>
> </simpleDidacMeta>
> </lobj:blockMeta>
> <title></title>
> </lobj:TitleMeta>
> </xmi:XMI>
The Netherlands
Current Time: Sat Jul 06 16:24:34 GMT 2024
Powered by FUDForum. Page generated in 0.10665 seconds
